查看: 2241|回复: 19
关于discuz 大板块伪静态问题,谁懂
发表于 2012-1-15 16:52:29 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
DZ论坛早已坠落了。
回答的都是啥的,还是loc技术人多··谁懂啊,?
还有如何将Apache的伪静态代码转换成WINNT iis的。
发表于 2012-1-15 16:55:55 | 只看该作者
【IIS Web Server(独立主机用户)】
[ISAPI_Rewrite]
# 3600 = 1 hour
CacheClockRate 3600
RepeatLimit 32
# Protect httpd.ini and httpd.parse.errors files
# from accessing through HTTP
RewriteRule ^(.*)/topic-(.+)\.html(\?(.*))*$ $1/portal\.php\?mod=topic&topic=$2&$4
RewriteRule ^(.*)/article-([0-9]+)-([0-9]+)\.html(\?(.*))*$ $1/portal\.php\?mod=view&aid=$2&page=$3&$5
RewriteRule ^(.*)/forum-(\w+)-([0-9]+)\.html(\?(.*))*$ $1/forum\.php\?mod=forumdisplay&fid=$2&page=$3&$5
RewriteRule ^(.*)/thread-([0-9]+)-([0-9]+)-([0-9]+)\.html(\?(.*))*$ $1/forum\.php\?mod=viewthread&tid=$2&extra=page\%3D$4&page=$3&$6
RewriteRule ^(.*)/group-([0-9]+)-([0-9]+)\.html(\?(.*))*$ $1/forum\.php\?mod=group&fid=$2&page=$3&$5
RewriteRule ^(.*)/space-(username|uid)-(.+)\.html(\?(.*))*$ $1/home\.php\?mod=space&$2=$3&$5
RewriteRule ^(.*)/blog-([0-9]+)-([0-9]+)\.html(\?(.*))*$ $1/home\.php\?mod=space&uid=$2&do=blog&id=$3&$5
RewriteRule ^(.*)/(fid|tid)-([0-9]+)\.html(\?(.*))*$ $1/index\.php\?action=$2&value=$3&$5
发表于 2012-1-15 16:56:39 | 只看该作者
晕死  他们官方就有
发表于 2012-1-15 16:56:45 | 只看该作者
【IIS7 Web Server(独立主机用户)】
<rewrite>
        <rules>
                <rule name="portal_topic">
                        <match url="^(.*/)*topic-(.+).html\?*(.*)$" />
                        <action type="Rewrite" url="{R:1}/portal.php\?mod=topic&amp;topic={R:2}&amp;{R:3}" />
                </rule>
                <rule name="portal_article">
                        <match url="^(.*/)*article-([0-9]+)-([0-9]+).html\?*(.*)$" />
                        <action type="Rewrite" url="{R:1}/portal.php\?mod=view&amp;aid={R:2}&amp;page={R:3}&amp;{R:4}" />
                </rule>
                <rule name="forum_forumdisplay">
                        <match url="^(.*/)*forum-(\w+)-([0-9]+).html\?*(.*)$" />
                        <action type="Rewrite" url="{R:1}/forum.php\?mod=forumdisplay&amp;fid={R:2}&amp;page={R:3}&amp;{R:4}" />
                </rule>
                <rule name="forum_viewthread">
                        <match url="^(.*/)*thread-([0-9]+)-([0-9]+)-([0-9]+).html\?*(.*)$" />
                        <action type="Rewrite" url="{R:1}/forum.php\?mod=viewthread&amp;tid={R:2}&amp;extra=page%3D{R:4}&amp;page={R:3}&amp;{R:5}" />
                </rule>
                <rule name="group_group">
                        <match url="^(.*/)*group-([0-9]+)-([0-9]+).html\?*(.*)$" />
                        <action type="Rewrite" url="{R:1}/forum.php\?mod=group&amp;fid={R:2}&amp;page={R:3}&amp;{R:4}" />
                </rule>
                <rule name="home_space">
                        <match url="^(.*/)*space-(username|uid)-(.+).html\?*(.*)$" />
                        <action type="Rewrite" url="{R:1}/home.php\?mod=space&amp;{R:2}={R:3}&amp;{R:4}" />
                </rule>
                <rule name="home_blog">
                        <match url="^(.*/)*blog-([0-9]+)-([0-9]+).html\?*(.*)$" />
                        <action type="Rewrite" url="{R:1}/home.php\?mod=space&amp;uid={R:2}&amp;do=blog&amp;id={R:3}&amp;{R:4}" />
                </rule>
                <rule name="forum_archiver">
                        <match url="^(.*/)*(fid|tid)-([0-9]+).html\?*(.*)$" />
                        <action type="Rewrite" url="{R:1}/index.php\?action={R:2}&amp;value={R:3}&amp;{R:4}" />
                </rule>
        </rules>
</rewrite>
Zeus Web Server
match URL into $ with ^(.*)/topic-(.+)\.html\?*(.*)$
if matched then
        set URL = $1/portal.php?mod=topic&topic=$2&$3
endif
match URL into $ with ^(.*)/article-([0-9]+)-([0-9]+)\.html\?*(.*)$
if matched then
        set URL = $1/portal.php?mod=view&aid=$2&page=$3&$4
endif
match URL into $ with ^(.*)/forum-(\w+)-([0-9]+)\.html\?*(.*)$
if matched then
        set URL = $1/forum.php?mod=forumdisplay&fid=$2&page=$3&$4
endif
match URL into $ with ^(.*)/thread-([0-9]+)-([0-9]+)-([0-9]+)\.html\?*(.*)$
if matched then
        set URL = $1/forum.php?mod=viewthread&tid=$2&extra=page\%3D$4&page=$3&$5
endif
match URL into $ with ^(.*)/group-([0-9]+)-([0-9]+)\.html\?*(.*)$
if matched then
        set URL = $1/forum.php?mod=group&fid=$2&page=$3&$4
endif
match URL into $ with ^(.*)/space-(username|uid)-(.+)\.html\?*(.*)$
if matched then
        set URL = $1/home.php?mod=space&$2=$3&$4
endif
match URL into $ with ^(.*)/blog-([0-9]+)-([0-9]+)\.html\?*(.*)$
if matched then
        set URL = $1/home.php?mod=space&uid=$2&do=blog&id=$3&$4
endif
match URL into $ with ^(.*)/(fid|tid)-([0-9]+)\.html\?*(.*)$
if matched then
        set URL = $1/index.php?action=$2&value=$3&$4
endif
顶楼上
发表于 2012-1-15 16:56:50 | 只看该作者
发表于 2012-1-15 16:57:06 | 只看该作者
找Helicon 3.1的破解版,可以支持htaccess
发表于 2012-1-15 16:59:06 | 只看该作者
随便度娘下
发表于 2012-1-15 17:02:40 | 只看该作者
X2后台可以看到伪静态规则的。
 楼主| 发表于 2012-1-15 17:04:52 | 只看该作者
别给官方的,垃圾,很多不完善的。
GMT+8, 2026-4-15 02:25 , Processed in 0.127267 second(s), 12 queries , Gzip On, MemCache On.
