查看: 4032|回复: 11
求转换规则(apache转nginx)
发表于 2012-2-11 20:59:11 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
RewriteEngine On
ErrorDocument 404 /404.php
ErrorDocument 500 /500.php
Rewritebase /
RewriteRule ^(.*)xx(.+)\.jsp$  $1product.php?rule=$2
RewriteRule ^(.*)lb(.+)\.jsp$ $1list.php?rule=$2
RewriteRule ^(.*)dp(.+)\.jsp$  $1shopsearch.php?rule=$2
RewriteRule ^(.*)tp(.+)\.jsp$ $1pic.php?rule=$2
RewriteRule ^(.*)shop-(.+)\.jsp$ $1shop.php?rule=$2
求手工转换
发表于 2012-2-11 21:00:56 | 只看该作者
额,这个还真不会
 楼主| 发表于 2012-2-11 21:01:40 | 只看该作者
没人会吗- -
发表于 2012-2-11 21:04:06 | 只看该作者
手工不会。。
http://www.anilcetin.com/convert-apache-htaccess-to-nginx/
if ($rule_0 = ""){
rewrite ^/(.*)xx(.+).jsp$ /;
if ($rule_1 = ""){
rewrite ^/(.*)lb(.+).jsp$ /$1list.php?rule=$2;
if ($rule_2 = ""){
rewrite ^/(.*)dp(.+).jsp$ /;
if ($rule_3 = ""){
rewrite ^/(.*)tp(.+).jsp$ /$1pic.php?rule=$2;
if ($rule_4 = ""){
rewrite ^/(.*)shop-(.+).jsp$ /$1shop.php?rule=$2;
 楼主| 发表于 2012-2-11 21:07:54 | 只看该作者
ㄒiger 发表于 2012-2-11 21:04
手工不会。。
表示粘贴完就无法启动nginx了
 楼主| 发表于 2012-2-11 21:08:45 | 只看该作者
[root@278088 conf]# /root/lnmp start
Manager for LNMP V0.8  ,  Written by Licess
LNMP is a tool to auto-compile & install Nginx+MySQL+PHP on Linux
This script is a tool to Manage status of lnmp
For more information please visit http://www.lnmp.org
Usage: /root/lnmp {start|stop|reload|restart|kill|status}
Starting LNMP...
nginx: [emerg] unknown "rule_0" variable
Nginx start successfully!
php-fpm is runing!
MySQL is runing!
 楼主| 发表于 2012-2-11 21:24:30 | 只看该作者
发表于 2012-2-11 21:40:26 | 只看该作者
发表于 2012-2-11 21:58:43 | 只看该作者
试试把规则弄到外面
 楼主| 发表于 2012-2-11 22:06:36 | 只看该作者
UCVPS 发表于 2012-2-11 21:58
试试把规则弄到外面
怎么弄?
GMT+8, 2026-4-24 04:24 , Processed in 0.067082 second(s), 10 queries , Gzip On, MemCache On.
