查看: 3906|回复: 11
[Windows VPS] 狗爹给我发来这样一份邮件,我该怎么办 急
发表于 2012-1-15 15:13:15 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
ear Sir/Madam,
Regarding your hosting account XXXXXX.com:
The zcxybbs.com web site has been found to be hosting malicious content which is a violation of section 3 "Your Obligations" of Go Daddy's Web Hosting and Virtual Dedicated Hosting Service Agreement.
The relevant passage of this agreement has been provided below:
"You may not use Go Daddy's servers and Your web site as a source, intermediary, reply to address, or destination address for mail bombs, Internet packet flooding, packet corruption, denial of service, or other abusive activities. Server hacking or other perpetration of security breaches is prohibited and Go Daddy reserves the right to remove sites containing information about hacking or links to such information."
Go Daddy's "Web Hosting and Virtual Dedicated Hosting Service Agreement" is located at the following URL: https://www.godaddy.com/agreements/showdoc.aspx?pageid=HOSTING_SA
This situation has resulted in a potential security threat to Go Daddy's network and the security we provide to other customers. It appears that this abusive action may have been the result of your server becoming compromised and ultimately exploited by a third party. Upon detection of this problem Go Daddy's Security Operations Center requested that Go Daddy's Advanced Hosting Team alert you of this action in the hope that you can resolve the issue.
*** IMPORTANT ***
Due to the serious nature of this malicious action, your site is scheduled to be suspended if you do not take immediate action. This suspension will take place on January 18, 2012 and will occur if either a repeat occurrence of the abuse is, at any time, detected OR you fail to reply to this message.
Go Daddy's security team has collected the following information to assist you in troubleshooting this issue:
A recent virus scan of your hosting account found and removed a malicious file from your hosting account. Please scan your local work station for virus, trojan, and malware content prior to uploading any additional content.
This matter can be closed by simply responding to this notice with the following:
1. A statement that you have reviewed and agree to abide by the terms of the "Web Hosting and Virtual Dedicated Hosting Service Agreement," and
2. A statement that you have removed any malicious content residing on your web site, and
3. A statement that you agree to secure your web site in such a way as to ensure that there is not a re-occurrence of this issue in the future.
After we receive your reply with these statements we consider the matter resolved and continue to monitor the situation. (We reserve the right to suspend the site again if a repeat occurrence of this security violation is discovered.)
If you have questions about this matter, you may contact us by replying to this email or by calling 480-505-8871.
We appreciate your cooperation in this matter.
Hosting Support Team
发表于 2012-1-15 15:14:27 | 只看该作者
给他回一封
发表于 2012-1-15 15:15:05 | 只看该作者
你的空间放恶意内容,请尽快回复解析,否则账号没了
发表于 2012-1-15 15:15:29 | 只看该作者
  1. zcxybbs.com网站已经发现被托管恶意内容
发表于 2012-1-15 15:25:18 | 只看该作者
你不采取行动的话,你的小jj(呃 你的网站)就会被suspended,1月18号是你的死期
想活命的话交出这三样东西
发表于 2012-1-15 15:28:48 | 只看该作者
bearqq 发表于 2012-1-15 15:25
Due to the serious nature of this malicious action, your site is scheduled to be suspended if you d ...
18..........
参与人数 1威望 +1 收起 理由
bearqq + 1 哼哼
发表于 2012-1-15 16:26:20 来自手机 | 只看该作者
gd的vps有违禁内容?
发表于 2012-1-15 16:26:49 | 只看该作者
耳先生/女士, 您的托管帐户XXXXXX.com: zcxybbs.com网站已经发现被托管恶意内容,这是违反第3条 “ 你的义务“转到爸爸的网站托管和虚拟专用托管服务协议, 在本协议有关的通道已被提供的下面: “你可能不使用前往爸爸的服务器和你的网站作为源,中介,答复解决的,或目的地邮件炸弹,网络包淹没,包**,拒绝服务,或其他虐待活动的地址。服务器犯下的安全漏洞黑客或其他被禁止的,转到爸爸有权删除包含黑客行为或链接到这些信息的相关信息的网站。 “ 好爸爸的“虚拟主机和虚拟专用托管服务协议”是在位于以下网址:https://www.godaddy.com/agreements/showdoc.aspx?pageid=HOSTING_SA 这种情况导致一个潜在的安全威胁,去爸爸的网络和我们提供给其他客户的安全。看来这一违规行为的妥协,最终由第三方利用您的服务器成为的结果可能已经 。当检测到这个问题转到爸爸的安全运营中心的要求,转到爸爸的高级托管团队提醒,希望你的这个动作,你可以解决这个 问题。*** 重要***由于这种恶意行动的性质严重, 网站预定暂停,如果你不立即采取行动。将于2012年1月18日,这种悬挂的地方,会发生,如果重复发生的滥用,在任何时候,检测或您无法回覆此邮件 。 ************* *** 转到爸爸的安全团队已经收集了以下信息,以协助您解决此问题: 您的托管帐户的一个最新的病毒扫描,发现并清除恶意文件从您的托管帐户。请扫描您的本地工作站的病毒,木马,和恶意软件内容上传任何附加内容 之前。\ vpsbackup \ uc_server \ DATA \ TMP \ upload17785.gif这件事可以通过简单的响应与本通知 以下的 封闭 :1。一个已审阅并同意遵守“虚拟主机和虚拟主机租用服务协议的条款”,并声明 2。一个已居住在您的网站,并删除任何恶意内容 的声明 3。 后,我们收到你的答复,我们认为解决这一问题,并继续监察这些陈述的一份声明表示您同意这样一种方式,以确保不存在这个问题在未来的再次发生,以确保在您的网站。 情况。(我们保留再次暂停该网站的权利,如果违反此安全重复发生发现。 )如果您有关于此事的问题,您可以通过回复此邮件或致电480-505-8871 联系我们,我们对此表示赞赏您在这个问题上的合作 。主机支援队
发表于 2012-1-15 16:29:59 | 只看该作者
?  什么?
发表于 2012-1-15 16:42:07 | 只看该作者
赶紧扫描一下你的VPS,把恶意文件删了,不然你就要惨了
GMT+8, 2026-4-15 06:02 , Processed in 0.208316 second(s), 17 queries , Gzip On, MemCache On.
