查看: 6312|回复: 16
[已解决]win11无法运行bat文件,怎么解决
发表于 2022-6-7 11:52:53 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
双击运行弹出弹出“打开方式”的对话框,让选择:
试了网上的几种方法都不行
网上有很多类似的帖子,方法大致为:
1. 将bat 文件的格式从UTF-8 改成ASNI
2. 添加环境变量,将c:\Windows\System32 添加到环境变量path 中
3. 修改注册表中.bat 相关属性,将其属性值都改成“未设置”
4. 关联成cmd运行
5. 删除注册表batfile
只能手动打开cmd再拖进去才能运行。太是太麻烦了
按这个可以了:命令行
                         assoc .bat=batfile
                          ftype batfile="%1" %*
发表于 2022-6-7 13:56:49 | 只看该作者
保存,导入试试
  1. Windows Registry Editor Version 5.00
  2. [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\.bat]
  3. @="batfile"
  4. [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\.bat\PersistentHandler]
  5. @="{5e941d80-bf96-11cd-b579-08002b30bfeb}"
  6. [HKEY_CLASSES_ROOT\.bat]
  7. @="batfile"
  8. [HKEY_CLASSES_ROOT\.bat\PersistentHandler]
  9. @="{5e941d80-bf96-11cd-b579-08002b30bfeb}"
  10. [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\batfile]
  11. @="Windows Batch File"
  12. "EditFlags"=hex:30,04,00,00
  13. "FriendlyTypeName"=hex(2):40,00,25,00,53,00,79,00,73,00,74,00,65,00,6d,00,52,\
  14.   00,6f,00,6f,00,74,00,25,00,5c,00,53,00,79,00,73,00,74,00,65,00,6d,00,33,00,\
  15.   32,00,5c,00,61,00,63,00,70,00,70,00,61,00,67,00,65,00,2e,00,64,00,6c,00,6c,\
  16.   00,2c,00,2d,00,36,00,30,00,30,00,32,00,00,00
  17. [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\batfile\DefaultIcon]
  18. @=hex(2):25,00,53,00,79,00,73,00,74,00,65,00,6d,00,52,00,6f,00,6f,00,74,00,25,\
  19.   00,5c,00,53,00,79,00,73,00,74,00,65,00,6d,00,33,00,32,00,5c,00,69,00,6d,00,\
  20.   61,00,67,00,65,00,72,00,65,00,73,00,2e,00,64,00,6c,00,6c,00,2c,00,2d,00,36,\
  21.   00,38,00,00,00
  22. [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\batfile\shell]
  23. [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\batfile\shell\edit]
  24. [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\batfile\shell\edit\command]
  25. @=hex(2):25,00,53,00,79,00,73,00,74,00,65,00,6d,00,52,00,6f,00,6f,00,74,00,25,\
  26.   00,5c,00,53,00,79,00,73,00,74,00,65,00,6d,00,33,00,32,00,5c,00,4e,00,4f,00,\
  27.   54,00,45,00,50,00,41,00,44,00,2e,00,45,00,58,00,45,00,20,00,25,00,31,00,00,\
  28.   00
  29. [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\batfile\shell\open]
  30. [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\batfile\shell\open\command]
  31. @=""%1" %*"
  32. [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\batfile\shell\print]
  33. [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\batfile\shell\print\command]
  34. @=hex(2):25,00,53,00,79,00,73,00,74,00,65,00,6d,00,52,00,6f,00,6f,00,74,00,25,\
  35.   00,5c,00,53,00,79,00,73,00,74,00,65,00,6d,00,33,00,32,00,5c,00,4e,00,4f,00,\
  36.   54,00,45,00,50,00,41,00,44,00,2e,00,45,00,58,00,45,00,20,00,2f,00,70,00,20,\
  37.   00,25,00,31,00,00,00
  38. [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\batfile\shell\runas]
  39. "HasLUAShield"=""
  40. [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\batfile\shell\runas\command]
  41. @=hex(2):25,00,53,00,79,00,73,00,74,00,65,00,6d,00,52,00,6f,00,6f,00,74,00,25,\
  42.   00,5c,00,53,00,79,00,73,00,74,00,65,00,6d,00,33,00,32,00,5c,00,63,00,6d,00,\
  43.   64,00,2e,00,65,00,78,00,65,00,20,00,2f,00,43,00,20,00,22,00,25,00,31,00,22,\
  44.   00,20,00,25,00,2a,00,00,00
  45. [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\batfile\shell\runasuser]
  46. @="@shell32.dll,-50944"
  47. "Extended"=""
  48. "SuppressionPolicyEx"="{F211AA05-D4DF-4370-A2A0-9F19C09756A7}"
  49. [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\batfile\shell\runasuser\command]
  50. "DelegateExecute"="{ea72d00e-4960-42fa-ba92-7792a7944c1d}"
  51. [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\batfile\shellex]
  52. [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\batfile\shellex\-ContextMenuHandlers]
  53. [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\batfile\shellex\-ContextMenuHandlers\Compatibility]
  54. @="{1d27f844-3a1f-4410-85ac-14651078412d}"
  55. [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\batfile\shellex\ContextMenuHandlers]
  56. @="Compatibility"
  57. [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\batfile\shellex\ContextMenuHandlers\OpenGLShExt]
  58. @="{E97DEC16-A50D-49bb-AE24-CF682282E08D}"
  59. [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\batfile\shellex\DropHandler]
  60. @="{86C86720-42A0-1069-A2E8-08002B30309D}"
  61. [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\batfile\shellex\PropertySheetHandlers]
  62. [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\batfile\shellex\PropertySheetHandlers\ShimLayer Property Page]
  63. @="{513D916F-2A8E-4F51-AEAB-0CBC76FB1AF8}"
  64. [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\batfile\shellex\{8895b1c6-b41f-4c1c-a562-0d564250836f}]
  65. @="{1531d583-8375-4d3f-b5fb-d23bbd169f22}"
发表于 2022-6-7 12:11:54 来自手机 | 只看该作者
exe和bat都是注册表注册过的执行文件,你可以把exe的注册表拿来看看
发表于 2022-6-7 12:13:23 | 只看该作者
改扩展名pif试试?
或者搜一下cmd2exe、bat2exe
 楼主| 发表于 2022-6-7 12:16:10 | 只看该作者
qwerttaa 发表于 2022-6-7 12:13
改扩展名pif试试?
改拓展名没反应
 楼主| 发表于 2022-6-7 12:17:51 | 只看该作者
不会搞呢。。。
发表于 2022-6-7 13:46:32 来自手机 | 只看该作者
改后缀.com或者.exe试试,注册表动了手脚
发表于 2022-6-7 13:48:24 | 只看该作者
发表于 2022-6-7 13:58:47 | 只看该作者
改成.cmd后缀试试
 楼主| 发表于 2022-6-7 15:03:29 | 只看该作者
zxxx 发表于 2022-6-7 13:56
保存,导入试试
不成功,有提示有部分无法导入
GMT+8, 2026-4-25 12:44 , Processed in 0.068834 second(s), 11 queries , Gzip On, MemCache On.
