查看: 14323|回复: 140
vir10.2 瞬间香了起来
发表于 2022-4-14 10:12:44 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
免费迁移美滋滋
  jp你们上
正在跑分 等下放个对比图
之前的帖子:https://loc.qiche.eu.org/thread-896530-1-1.html
迁移之后,忘记选保留数据了,少了个IP
  1. Processor  : AMD EPYC-Rome Processor
  2. CPU cores  : 2 @ 3799.998 MHz
  3. AES-NI     : ✔ Enabled
  4. VM-x/AMD-V : ❌ Disabled
  5. RAM        : 1.9 GiB
  6. Swap       : 256.0 MiB
  7. Disk       : 39.1 GiB
  8. fio Disk Speed Tests (Mixed R/W 50/50):
  9. ---------------------------------
  10. Block Size | 4k            (IOPS) | 64k           (IOPS)
  11.   ------   | ---            ----  | ----           ----
  12. Read       | 342.27 MB/s  (85.5k) | 117.86 MB/s   (1.8k)
  13. Write      | 343.17 MB/s  (85.7k) | 118.48 MB/s   (1.8k)
  14. Total      | 685.45 MB/s (171.3k) | 236.35 MB/s   (3.6k)
  15.            |                      |
  16. Block Size | 512k          (IOPS) | 1m            (IOPS)
  17.   ------   | ---            ----  | ----           ----
  18. Read       | 531.58 MB/s   (1.0k) | 776.71 MB/s    (758)
  19. Write      | 559.82 MB/s   (1.0k) | 828.44 MB/s    (809)
  20. Total      | 1.09 GB/s     (2.1k) | 1.60 GB/s     (1.5k)
  21. iperf3 Network Speed Tests (IPv4):
  23. Provider        | Location (Link)           | Send Speed      | Recv Speed
  24.                 |                           |                 |
  25. Clouvider       | London, UK (10G)          | 265 Mbits/sec   | 260 Mbits/sec
  26. Online.net      | Paris, FR (10G)           | 244 Mbits/sec   | 250 Mbits/sec
  27. WorldStream     | The Netherlands (10G)     | 261 Mbits/sec   | 179 Mbits/sec
  28. WebHorizon      | Singapore (400M)          | 139 Mbits/sec   | 408 Mbits/sec
  29. Clouvider       | NYC, NY, US (10G)         | 894 Mbits/sec   | 576 Mbits/sec
  30. Velocity Online | Tallahassee, FL, US (10G) | 558 Mbits/sec   | 440 Mbits/sec
  31. Clouvider       | Los Angeles, CA, US (10G) | 556 Mbits/sec   | 839 Mbits/sec
  32. Iveloz Telecom  | Sao Paulo, BR (2G)        | busy            | busy
  33. Geekbench 5 Benchmark Test:
  34. ---------------------------------
  35. Test            | Value
  36.                 |
  37. Single Core     |
  38. Multi Core      |
  39. Full Test       | https://browser.geekbench.com/v5/cpu/14301705
来自 79#
 楼主| 发表于 2022-4-14 13:34:13 | 只看该作者
迁移成功是有邮件通知的
建议选择星号的机房,想要秒迁移就选不保留数据。
JP机房就不用想了,洗洗睡吧 ,vir老板连预售的机子都没整明白呢,现在35节点延迟130+,玩个der。。。。
  1. Please visit your control panel to install an operating system.
  2. Linux Setup Guide (After you install an OS)
  3. Your server can  be accessed via SSH; we recommend PuTTy. Unless you selected an operating system labeled as (Desktop) then the version of Linux does not come with a desktop environment or VNC pre-installed. This means you will only have access to the text-only version of the operating system.
  4. Your IP is: xxx.xxx.xxx
  5. Your Username is: root
  6. Your Password is: Will be provided once you install an operating system.
  7. Please CHANGE the password once you have successfully logged in.
  8. Advanced Control Panel
  9. Your VPS controls are available on your service details page. Here you can reboot your VPS, re-install your operating system, and more. If you require advanced direct access to your full SolusVM control panel, you may click the "Control Panel" button on your service details page. You will automatically be logged in to your control panel. If you would like to access your control panel independently, you can use the direct link. Your username is "xxxx" and you must reset your password to obtain it.
  10. Billing
  11. Your service is set to renew 年繳 and your next invoice will be generated  Your next due date is on 09/21/2022 and if you have an automatic payment method on file, by default we will attempt to bill you (3) days before your next due date.  Your next bill amount will be $10.20 USD. Your store credit balance is $0.00 USD and will by default be automatically applied to your invoice as soon as the next invoice is generated.
  12. Support
  13. To contact us regarding your service, please create a support ticket.
  14. Virtual Machine Solutions LLC
  15. Support Team
  16. Please DO NOT reply to this e-mail. Use our ticket system directly.
发表于 2022-4-14 14:10:51 | 只看该作者
笑花落半世琉璃 发表于 2022-4-14 14:03
我的就是啊  最前面不是贴yabs数据,你看那网络比起SJ弱爆了
我还以为你的也是sj,我上面有发sj的yabs
sj的网络也不行,电信中午都有10%+丢包
发表于 2022-4-14 12:59:10 | 只看该作者
点了迁移。好像没有反应。多了个IP,节点没变,给的IP不通。原系统正常使用。
这是还是还没迁移吗?
 楼主| 发表于 2022-4-14 10:41:13 | 只看该作者
vir老板内心os : 这个我在行 迁移jp的全部打上mjj标签
发表于 2022-4-14 10:13:20 | 只看该作者
给的IP PING不能啊。
 楼主| 发表于 2022-4-14 10:14:09 | 只看该作者
aipage 发表于 2022-4-14 10:13
给的IP PING不能啊。
那就不知道了 我没迁移jp  太鸡儿能折腾了  等你们折腾完再过去
发表于 2022-4-14 10:14:47 | 只看该作者
点了迁移。好像没有反应。
 楼主| 发表于 2022-4-14 10:16:23 | 只看该作者
hxuf 发表于 2022-4-14 10:14
点了迁移。好像没有反应。
你看看ip变没变
发表于 2022-4-14 10:17:00 来自手机 | 只看该作者
不香,水牛城可以迁移东京,全线封神
发表于 2022-4-14 10:18:06 | 只看该作者
好像全部机型都能迁移..
发表于 2022-4-14 10:18:38 | 只看该作者
多了个附加IP。实际并没有迁移。
发表于 2022-4-14 10:19:13 | 只看该作者
我la的都可以迁移啊
 楼主| 发表于 2022-4-14 10:19:58 | 只看该作者
madegehaol1 发表于 2022-4-14 10:19
我la的都可以迁移啊
应该是全部都可以吧 反正不想去jp了 天天炸
GMT+8, 2026-5-2 03:08 , Processed in 0.072361 second(s), 12 queries , Gzip On, MemCache On.
