查看: 2360|回复: 14
大家报下自己MK-5D-R的配置
发表于 2022-6-22 20:48:12 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
RT
  1. Basic System Information:
  3. Uptime     : 0 days, 0 hours, 6 minutes
  4. Processor  : Intel(R) Xeon(R) CPU E5-2630L 0  2.00GHz
  5. CPU cores  : 24 [url=home.php?mod=space&uid=175]@[/url] 1199.951 MHz
  6. AES-NI     : ✔ Enabled
  7. VM-x/AMD-V : ✔ Enabled
  8. RAM        : 3.6 GiB
  9. Swap       : 3.9 GiB
  10. Disk       : 106.1 GiB
  11. Distro     : CentOS Linux 7 (Core)
  12. Kernel     : 3.10.0-1160.el7.x86_64
  13. fio Disk Speed Tests (Mixed R/W 50/50):
  14. ---------------------------------
  15. Block Size | 4k            (IOPS) | 64k           (IOPS)
  16.   ------   | ---            ----  | ----           ----
  17. Read       | 26.80 MB/s    (6.7k) | 52.66 MB/s     (822)
  18. Write      | 26.83 MB/s    (6.7k) | 53.05 MB/s     (829)
  19. Total      | 53.63 MB/s   (13.4k) | 105.72 MB/s   (1.6k)
  20.            |                      |
  21. Block Size | 512k          (IOPS) | 1m            (IOPS)
  22.   ------   | ---            ----  | ----           ----
  23. Read       | 57.82 MB/s     (112) | 51.50 MB/s      (50)
  24. Write      | 60.67 MB/s     (118) | 55.03 MB/s      (53)
  25. Total      | 118.49 MB/s    (230) | 106.54 MB/s    (103)
  26. iperf3 Network Speed Tests (IPv4):
  27. ---------------------------------
  28. Provider        | Location (Link)           | Send Speed      | Recv Speed
  29.                 |                           |                 |
  30. Clouvider       | London, UK (10G)          | 26.6 Mbits/sec  | 27.1 Mbits/sec
  31. Online.net      | Paris, FR (10G)           | 26.6 Mbits/sec  | 24.7 Mbits/sec
  32. Hybula          | The Netherlands (40G)     | 26.4 Mbits/sec  | 26.2 Mbits/sec
发表于 2022-6-22 20:49:13 | 只看该作者
24U 4G这也太瘸腿了吧。
发表于 2022-6-22 20:51:03 | 只看该作者
  1. CPU Model            : Intel(R) Xeon(R) CPU E5-2630L 0 [url=home.php?mod=space&uid=175]@[/url] 2.00GHz
  2. CPU Cores            : 24 Cores 1197.049 MHz x86_64
  3. CPU Cache            : 15360 KB
  4. OS                   : CentOS 7.9.2009 (64 Bit) Dedicated
  5. Kernel               : 4.14.129-bbrplus
  6. Total Space          : 1.8 GB / 436.9 GB
  7. Total RAM            : 210 MB / 3888 MB (157 MB Buff)
  8. Total SWAP           : 0 MB / 3968 MB
  9. Uptime               : 0 days 0 hour 2 min
  10. Load Average         : 0.00, 0.00, 0.00
  11. TCP CC               : bbrplus
  12. ASN & ISP            : AS138195, Dotname Korea Corp
  13. Organization         : Icidc Limited
  14. Location             : Yongin-si, South Korea / KR
  15. Region               : Gyeonggi-do
  16. ----------------------------------------------------------------------
  17. I/O Speed( 1.0GB )   : 247 MB/s
  18. I/O Speed( 1.0GB )   : 252 MB/s
  19. I/O Speed( 1.0GB )   : 250 MB/s
  20. Average I/O Speed    : 249.7 MB/s
  21. ----------------------------------------------------------------------
  22. Node Name        Upload Speed      Download Speed      Latency
  23. Speedtest.net    9.42 Mbit/s       29.13 Mbit/s        1.31 ms
  24. Fast.com         0.00 Mbit/s       29.3 Mbit/s         -
  25. Nanjing 5G   CT  28.78 Mbit/s      29.05 Mbit/s        102.05 ms
  26. Hefei 5G     CT  28.50 Mbit/s      29.00 Mbit/s        61.94 ms
  27. Guangzhou 5G CT  13.14 Mbit/s      26.74 Mbit/s        54.00 ms
  28. Shanghai 5G  CU  28.93 Mbit/s      29.03 Mbit/s        23.56 ms
  29. Wuxi 5G      CM  28.53 Mbit/s      28.87 Mbit/s        33.31 ms
  30. Nanjing 5G   CM  18.44 Mbit/s      29.86 Mbit/s        40.48 ms
  31. Hefei 5G     CM  28.35 Mbit/s      28.49 Mbit/s        43.81 ms
  32. ----------------------------------------------------------------------
  33. Finished in  : 3 min 56 sec
  34. Timestamp    : 2022-04-28 23:16:16 GMT+8
  35. Results      : ./superbench.log
发表于 2022-6-22 20:51:09 | 只看该作者
24c 4G,哪有这么玩的
发表于 2022-6-22 20:51:45 | 只看该作者
https://github.com/jvlflame/Javinizer
能跑这个吗我看看
 楼主| 发表于 2022-6-22 23:48:16 | 只看该作者
其实是不是很多都是4G内存的
发表于 2022-6-22 23:53:16 | 只看该作者
心疼你1秒 直接抽个最低最低配 我开了一个 8G 1T机械
 楼主| 发表于 2022-6-22 23:55:15 | 只看该作者
哎呀,你运气怎么这么好的,你这个配置真的是我想要的
发表于 2022-6-23 00:02:16 | 只看该作者
51Yo 发表于 2022-6-22 23:48
其实是不是很多都是4G内存的
现在不是可以加钱升级内存了么 32G8刀吧 你问问客服
 楼主| 发表于 2022-6-23 00:03:37 | 只看该作者
一次性还是怎么样的
GMT+8, 2026-4-13 23:04 , Processed in 0.072229 second(s), 10 queries , Gzip On, MemCache On.
