12
返回列表 发新帖
楼主: koukouwu.com
[疑问] 请删除此帖子
发表于 2012-1-8 17:05:45 | 只看该作者
楼主的CPANEL是ROOT 的?可以自己 更改?
 楼主| 发表于 2012-1-8 17:17:33 | 只看该作者
yes
可以更改
还可以编译apache
Please choose specific options:
Apache Built-in Modules
Options in this color are enabled by default in Apache. That means that you won't see anything added to Apache's configure line unless it is unchecked.
        Asis [More Info ↑]
        Auth Digest [More Info ↑]
        AuthnAlias [More Info ↑]
        AuthnAnon [More Info ↑]
        AuthnDBD [More Info ↑]
        AuthnDBM [More Info ↑]
        AuthnDefault [More Info ↑]
        AuthnzLDAP [More Info ↑]
        AuthzDBM [More Info ↑]
        AuthzOwner [More Info ↑]
        Bucketeer
        Cache [More Info ↑]
        CaseFilter
        CaseFilterIn
        Cern Meta [More Info ↑]
        Charset Lite [More Info ↑]
        DAVFs [More Info ↑]
        DAVLock [More Info ↑]
        DBD [More Info ↑]
        Dav [More Info ↑]
        Among other things mod_dav can be used by DAV enabled Frontpage clients instead of FP extensions
        Deflate [More Info ↑]
        Disk Cache [More Info ↑]
        Distcache [More Info ↑]
        Dumpio [More Info ↑]
        Echo [More Info ↑]
        Env [More Info ↑]
        Expires [More Info ↑]
        ExtFilter [More Info ↑]
        Mod FCGID [More Info ↑]
        fastcgi support
        File Cache [More Info ↑]
        Fileprotect
        Prevent Users from reading other webroots
        Frontpage [More Info ↑]
        Headers [More Info ↑]
        Ident [More Info ↑]
        Imagemap [More Info ↑]
        LDAP [More Info ↑]
        Log Forensic [More Info ↑]
        MPM Event [More Info ↑]
        PHP may not be run as an Apache DSO (mod_php) while this MPM is in use
        MPM Prefork [More Info ↑]
        (recommended)
        MPM Worker [More Info ↑]
        MemCache [More Info ↑]
        Mime Magic [More Info ↑]
        Optional Fn Export
        Optional Fn Import
        OptionalHookExport
        Optional Hook Import
        Mod SuPHP [More Info ↑]
        This option will make the following changes to your profile prior to the build:
Enables:
  CGI (PHP v4)
  CGI (PHP v5)
        Proxy [More Info ↑]
        required for cPanel/WHM/Webmail/Webdisk proxy VirtualHost support
        Speling [More Info ↑]
        UniqueId [More Info ↑]
        Usertrack [More Info ↑]
        Version [More Info ↑]
        Vhost Alias [More Info ↑]
Back to top
Other Modules
        EAccelerator for PHP [More Info ↑]
        v0.9.6.1 - caches compiled PHP pages ONLY when running in a persistent (DSO/FCGID) manner
        IonCube Loader for PHP [More Info ↑]
        4.0.9 - please read documentation that can found by clicking "More Info" to fully understand this option
        Mod Bandwidth [More Info ↑]
        v2.1 for Apache 1.3, v0.92 for Apache 2.x - see documentation that can found by clicking "More Info" for details
        Tomcat [More Info ↑]
        v5.5.34 - Experts ONLY: Do not install this unless you have a tomcat admin.
        Mod Mono (.Net 1.x) [More Info ↑]
        v2.6.3 - Experts ONLY: Do not install this unless you have a mono admin This option will make the following changes to your profile prior to the build:
Disables:
  Mod Mono (.Net 2.x)
        Mod Mono (.Net 2.x) [More Info ↑]
        Not currently compatible with mod_mono .Net 1.x support, one will be dropped This option will make the following changes to your profile prior to the build:
Disables:
  Mod Mono (.Net 1.x)
        Mod Perl [More Info ↑]
        v2.0.5 - not needed to run CGI scripts
        Mod Qos [More Info ↑]
        See documentation at http://mod-qos.sourceforge.net/
        Mod Security [More Info ↑]
        v1.9.5 for Apache 1.3, v2.5.13 for Apache 2.0.x, v2.6.2 for Apache 2.2.x This option will make the following changes to your profile prior to the build:
Enables:
  UniqueId
        Suhosin for PHP [More Info ↑]
        v0.9.32.1 - please read documentation that can found by clicking "More Info" to fully understand this option
        SourceGuardian Loader for PHP [More Info ↑]
        8.2 - please read documentation that can found by clicking "More Info" to fully understand this option
        Xcache for PHP [More Info ↑]
        Please see http://xcache.lighttpd.net for info about this option
        Zend Optimizer/Guard Loader for PHP [More Info ↑]
        3.3.9 - please read documentation that can found by clicking "More Info" to fully understand this option
By choosing this option you are signifying agreement and compliance with the license at http://static.zend.com/topics/guard-license-agreement.txt. If you do not agree to those terms you must not choose this option.
