楼主: jil
[Windows VPS] 幻觉:骨骼加,开张了,不用翻了?
发表于 2011-12-26 14:08:05 | 只看该作者
浙江电信,不行
发表于 2011-12-26 14:08:29 | 只看该作者
无法连接
发表于 2011-12-26 14:12:31 | 只看该作者
Google
404. That’s an error.
在此服务器上找不到请求的网址。 That’s all we know.
发表于 2011-12-26 14:13:18 | 只看该作者
打不开
发表于 2011-12-26 15:26:09 | 只看该作者
联通可以看到她甜甜的微笑了
发表于 2011-12-26 15:27:35 | 只看该作者
我靠,可以打开了!
电信
发表于 2011-12-26 15:29:54 | 只看该作者
载入页面时到服务器的连接被重置
发表于 2011-12-26 15:32:51 | 只看该作者
This webpage is not available
The connection to plus.google.com was interrupted.
Here are some suggestions:
Reload this webpage later.
Check your Internet connection. Restart any router, modem, or other network devices you may be using.
Add Google Chrome as a permitted program in your firewall's or antivirus software's settings. If it is already a permitted program, try deleting it from the list of permitted programs and adding it again.
If you use a proxy server, check your proxy settings or contact your network administrator to make sure the proxy server is working. If you don't believe you should be using a proxy server, adjust your proxy settings: Go to the wrench menu > Options > Under the Hood > Change proxy settings... > LAN Settings and deselect the "Use a proxy server for your LAN" checkbox.
Error 101 (net::ERR_CONNECTION_RESET): The connection was reset.
 楼主| 发表于 2011-12-26 15:34:49 | 只看该作者
推荐,先登录邮箱,然后再点,左上的+
20#
发表于 2011-12-26 17:48:19 | 只看该作者
浙江电信 可以打开  估计是高墙抽风
GMT+8, 2026-4-30 01:14 , Processed in 0.061958 second(s), 9 queries , Gzip On, MemCache On.
