查看: 2637|回复: 12
vir大盘鸡开机咯
发表于 2022-6-5 07:19:55 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Your Storage Server is being installed...
Please wait up to 10 minutes for server setup to complete. Do not re-install, reboot, or reconfigure while setup is completing.
Important Notice:
While the disk amount if dedicated to you, disk operations and processing power need to fall within your fair share. Please ensure you run any commands in a way where you limit your operations. For example, you can use the --cpu-limit flag in your command in some cases to ensure you do not burst to extreme amounts for extended periods. Otherwise, if your service is using more processing power than allotted as a result of disk operations, especially when combined with extremely high level of disk operations for an extended period of time, you may cause a high load on the server and negatively affect others, in which case your service may be shut down or suspended.
发表于 2022-6-5 07:37:37 来自手机 | 只看该作者
续费时间变成7.4了
发表于 2022-6-5 07:28:25 | 只看该作者
我给你补张图
发表于 2022-6-5 07:42:21 | 只看该作者
签名站还能上车
https://stock.hostmonit.com/virSO
注意使用优惠码
发表于 2022-6-5 07:51:59 | 只看该作者
发表于 2022-6-5 09:53:59 | 只看该作者
HostMonit 发表于 2022-6-5 07:42
签名站还能上车
注意使用优惠码
你站里为啥没看到链接
 楼主| 发表于 2022-6-5 09:55:39 | 只看该作者
winday 发表于 2022-6-5 07:51
250G的日本开了,,给了两个IP ,另外续费时间到了2023年7月4日
建议传家
GMT+8, 2026-4-21 04:03 , Processed in 0.083264 second(s), 11 queries , Gzip On, MemCache On.
