查看: 2739|回复: 25
请教各位技术帝,无法yum update
发表于 2012-2-1 19:38:05 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
[root@min ~]# yum update
Loaded plugins: fastestmirror
Loading mirror speeds from cached hostfile
Traceback (most recent call last):
  File "/usr/bin/yum", line 29, in ?
    yummain.user_main(sys.argv[1:], exit_code=True)
  File "/usr/share/yum-cli/yummain.py", line 309, in user_main
    errcode = main(args)
  File "/usr/share/yum-cli/yummain.py", line 178, in main
    result, resultmsgs = base.doCommands()
  File "/usr/share/yum-cli/cli.py", line 345, in doCommands
    self._getTs(needTsRemove)
  File "/usr/lib/python2.4/site-packages/yum/depsolve.py", line 101, in _getTs
    self._getTsInfo(remove_only)
  File "/usr/lib/python2.4/site-packages/yum/depsolve.py", line 112, in _getTsInfo
    pkgSack = self.pkgSack
  File "/usr/lib/python2.4/site-packages/yum/__init__.py", line 662, in <lambda>
    pkgSack = property(fget=lambda self: self._getSacks(),
  File "/usr/lib/python2.4/site-packages/yum/__init__.py", line 502, in _getSacks
    self.repos.populateSack(which=repos)
  File "/usr/lib/python2.4/site-packages/yum/repos.py", line 232, in populateSack
    self.doSetup()
  File "/usr/lib/python2.4/site-packages/yum/repos.py", line 79, in doSetup
    self.ayum.plugins.run('postreposetup')
  File "/usr/lib/python2.4/site-packages/yum/plugins.py", line 179, in run
    func(conduitcls(self, self.base, conf, **kwargs))
  File "/usr/lib/yum-plugins/fastestmirror.py", line 181, in postreposetup_hook
    all_urls = FastestMirror(all_urls).get_mirrorlist()
  File "/usr/lib/yum-plugins/fastestmirror.py", line 333, in get_mirrorlist
    self._poll_mirrors()
  File "/usr/lib/yum-plugins/fastestmirror.py", line 376, in _poll_mirrors
    pollThread.start()
  File "/usr/lib/python2.4/threading.py", line 416, in start
    _start_new_thread(self.__bootstrap, ())
thread.error: can't start new thread
出现上述问题。。。重装完无法用yum。。。小弟技术太菜,搞不懂了,求教
发表于 2012-2-1 19:40:00 | 只看该作者
没看懂
发表于 2012-2-1 19:41:08 | 只看该作者
俺也没看懂呀
 楼主| 发表于 2012-2-1 19:41:46 | 只看该作者
继续求高手。。。我觉得好像是RPM包和PYthon的问题。。。
发表于 2012-2-1 19:47:14 | 只看该作者
gcc?
发表于 2012-2-1 19:48:34 | 只看该作者
fastestmirrot的事,删掉以后,重装yum即可
yum -y remove yum-fastestmirrot
删掉了,下载个yum,装上,再yum update    ,回答完毕,求分,撸过
参与人数 1威望 +5 收起 理由
tubos + 5 很给力!
发表于 2012-2-1 19:51:50 | 只看该作者
楼上牛人~
发表于 2012-2-1 19:52:33 | 只看该作者
明显的内存不足
 楼主| 发表于 2012-2-1 19:54:33 | 只看该作者
paopao00 发表于 2012-2-1 19:52
明显的内存不足
论坛里T楼得的128M
 楼主| 发表于 2012-2-1 19:55:52 | 只看该作者
[root@min ~]# yum -y remove yum-fastestmirrot
Setting up Remove Process
No Match for argument: yum-fastestmirrot
  File "/usr/share/yum-cli/cli.py", line 349, in doCommands
    return self.yum_cli_commands[self.basecmd].doCommand(self, self.basecmd, sel                                              f.extcmds)
  File "/usr/share/yum-cli/yumcommands.py", line 365, in doCommand
    return base.erasePkgs(extcmds)
  File "/usr/share/yum-cli/cli.py", line 638, in erasePkgs
    self._checkMaybeYouMeant(arg, always_output=False)
  File "/usr/share/yum-cli/cli.py", line 533, in _checkMaybeYouMeant
    matches = self.doPackageLists(patterns=[arg], ignore_case=False)
  File "/usr/lib/python2.4/site-packages/yum/__init__.py", line 1618, in doPacka                                              geLists
    avail = self.pkgSack.returnNewestByNameArch(patterns=patterns,
  File "/usr/lib/python2.4/site-packages/yum/__init__.py", line 502, in _getSack                                              s
  File "/usr/lib/python2.4/site-packages/yum/repos.py", line 232, in populateSac                                              k
    self.doSetup()
    pollThread.start()
还是删不掉。。。
GMT+8, 2026-4-15 13:24 , Processed in 0.152123 second(s), 14 queries , Gzip On, MemCache On.
