查看: 3796|回复: 0
[Windows VPS] 下载了个xshell的中文语言如何应用到xshell啊
发表于 2012-1-31 17:08:06 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  1. POPUP "文件(&F)"
  2.         MENUITEM "新建(&N)...", ID_FILE_NEW
  3.         MENUITEM "打开(&O)\tAlt+O", ID_FILE_OPEN
  4.         MENUITEM "关闭(&C)\tAlt+C", ID_FILE_CLOSE
  5.         MENUITEM "另存(&A)...", ID_FILE_SAVE_AS
  6.         MENUITEM SEPARATOR
  7.         MENUITEM "打印(&P)...", ID_FILE_PRINT
  8.         MENUITEM "打印预览(&V)", ID_FILE_PRINT_PREVIEW
  9.         MENUITEM "打印设置(&U)...", ID_FILE_PAGE_SETUP
  10.         MENUITEM SEPARATOR
  11.         POPUP "传送器(&T)"
  12.                 MENUITEM "发送 ASCII(&S)...", ID_TRANSFER_SEND_ASCII
  13.                 MENUITEM SEPARATOR
  14.                 MENUITEM "发送 ZMODEM(&Z)...", ID_TRANSFER_SEND_ZMODEM
  15.                 MENUITEM "接收 ZMODEM(&M)...", ID_TRANSFER_RECV_ZMODEM
  16.         END_POPUP
  17.         POPUP "日志(&L)"
  18.                 MENUITEM "开始(&S)...", ID_FILE_LOG_START
  19.                 MENUITEM "停止(&T)", ID_FILE_LOG_STOP
  20.                 MENUITEM SEPARATOR
  21.                 MENUITEM "暂停(&P)", ID_FILE_LOG_PAUSE
  22.                 MENUITEM "继续(&R)", ID_FILE_LOG_RESUME
  23.                 MENUITEM SEPARATOR
  24.                 MENUITEM "打开日志文件(&O)", ID_FILE_LOG_OPEN
  25.         END_POPUP
  26.         MENUITEM SEPARATOR
  27.         MENUITEM "配置(&R)\tAlt+P", ID_FILE_PROPERTIES
  28.         MENUITEM SEPARATOR
  29.         MENUITEM "退出(&X)", ID_APP_EXIT
  30. END_POPUP
  31. POPUP "编辑(&E)"
  32.         MENUITEM "复制(&C)\tCtrl+Ins", ID_EDIT_COPY
  33.         MENUITEM "粘贴(&P)\tShift+Ins", ID_EDIT_PASTE
  34.         MENUITEM "粘贴选中内容(&E)\tAlt+Ins", ID_EDIT_PASTE_SELECTION
  35.         MENUITEM SEPARATOR
  36.         MENUITEM "全选(&A)", ID_EDIT_SELECT_ALL
  37.         MENUITEM "选中当前屏幕(&S)", ID_EDIT_SELECT_SCREEN
  38.         MENUITEM SEPARATOR
  39.         MENUITEM "查找(&F)...", ID_EDIT_FIND
  40.         MENUITEM SEPARATOR
  41.         POPUP "复制到记事本(&N)"
  42.                 MENUITEM "选中的区域(&S)", ID_EDIT_TO_NOTEPAD_SELECTED
  43.                 MENUITEM "所有内容(&A)", ID_EDIT_TO_NOTEPAD_ALL
  44.                 MENUITEM "当前屏幕(&C)", ID_EDIT_TO_NOTEPAD_SCREEN
  45.         END_POPUP
  46.         MENUITEM SEPARATOR
  47.         MENUITEM "重置光标(&R)", ID_EDIT_RESET_CURSOR
  48.         MENUITEM "重置终端(&T)", ID_EDIT_RESET_TERMINAL
  49. END_POPUP
  50. POPUP "视图(&V)"
  51.         POPUP "工具栏(&T)"
  52.                 MENUITEM "菜单栏(&M)", ID_VIEW_MENUBAR
  53.                 MENUITEM "标准按钮(&S)", ID_VIEW_TOOLBAR
  54.                 MENUITEM "地址栏(&A)", ID_VIEW_ADDRBAR
  55.                 MENUITEM "链接(&L)", ID_VIEW_LINKS
  56.                 MENUITEM "字体(&F)", ID_VIEW_FONTBAR
  57.                 MENUITEM "快速命令(&Q)", ID_VIEW_QUICKBAR
  58.                 MENUITEM SEPARATOR
  59.                 MENUITEM "锁定工具栏(&B)", ID_VIEW_TOOLBAR_LOCK
  60.                 MENUITEM "自定义(&C)...", ID_VIEW_TOOLBAR_CUSTOMIZE
  61.         END_POPUP
  62.         MENUITEM "滚动条(&S)", ID_VIEW_SCROLLBAR
  63.         MENUITEM "状态栏(&B)", ID_VIEW_STATUS_BAR
  64.         MENUITEM SEPARATOR
