123
返回列表 发新帖
楼主: 炒土豆丝
[疑问] Docker 安装出错求救!!!
发表于 2022-4-3 03:55:57 | 只看该作者
google一下
scheme "unix" not registered, fallback to default scheme  module=grpc
很多都是在讲这个,应该总有一个适合你
22#
 楼主| 发表于 2022-4-3 03:57:00 | 只看该作者
xayle 发表于 2022-4-3 03:24
https://forums.docker.com/t/failing-to-start-dockerd-failed-to-create-nat-chain-docker/78269
转换 ...
转换后少报了一条错误
  1. WARN[2022-04-02T15:56:11.074450966-04:00] Running modprobe bridge br_netfilter failed with message: modprobe: ERROR: could not insert 'bridge': Key was rejected by service
  2. modprobe: ERROR: could not insert 'br_netfilter': Key was rejected by service
  3. insmod /lib/modules/5.10.0-10-amd64/kernel/net/bridge/bridge.ko
  4. insmod /lib/modules/5.10.0-10-amd64/kernel/net/bridge/bridge.ko
  5. , error: exit status 1
  6. INFO[2022-04-02T15:56:11.090697944-04:00] Default bridge (docker0) is assigned with an IP address 172.17.0.0/16. Daemon option --bip can be used to set a preferred IP address
  7. failed to start daemon: Error initializing network controller: Error creating default "bridge" network: package not installed
23#
发表于 2022-4-3 04:02:59 | 只看该作者
炒土豆丝 发表于 2022-4-3 03:57
转换后少报了一条错误
报错信息 bridge 模块 key 被拒绝, 不能加载.
看下下 新装的几个 都是
  1. 4B:6E:F5:AB:CA:66:98:25:17:8E:05:2C:84:66:7C:CB:C0:53:1F:8C
modinfo bridge
执行上面的命令 看下 签名 key
24#
发表于 2022-4-3 04:05:11 | 只看该作者
uname -a
看下你的系统内核版本
25#
 楼主| 发表于 2022-4-3 04:06:16 | 只看该作者
Linux Tokyo768 5.10.0-10-amd64 #1 SMP Debian 5.10.84-1 (2021-12-08) x86_64 GNU/Linux
  1. filename:       /lib/modules/5.10.0-10-amd64/kernel/net/bridge/bridge.ko
  2. alias:          rtnl-link-bridge
  3. version:        2.3
  4. license:        GPL
  5. srcversion:     5E154AB40AC717603A73F15
  6. depends:        stp,llc
  7. retpoline:      Y
  8. intree:         Y
  9. name:           bridge
  10. vermagic:       5.10.0-10-amd64 SMP mod_unload modversions
  11. sig_id:         PKCS#7
  12. signer:         Debian Secure Boot CA
  13. sig_key:        4B:6E:F5:AB:CA:66:98:25:17:8E:05:2C:84:66:7C:CB:C0:53:1F:8C
  14. sig_hashalgo:   sha256
  15. signature:      22:F3:30:FC:CA:92:92:B4:FD:40:01:9C:88:39:32:C9:29:99:32:E9:
  16.                 15:0A:FC:1E:8C:EE:DA:46:51:73:21:F0:8E:21:D6:56:FF:1B:79:B9:
  17.                 99:D5:AB:26:E3:32:12:EC:79:DF:11:61:77:F1:96:AF:D2:56:44:81:
  18.                 75:D5:7F:A7:FE:39:57:FA:35:3B:D7:17:5C:22:BA:E2:E3:62:1C:BA:
  19.                 EA:01:54:28:FB:9D:36:92:B8:08:EB:00:DF:F2:03:CE:6B:6A:5E:FC:
  20.                 BF:8B:EF:D8:0F:8C:C5:C0:51:45:26:5D:21:E9:E4:23:33:21:A8:57:
  21.                 30:96:FF:0B:CE:76:F9:4A:AC:CA:E0:8C:48:32:97:A1:60:94:49:B5:
  22.                 79:69:A4:23:F5:DD:D7:CF:9C:D9:1D:B3:50:6B:F1:7C:73:8D:A6:6B:
  23.                 A1:04:75:D2:E3:7C:21:89:FA:DA:0F:AB:0F:32:0E:79:A9:46:07:03:
  24.                 C3:5E:2A:AD:B5:53:43:52:64:AF:9F:88:4B:C6:B3:57:8D:69:9A:A4:
  25.                 E0:52:4A:E4:85:BC:4D:F0:5B:A5:34:D5:FA:4F:94:E8:00:B5:74:18:
  26.                 37:21:55:70:0F:38:A3:1F:C2:E2:CD:08:5D:41:7B:5E:A4:8F:43:D7:
  27.                 4B:CA:E9:9D:44:7A:04:7A:29:12:23:12:D5:71:6B:A5
  28. root@Tokyo768:~#
26#
发表于 2022-4-3 13:31:23 来自手机 | 只看该作者
dd了重新安装还省事一些。
27#
发表于 2022-4-3 13:33:48 | 只看该作者
vir debain模板有问题,我DD过的debain11apt安装没问题
28#
 楼主| 发表于 2022-4-3 13:50:07 | 只看该作者
我试过 DD 直接失联了,老哥用哪个脚本DD的?
29#
发表于 2022-4-3 15:20:41 | 只看该作者
bash <(wget --no-check-certificate -qO- 'https://moeclub.org/attachment/LinuxShell/InstallNET.sh') -d 11 -v 64 -a -firmware -p 自定义密码 这个是直接dd debain11不过还是要进vnc手动设置一些东西
30#
发表于 2022-4-3 15:24:32 | 只看该作者
DD, 解决docker安装问题,用萌卡大佬的脚本,期间可能会offline,去面板重启就行了,可能会offline几次,看vnc掉了就去重启
GMT+8, 2026-4-16 10:57 , Processed in 0.065777 second(s), 9 queries , Gzip On, MemCache On.
