查看: 1007|回复: 1
哪个MJJ的VirMach机器开好了
发表于 2022-4-22 16:07:40 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
邮件发到我这里了,应该是之前买我VirMach的MJJ,没改邮箱。看到去把邮箱改了,不改我能通过邮箱重置控制面板密码随时操控你的鸡鸡哦
Linux Setup Guide
Your server can  be accessed via SSH; we recommend PuTTy. Unless you selected an operating system labeled as (Desktop) then the version of Linux does not come with a desktop environment or VNC pre-installed. This means you will only have access to the text-only version of the operating system.
Your IP is: 147.78.247.**
Your Username is: root
Your Password is: tRpgeZX6r43F0T****
Please CHANGE the password once you have successfully logged in.
Linux Setup Guide
Your IP is: 45.66.128.***
Your Password is: a0jcSG3t82SXjt****
来自vps.org.cn
 楼主| 发表于 2022-4-22 16:20:50 | 只看该作者
卧槽,是做大业务的呀,开了7台了
来自vps.org.cn
GMT+8, 2026-4-16 15:58 , Processed in 0.062607 second(s), 10 queries , Gzip On, MemCache On.
