查看: 4367|回复: 16
电信的朋友帮个忙
发表于 2010-2-4 22:48:02 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
帮忙看看这个ip走哪个线路,谢谢!   我这电信走的level3,速度不是太理想,想看看其他地区。
tracert 67.213.219.229
发表于 2010-2-4 22:52:18 | 只看该作者
安徽电信
Microsoft Windows [版本 5.2.3790]
(C) 版权所有 1985-2003 Microsoft Corp.
C:\Documents and Settings\Administrator>tracert 67.213.219.229
Tracing route to 67.213.219.229 over a maximum of 30 hops
  1    33 ms    35 ms    35 ms  114.99.252.1
  2    33 ms    32 ms    36 ms  61.191.4.217
  3    38 ms    35 ms    34 ms  61.190.255.201
  4    40 ms    39 ms    39 ms  202.97.18.82
  5    46 ms    45 ms    46 ms  202.97.39.129
  6    47 ms    44 ms    44 ms  202.97.33.74
  7    48 ms    49 ms    46 ms  202.97.33.2
  8   224 ms   224 ms   225 ms  202.97.51.182
  9     *        *      324 ms  te-8-1.car4.SanJose1.Level3.net [4.71.114.101]
10   335 ms     *      326 ms  vlan89.csw3.SanJose1.Level3.net [4.68.18.190]
11   325 ms   332 ms   324 ms  ae-82-82.ebr2.SanJose1.Level3.net [4.69.134.217]
12   356 ms   350 ms   354 ms  ae-7.ebr1.Seattle1.Level3.net [4.69.132.50]
13   347 ms   346 ms     *     ae-14-51.car4.Seattle1.Level3.net [4.68.105.5]
14   223 ms   222 ms   223 ms  te2-1.cer01.sea01.seattle-datacenter.com [4.71.1
52.138]
15     *      222 ms     *     po1.fcr01.sea01.seattle-datacenter.com [67.228.1
18.134]
16   245 ms   243 ms   246 ms  174.36.153.150-static.reverse.softlayer.com [174
.36.153.150]
17   242 ms   240 ms   241 ms  67.213.219.229
Trace complete.
发表于 2010-2-4 22:52:59 | 只看该作者
C:\Documents and Settings\Administrator>ping 67.213.219.229
Pinging 67.213.219.229 with 32 bytes of data:
Reply from 67.213.219.229: bytes=32 time=241ms TTL=51
Reply from 67.213.219.229: bytes=32 time=247ms TTL=51
Reply from 67.213.219.229: bytes=32 time=240ms TTL=51
Reply from 67.213.219.229: bytes=32 time=245ms TTL=51
Ping statistics for 67.213.219.229:
    Minimum = 240ms, Maximum = 247ms, Average = 243ms
 楼主| 发表于 2010-2-4 22:55:33 | 只看该作者
 楼主| 发表于 2010-2-4 22:57:31 | 只看该作者
这么久了没有发现一个真正完美的vps(主要都是线路问题),杯具啊!
发表于 2010-2-4 22:59:34 | 只看该作者
softlayer @ seattle, level3 , 深圳电信4M
imac:~ chen$ traceroute  67.213.219.229
traceroute to 67.213.219.229 (67.213.219.229), 64 hops max, 52 byte packets
1  192.168.1.1 (192.168.1.1)  80.279 ms  0.678 ms  0.643 ms
2  119.122.174.1 (119.122.174.1)  27.451 ms  29.483 ms  29.249 ms
3  121.15.150.49 (121.15.150.49)  21.840 ms  21.049 ms  21.181 ms
4  58.60.24.33 (58.60.24.33)  21.769 ms  20.965 ms  22.439 ms
5  119.145.47.82 (119.145.47.82)  23.375 ms  23.631 ms  23.400 ms
6  * 202.97.33.218 (202.97.33.218)  24.071 ms  80.529 ms
7  202.97.60.66 (202.97.60.66)  24.194 ms  25.375 ms  24.407 ms
8  202.97.51.230 (202.97.51.230)  183.627 ms  206.300 ms  184.982 ms
9  te-8-1.car4.sanjose1.level3.net (4.71.114.101)  314.455 ms  184.288 ms  184.033 ms
10  vlan99.csw4.sanjose1.level3.net (4.68.18.254)  189.716 ms  188.893 ms  184.967 ms
11  ae-92-92.ebr2.sanjose1.level3.net (4.69.134.221)  191.894 ms  186.239 ms  197.369 ms
12  ae-7.ebr1.seattle1.level3.net (4.69.132.50)  207.634 ms  201.886 ms  212.036 ms
13  ae-14-51.car4.seattle1.level3.net (4.68.105.5)  202.810 ms  202.082 ms  202.434 ms
14  te2-1.cer01.sea01.seattle-datacenter.com (4.71.152.138)  203.102 ms  202.660 ms  203.447 ms
15  po1.fcr01.sea01.seattle-datacenter.com (67.228.118.134)  215.556 ms  204.103 ms *
16  174.36.153.150-static.reverse.softlayer.com (174.36.153.150)  202.925 ms  202.686 ms  203.132 ms
17  67.213.219.229 (67.213.219.229)  204.373 ms  203.144 ms  202.964 ms
 楼主| 发表于 2010-2-4 23:00:22 | 只看该作者
楼上的走level3,速度也不错呀   不愧是4M的
发表于 2010-2-4 23:05:25 | 只看该作者
厦门电信访问,走的Level3线路。
 楼主| 发表于 2010-2-4 23:08:04 | 只看该作者
我现在用的PR机房的vps,一到晚上下载速度只有20几k,郁闷死了
发表于 2010-2-4 23:15:05 | 只看该作者
我这里level3一直很好。。seattle很不错。。上次抽的时候用ecvps的连接测试下载速度也有300kb
GMT+8, 2026-4-30 10:47 , Processed in 0.062414 second(s), 10 queries , Gzip On, MemCache On.
