查看: 1210|回复: 4
[疑问] cyberpanel使用官方的数据库优化命令进行优化后面版直接500
发表于 2022-5-20 11:23:29 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
cyberpanel使用官方的数据库优化命令进行优化后面版直接500,手动改回又可以用了,请问是什么原因?
优化后报错
** (pkttyagent:1941): WARNING **: 23:16:56.677: Unable to register authentication agent: GDBus.Errorrg.freedesktop.PolicyKit1.Error.Failed: Cannot determine user of subject
Error registering authentication agent: GDBus.Errorrg.freedesktop.PolicyKit1.Error.Failed: Cannot determine user of subject (polkit-error-quark, 0)
Job for mariadb.service failed because the control process exited with error code. See "systemctl status mariadb.service" and "journalctl -xe" for details.
手工改回后
** (pkttyagent:21000): WARNING **: 23:19:17.473: Unable to register authentication agent: GDBus.Errorrg.freedesktop.PolicyKit1.Error.Failed: Cannot determine user of subject
谁帮忙看看怎么解决,谢谢
发表于 2022-5-20 11:30:18 | 只看该作者
使用命令
  1. groupadd -g 23 nohidproc
  2. usermod -a -G nohidproc polkitd
  3. mount -o remount,rw,hidepid=2,gid=nohidproc /proc
  4. systemctl restart polkit
 楼主| 发表于 2022-5-20 11:53:18 | 只看该作者
不行,还是500,输完命令后
** (pkttyagent:22743): WARNING **: 23:47:29.050: Unable to register authentication agent: GDBus.Errorrg.freedesktop.PolicyKit1.Error.Failed: Cannot determine user of subject
用service mysqld restart,重启数据库
Redirecting to /bin/systemctl restart mysqld.service
cyberpanel 真难用- -
 楼主| 发表于 2022-5-20 11:55:18 | 只看该作者
官方提供的优化数据
[mysqld]
# GENERAL #
user                           = mysql
default-storage-engine         = InnoDB
#socket                         = /var/lib/mysql/mysql.sock
#pid-file                       = /var/lib/mysql/mysqld.pid
# MyISAM #
# key-buffer-size                = 32M
# myisam-recover                 = FORCE,BACKUP
# SAFETY #
max-allowed-packet             = 16M
max-connect-errors             = 1000000
sql-mode                       = NO_ENGINE_SUBSTITUTION,NO_AUTO_CREATE_USER
sysdate-is-now                 = 1
innodb-strict-mode             = 1
# DATA STORAGE #
datadir                        = /var/lib/mysql
# SERVER ID #
server-id                      = 677161
# CACHES AND LIMITS #
max-connections                = 500
tmp-table-size                 = 32M
max-heap-table-size            = 32M
query-cache-type               = 0
query-cache-size               = 0
thread-cache-size              = 50
open-files-limit               = 65535
table-definition-cache         = 1024
table-open-cache               = 2048
# INNODB #
innodb-flush-method            = O_DIRECT
innodb-log-files-in-group      = 2
innodb-log-file-size           = 128M
innodb-flush-log-at-trx-commit = 1
innodb-file-per-table          = 1
innodb-buffer-pool-size        = 1228M
# LOGGING #
log-error                      = /var/lib/mysql/mysqld.log
slow-query-log                 = 1
slow-query-log-file            = /var/lib/mysql/mysqld-slow.log
log-queries-not-using-indexes  = OFF
long_query_time                = 30
[mysqldump]
!includedir /etc/mysql/conf.d/
!includedir /etc/mysql/mariadb.conf.d/
 楼主| 发表于 2022-5-20 11:57:34 | 只看该作者
原始的数据
# This group is read both by the client and the server
# use it for options that affect everything
[client-server]
# include *.cnf from the config directory
!includedir /etc/my.cnf.d
GMT+8, 2026-5-1 21:24 , Processed in 0.080302 second(s), 10 queries , Gzip On, MemCache On.
