查看: 1614|回复: 8
dearroy,进来下
发表于 2012-1-8 18:58:38 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
dearroy 发表于 2012-1-8 06:36
我问过了,好像会进行抽查,必须是欧盟成员国公民才能申请,如果提供的vat等信息是假的,还有可能收回域名 ...
Although known as a country-code TLD, .BE is actually wide open for registration, with no local or any special restrictions to owning .BE domains. No matter which country you are from or in which country you currently reside - you can register your .BE domain for a personal or commercial website without any hassle.
请问你在哪咨询得到的答案?
发表于 2012-1-8 18:59:18 | 只看该作者
不是我
发表于 2012-1-8 18:59:45 | 只看该作者
大概沒有問題吧, 我註冊US域名都是填垃圾資料
用了兩年也沒有問題
結果在market賣回給美國人
发表于 2012-1-8 18:59:53 | 只看该作者
关注下
发表于 2012-1-8 19:05:02 | 只看该作者
发表于 2012-1-8 19:06:37 | 只看该作者
关注
发表于 2012-1-8 19:35:59 | 只看该作者
发表于 2012-1-8 20:11:09 | 只看该作者
抱歉,我只是说的.it和.pm等等,并没有注意到.be。
我又去找他们家问了下。得到的答复是这样的
can Asian register?
Robert Miller20:00:30
Nope
it is open to individuals residing or corporations having their head office in the territory of one of the Member States f the  EuropeanUnion
Afnic the .re and .pm .it registry, will be performing eligibility validation on random basis or if they receive complaints. When they initiate the validation process the registrant has 30 days to provide profs the whois details are accurate. If not provided in 30 days the domain will be suspended and the registrant still has another 30 days to provide those profs. If not provided Afnic will delete the domain at the end of those 30 days
这里就是说会抽查,如果不提供正确的欧盟成员国信息,就要在30天内暂停,而且再过30天,注册商不提供注册证明,就要删除。。。
发表于 2012-1-8 20:17:10 | 只看该作者
看来就是不能注册, 就象 .us 一样,只允许美国公民注册
参与人数 1威望 +20 收起 理由
Kokgog + 20 us倒是风险不大............
GMT+8, 2026-4-15 03:58 , Processed in 0.114892 second(s), 13 queries , Gzip On, MemCache On.