  65.         MENUITEM "会话标签(&I)", ID_VIEW_SESSION_TAB
  66.         MENUITEM "会话栏(&E)", ID_VIEW_SESSION_BAR
  67.         MENUITEM SEPARATOR
  68.         MENUITEM "命令栏(&C)", ID_VIEW_COMPOSE
  69.         MENUITEM "通道栏(&U)", ID_VIEW_TUNNELING
  70.         MENUITEM SEPARATOR
  71.         POPUP "布局(&L)"
  72.                 MENUITEM "默认(&D)", ID_VIEW_LAYOUT_DEFAULT
  73.                 MENUITEM SEPARATOR
  74.                 MENUITEM "<< 布局列表 >>", ID_VIEW_LAYOUT_LIST
  75.                 MENUITEM SEPARATOR
  76.                 MENUITEM "另存(&S)...", ID_VIEW_LAYOUT_SNAPSHOT
  77.                 MENUITEM "管理(&M)...", ID_VIEW_LAYOUT_MANAGE
  78.         END_POPUP
  79.         MENUITEM SEPARATOR
  80.         MENUITEM "透明(&R)\tAlt+T", ID_VIEW_TRANSPARENT
  81.         MENUITEM "置顶(&A)\tAlt+A", ID_VIEW_TOPMOST
  82.         MENUITEM SEPARATOR
  83.         MENUITEM "全屏(&F)\tAlt+Enter", ID_VIEW_FULLSCREEN
  84.         MENUITEM "最小化到系统托盘(&G)", ID_VIEW_GOTO_TRAY
  85. END_POPUP
  86. POPUP "工具(&T)"
  87.         MENUITEM "Sun 快捷键(&S)", ID_TOOLS_SUNKEYS
  88.         MENUITEM SEPARATOR
  89.         MENUITEM "主机密钥管理器(&H)...", ID_TOOLS_HOSTKEYS
  90.         MENUITEM "用户密钥管理器(&U)...", ID_TOOLS_USERKEYS
  91.         MENUITEM "用户密钥生成器(&G)...", ID_TOOLS_USERKEY_GENERATOR
  92.         MENUITEM SEPARATOR
  93.         MENUITEM "启动 Xagent(&A)", ID_TOOLS_XAGENT
  94.         MENUITEM "启动 Xactivator(&L)", ID_TOOLS_XACTIVATOR
  95.         MENUITEM SEPARATOR
  96.         MENUITEM "色彩方案(&C)...", ID_TOOLS_COLORSCHEME_EDITOR
  97.         MENUITEM "快速命令集(&Q)...", ID_TOOLS_QUICK_BUTTONS
  98.         MENUITEM SEPARATOR
  99.         MENUITEM "选项(&O)...", ID_TOOLS_OPTIONS
  100. END_POPUP
  101. POPUP "窗口(&W)"
  102.         MENUITEM "新建窗口(&N)", ID_WINDOW_NEW
  103.         MENUITEM "关闭所有窗口(&C)", ID_WINDOW_CLOSE_ALL
  104.         MENUITEM "关闭所有其他窗口(&A)", ID_WINDOW_CLOSE_ALL_OTHERS
  105.         MENUITEM SEPARATOR
  106.         MENUITEM "后一个窗口(&x)\tAlt+Right", ID_WINDOW_NEXT
  107.         MENUITEM "前一个窗口(&v)\tAlt+Left", ID_WINDOW_PREV
  108.         MENUITEM SEPARATOR
  109.         MENUITEM "层叠显示窗口(&S)", ID_WINDOW_CASCADE
  110.         MENUITEM "堆叠显示窗口(&I)", ID_WINDOW_TILE_HORZ
  111.         MENUITEM "并列显示窗口(&L)", ID_WINDOW_TILE_VERT
  112.         MENUITEM SEPARATOR
  113.         MENUITEM "新建终端(&T)\tCtrl+Alt+T", ID_FILE_OPEN_AS_TERM
  114.         MENUITEM "新建文件传送器(&F)\tCtrl+Alt+F", ID_FILE_OPEN_AS_FTP
  115.         MENUITEM SEPARATOR
  116.         MENUITEM "<< 窗口列表 >>", ID_WINDOW_LIST
  117. END_POPUP
  118. POPUP "帮助(&H)"
  119.         MENUITEM "Xshell 帮助(&X)", ID_APP_HELP
  120.         MENUITEM SEPARATOR
  121.         MENUITEM "Xshell 主页(&V)", ID_APP_WEBSITE
  122.         MENUITEM "Xshell 在线论坛(&F)", ID_APP_FORUM
  123.         MENUITEM SEPARATOR
  124.         MENUITEM "检查更新(&C)...", ID_APP_UPDATECHECK
  125.         MENUITEM "注册(&R)...", ID_APP_REGISTER
  126.         MENUITEM SEPARATOR
  127.         MENUITEM "关于 Xshell (&A)", ID_APP_ABOUT
  128. END_POPUP
example_zh.rar
1.58 KB, 下载次数: 425
GMT+8, 2026-4-14 02:33 , Processed in 0.125051 second(s), 13 queries , Gzip On, MemCache On.