Back to top
PHP 5.2.17 (Be sure to "harden" your PHP since PHP has many security issues)
For more information about PHP configuration, capabilities, and limitations please see http://www.php.net.
Options in this color are enabled by default in php 5.2.17. That means that you won't see anything added to php's configure line unless it is unchecked.
        Bcmath [More Info ↑]
        Bz2 [More Info ↑]
        CGI [More Info ↑]
        Calendar [More Info ↑]
        Concurrent DSO patch [More Info ↑]
        Allows PHP 4 and 5 to load simultaneously as Apache modules (not compatible with Zend optimizer and some extensions) This option will make the following changes to your profile prior to the build:
Disables:
  PDO
  PDO MySQL
        Curl [More Info ↑]
        CurlSSL [More Info ↑]
        Curlwrappers [More Info ↑]
        Dbase [More Info ↑]
        Discard Path
        when running PHP as CGI you should disable this (or will be prompted to do so)
        Exif [More Info ↑]
        Expat [More Info ↑]
        You may need this to address http://bugs.php.net/bug.php?id=45996 for PHP 5.2.8 and older
        FTP [More Info ↑]
        Fastcgi
Enables:
  Mod FCGID
  CGI
Disables:
  Discard Path
        Force CGI Redirect [More Info ↑]
        GD [More Info ↑]
Enables:
  Zlib
        Gettext [More Info ↑]
        Iconv [More Info ↑]
        Support iconv character set conversion facility
        Imap [More Info ↑]
        MM [More Info ↑]
        Magic Quotes [More Info ↑]
        MailHeaders [More Info ↑]
        Mbregex
        Mbstring [More Info ↑]
        Mcrypt [More Info ↑]
        Mhash [More Info ↑]
        Ming [More Info ↑]
        (Not Recommended due to various problems) using ming library 0.4.2
        Mysql [More Info ↑]
        compile MySQL support using the PHP bundled libraries (if the System MySQL option is checked it takes precedence over this option)
        Mysql of the system [More Info ↑]
        compile mysql (and mysqli if its checked) support against the system libraries
        MySQL "Improved" extension. [More Info ↑]
        MySQLi does not replace the standard MySQL extension. Requires MySQL 4.1 or later. !! mysqli may not work on all systems, contact your support provider for mysqli support !!
        Openssl [More Info ↑]
        PDO [More Info ↑]
        Includes SQLite support. MySQL support is available. If you plan on installing or updating PDO drivers (freetds, oracle, etc) via PECL you might want to skip this option as PECL will install the version of PDO it has. This option will make the following changes to your profile prior to the build:
Enables:
  SQLite3
        PDO MySQL [More Info ↑]
Enables:
  PDO
        POSIX [More Info ↑]
        Path Info Check
        Pear [More Info ↑]
        PGsql [More Info ↑]
        Requires PostgreSQL 7.3 or higher to already be installed. You can do that with /scripts/installpostgres
        Pspell [More Info ↑]
        SNMP [More Info ↑]
        Requires the SNMP Dev libraries to be installed first!!!
        SOAP [More Info ↑]
        SafeMode [More Info ↑]
        Safe PHP CGI
        prevents users from overriding system php.ini
        Sockets [More Info ↑]
        TTF (FreeType) [More Info ↑]
        Tidy [More Info ↑]
        Wddx [More Info ↑]
        XSL [More Info ↑]
        XmlRPC [More Info ↑]
        Zend Multibyte
        Zip [More Info ↑]
        Zlib [More Info ↑]
        Requires that zlib is installed and up to date
        Save my profile with appropriate PHP 5 options set so that it is compatible with cpphp
Enables:
  CurlSSL
  FTP
  GD
  Gettext
  Iconv
  Imap
  Mbregex
  Mbstring
  Mysql
  Mysql of the system
  PGsql
  Sockets
  Zlib
Back to top
Preferences
        Reset Apache Config to default - any customizations will be lost (this session only)
        Always do latest PHP (forces newest minor version of any major versions chosen) This takes precedence over "Always do oldest PHP".
        Only apply "Always do latest PHP" if PHP in profile is no longer available
        Always do oldest PHP (forces oldest minor version of any major versions chosen) This only applies if "Always do latest PHP" is not active.
        Only apply "Always do oldest PHP" if PHP in profile is no longer available
        Archive Backup (this session only)
        Report Errors to cPanel
        If httpd.conf generation fails or apache can not be restarted after conf generation, leave build in-place so I can manually resolve httpd.conf issues.
        After each "post restart" test check that apache is still running
        If tests fail that would normally revert the build, leave the build in-place so I can manually resolve any issues.
        When there are problems with local templates and the default templates are tried, move the local one to a .broken extension.
发表于 2012-1-8 17:21:14 | 只看该作者
建议用cgi
有守护的fastcgi才比cgi强。
在cpanel中,cgi是传统的cgi
发表于 2012-1-8 17:41:27 | 只看该作者
GMT+8, 2026-4-29 20:31 , Processed in 0.062485 second(s), 8 queries , Gzip On, MemCache On.
