查看: 2472|回复: 9
[疑问] zerotier ping telnet都不通,帮忙看看哪里有问题
发表于 2022-5-24 10:58:32 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
家里linuxdeploy安装的debian:
  1. root@localhost:/var/lib/zerotier-one# zerotier-cli info
  2. 200 info 61768610f2 1.8.10 ONLINE
  3. root@localhost:/var/lib/zerotier-one# zerotier-cli listpeers
  4. 200 listpeers <ztaddr> <path> <latency> <version> <role>
  5. 200 listpeers 62f865ae71 50.7.252.138/9993;11117;1020 64 - PLANET
  6. 200 listpeers 778cde7190 103.195.103.66/9993;11117;5876 247 - PLANET
  7. 200 listpeers b15644912e 34.133.52.206/21033;10109;10109 233 1.8.9 LEAF
  8. 200 listpeers cafe04eba9 84.17.53.155/9993;11117;885 197 - PLANET
  9. 200 listpeers cafe9efeb9 104.194.8.134/9993;11117;896 187 - PLANET
  10. 200 listpeers f43fe27f93 - -1 1.8.10 LEAF
  11. root@localhost:/var/lib/zerotier-one# ifconfig
  12. dummy0: flags=195<UP,BROADCAST,RUNNING,NOARP>  mtu 1500
  13.         inet6 fe80::93:edff:feeb:91d0  prefixlen 64  scopeid 0x20<link>
  14.         ether 02:93:ed:eb:91:d0  txqueuelen 1000  (Ethernet)
  15.         RX packets 0  bytes 0 (0.0 B)
  16.         RX errors 0  dropped 0  overruns 0  frame 0
  17.         TX packets 319  bytes 70198 (68.5 KiB)
  18.         TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
  19. lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
  20.         inet 127.0.0.1  netmask 255.0.0.0
  21.         inet6 ::1  prefixlen 128  scopeid 0x10<host>
  22.         loop  txqueuelen 1  (Local Loopback)
  23.         RX packets 4095  bytes 1110394 (1.0 MiB)
  24.         RX errors 0  dropped 0  overruns 0  frame 0
  25.         TX packets 4095  bytes 1110394 (1.0 MiB)
  26.         TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
  27. p2p0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
  28.         ether 02:0a:f5:78:ef:17  txqueuelen 3000  (Ethernet)
  29.         RX packets 0  bytes 0 (0.0 B)
  30.         RX errors 0  dropped 0  overruns 0  frame 0
  31.         TX packets 0  bytes 0 (0.0 B)
  32.         TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
  33. rmnet_ipa0: flags=65<UP,RUNNING>  mtu 2000
  34.         unspec 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00  txqueuelen 1000  (UNSPEC)
  35.         RX packets 0  bytes 0 (0.0 B)
  36.         RX errors 0  dropped 0  overruns 0  frame 0
  37.         TX packets 0  bytes 0 (0.0 B)
  38.         TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
  39. wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
  40.         inet 192.168.1.11  netmask 255.255.255.0  broadcast 192.168.1.255
  41.         inet6 fe80::20a:f5ff:fe78:ef17  prefixlen 64  scopeid 0x20<link>
  42.         ether 00:0a:f5:78:ef:17  txqueuelen 3000  (Ethernet)
  43.         RX packets 13741224  bytes 808675436 (771.2 MiB)
  44.         RX errors 0  dropped 0  overruns 0  frame 0
  45.         TX packets 1089217  bytes 281991968 (268.9 MiB)
  46.         TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
  47. zteb4ksdfm: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 2800
  48.         inet 192.168.111.1  netmask 255.255.255.0  broadcast 192.168.111.255
  49.         inet6 fe80::80fc:9bff:fea8:81b6  prefixlen 64  scopeid 0x20<link>
  50.         ether 82:fc:9b:a8:81:b6  txqueuelen 1000  (Ethernet)
  51.         RX packets 1193  bytes 265087 (258.8 KiB)
  52.         RX errors 0  dropped 0  overruns 0  frame 0
  53.         TX packets 65  bytes 10890 (10.6 KiB)
  54.         TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
  55. root@localhost:/var/lib/zerotier-one# ping 192.168.111.2
  56. PING 192.168.111.2 (192.168.111.2) 56(84) bytes of data.
  57. ^C
  58. --- 192.168.111.2 ping statistics ---
  59. 49 packets transmitted, 0 received, 100% packet loss, time 49907ms
公司的电脑:
  1. C:\Program Files (x86)\ZeroTier\One>zerotier-cli info
  2. 200 info f43fe27f93 1.8.10 ONLINE
  3. C:\Program Files (x86)\ZeroTier\One>zerotier-cli listpeers
  5. 200 listpeers 61768610f2 - -1 - MOON
  6. 200 listpeers 62f865ae71 50.7.252.138/9993;14;6016 -326 - PLANET
  7. 200 listpeers 778cde7190 103.195.103.66/9993;14;6188 -498 - PLANET
  8. 200 listpeers b15644912e 34.133.52.206/31801;6336;6336 578 1.8.9 LEAF
  9. 200 listpeers cafe04eba9 84.17.53.155/9993;14;6220 -530 - PLANET
  10. 200 listpeers cafe9efeb9 104.194.8.134/9993;14;6362 -1 - PLANET
  11. C:\Program Files (x86)\ZeroTier\One>ipconfig
  12. Windows IP 配置
  13. 以太网适配器 ZeroTier One [b15644912eed9d82]:
  14.    连接特定的 DNS 后缀 . . . . . . . :
  15.    本地链接 IPv6 地址. . . . . . . . : fe80::307a:cd61:c9c5:6795%72
  16.    IPv4 地址 . . . . . . . . . . . . : 192.168.111.2
  17.    子网掩码  . . . . . . . . . . . . : 255.255.255.0
  18.    默认网关. . . . . . . . . . . . . : 192.168.111.1
  19.                                        25.255.255.254
  20. 无线局域网适配器 WLAN:
  21.    连接特定的 DNS 后缀 . . . . . . . :
  22.    本地链接 IPv6 地址. . . . . . . . : fe80::31ff:79a6:7a10:1d03%26
  23.    IPv4 地址 . . . . . . . . . . . . : 192.168.4.161
  24.    子网掩码  . . . . . . . . . . . . : 255.255.255.0
  25.    默认网关. . . . . . . . . . . . . : 192.168.4.1
  26. C:\Program Files (x86)\ZeroTier\One>ping 192.168.111.1
  27. 正在 Ping 192.168.111.1 具有 32 字节的数据:
  28. 请求超时。
  29. 请求超时。
  30. 请求超时。
  31. 请求超时。
  32. 192.168.111.1 的 Ping 统计信息:
  33.     数据包: 已发送 = 4,已接收 = 0,丢失 = 4 (100% 丢失),
  34. C:\Program Files (x86)\ZeroTier\One>
my.zerotier.com:
 楼主| 发表于 2022-5-24 11:17:10 | 只看该作者
发现一个mjj @ZeroOne
发表于 2022-5-24 11:22:24 | 只看该作者
看起来都连上了,延迟都看到了。试试防火墙或路由表?
 楼主| 发表于 2022-5-24 11:28:10 | 只看该作者
延迟都看到了? 在哪,不是丢包吗,路由器防火墙关了
 楼主| 发表于 2022-5-24 11:32:37 | 只看该作者
debian的防火墙也删了:
rm -f /etc/iptables/rules.v4
rm -f /etc/iptables/rules.v6
发表于 2022-5-24 11:33:31 来自手机 | 只看该作者
有没有fullcone
发表于 2022-5-24 11:43:33 | 只看该作者
这个latency是578ms吧。linux格式和这个不一样,但只有能直连才会显示ip,经过moon或planet都不显示的。
其实我也不知道乱猜的。。
 楼主| 发表于 2022-5-24 11:44:26 | 只看该作者
是这些吗
发表于 2022-5-24 11:44:28 | 只看该作者
我用tailscale
 楼主| 发表于 2022-5-24 12:02:33 | 只看该作者
200 listpeers
200 listpeers b15644 ...
b15644912e 这个设备不知道是哪个 linux是 61768610f2 ,同时也是 moon,windows是 f43fe27f93
GMT+8, 2026-4-19 06:57 , Processed in 0.065962 second(s), 10 queries , Gzip On, MemCache On.
