[经验] 【教程】腾讯云新春企业888券最佳作业方案及新用户最优解
发表于 2022-1-28 23:47:54 来自手机 | 只看该作者
32安全下车,感谢
83#
 楼主| 发表于 2022-1-29 00:57:31 | 只看该作者
(如何完成888券最佳作业方案-32车其余地域方案)
此处衔接主帖没写完的部分,因为文本限制长度。部分香港地区32方案已经被撸爆了,那么我们可以考虑下新加坡或者别的地区方案,有个别MJJ所需要硅谷东京的干脆全部整出来。
请参考主帖信息和51楼补充的信息结合在看此楼层补充的信息。同理别的价位你可以自己依葫芦画瓢
操作流程:
先购买一个32地域的鸡1个月即可。然后对其进行续费需要留意这些参数。
https://curl.qcloud.com/qRvC92Y2
记录小鸡代号参数,修改timespan后面的数值
https://tencentcloud.pages.dev/
再次进入网页这里输入下面的信息务必把 "lhins-这里请修改成你小鸡的代号" 双引号内中文改成上面你记录的编号
这一串中文全部改成对应的数值按照上面提示的走” 的信息改成数值“105” “211” “620” 使用掉ABC券
新加坡
  1. {"raw_goodsData": [{"goodsCategoryId": 1024708,"goodsNum": 1,"payMode": 1,"regionId": 9,"goodsDetail": {"productCode": "p_lighthouse","subProductCode": "sp_lighthouse_bundle2022_gen_lin_01","pid": 1012949,"sv_lighthouse_compute_gen_lin_med2_1024": 1,"sv_lighthouse_rootdisk_gen_lin_med2_1024": 1,"sv_lighthouse_trafficpkg_gen_lin_med2_1024": 1,"productInfo": [{"name": "运算组件","value": "2核CPU、2GB内存 (通用型Linux-2核2G-30G-1T)"},{"name": "系统盘","value": "30GB SSD云硬盘 (通用型Linux-2核2G-30G-1T)"},{"name": "流量包","value": "1TB/月流量包 (通用型Linux-2核2G-30G-1T)"},{"name": "地域","value": "新加坡"}],"resourceId": "lhins-这里请修改成你小鸡的代号","autoRenewFlag": 0,"timeUnit": "d","timeSpan": 这一串中文全部改成对应的数值按照上面提示的走2}}]}
东京
  1. {"raw_goodsData": [{"goodsCategoryId": 1024708,"goodsNum": 1,"payMode": 1,"regionId": 25,"goodsDetail": {"productCode": "p_lighthouse","subProductCode": "sp_lighthouse_bundle2022_gen_lin_01","pid": 1012949,"sv_lighthouse_compute_gen_lin_med2_1024": 1,"sv_lighthouse_rootdisk_gen_lin_med2_1024": 1,"sv_lighthouse_trafficpkg_gen_lin_med2_1024": 1,"productInfo": [{"name": "运算组件","value": "2核CPU、2GB内存 (通用型Linux-2核2G-30G-1T)"},{"name": "系统盘","value": "30GB SSD云硬盘 (通用型Linux-2核2G-30G-1T)"},{"name": "流量包","value": "1TB/月流量包 (通用型Linux-2核2G-30G-1T)"},{"name": "地域","value": "东京"}],"resourceId": "lhins-这里请修改成你小鸡的代号","autoRenewFlag": 0,"timeUnit": "d","timeSpan": 这一串中文全部改成对应的数值按照上面提示的走}}]}
硅谷
  1. {"raw_goodsData": [{"goodsCategoryId": 1024708,"goodsNum": 1,"payMode": 1,"regionId": 15,"goodsDetail": {"productCode": "p_lighthouse","subProductCode": "sp_lighthouse_bundle2022_gen_lin_01","pid": 1012949,"sv_lighthouse_compute_gen_lin_med2_1024": 1,"sv_lighthouse_rootdisk_gen_lin_med2_1024": 1,"sv_lighthouse_trafficpkg_gen_lin_med2_1024": 1,"productInfo": [{"name": "运算组件","value": "2核CPU、2GB内存 (通用型Linux-2核2G-30G-1T)"},{"name": "系统盘","value": "30GB SSD云硬盘 (通用型Linux-2核2G-30G-1T)"},{"name": "流量包","value": "1TB/月流量包 (通用型Linux-2核2G-30G-1T)"},{"name": "地域","value": "硅谷"}],"resourceId": "lhins-这里请修改成你小鸡的代号","autoRenewFlag": 0,"timeUnit": "d","timeSpan": 这一串中文全部改成对应的数值按照上面提示的走}}]}
莫斯科
  1. {"raw_goodsData": [{"goodsCategoryId": 1024708,"goodsNum": 1,"payMode": 1,"regionId": 24,"goodsDetail": {"productCode": "p_lighthouse","subProductCode": "sp_lighthouse_bundle2022_gen_lin_01","pid": 1012949,"sv_lighthouse_compute_gen_lin_med2_1024": 1,"sv_lighthouse_rootdisk_gen_lin_med2_1024": 1,"sv_lighthouse_trafficpkg_gen_lin_med2_1024": 1,"productInfo": [{"name": "运算组件","value": "2核CPU、2GB内存 (通用型Linux-2核2G-30G-1T)"},{"name": "系统盘","value": "30GB SSD云硬盘 (通用型Linux-2核2G-30G-1T)"},{"name": "流量包","value": "1TB/月流量包 (通用型Linux-2核2G-30G-1T)"},{"name": "地域","value": "莫斯科"}],"resourceId": "lhins-这里请修改成你小鸡的代号","autoRenewFlag": 0,"timeUnit": "d","timeSpan": 这一串中文全部改成对应的数值按照上面提示的走}}]}
法兰克福
  1. {"raw_goodsData": [{"goodsCategoryId": 1024708,"goodsNum": 1,"payMode": 1,"regionId": 17,"goodsDetail": {"productCode": "p_lighthouse","subProductCode": "sp_lighthouse_bundle2022_gen_lin_01","pid": 1012949,"sv_lighthouse_compute_gen_lin_med2_1024": 1,"sv_lighthouse_rootdisk_gen_lin_med2_1024": 1,"sv_lighthouse_trafficpkg_gen_lin_med2_1024": 1,"productInfo": [{"name": "运算组件","value": "2核CPU、2GB内存 (通用型Linux-2核2G-30G-1T)"},{"name": "系统盘","value": "30GB SSD云硬盘 (通用型Linux-2核2G-30G-1T)"},{"name": "流量包","value": "1TB/月流量包 (通用型Linux-2核2G-30G-1T)"},{"name": "地域","value": "法兰克福"}],"resourceId": "lhins-这里请修改成你小鸡的代号","autoRenewFlag": 0,"timeUnit": "d","timeSpan": 这一串中文全部改成对应的数值按照上面提示的走}}]}
孟买
  1. {"raw_goodsData": [{"goodsCategoryId": 1024708,"goodsNum": 1,"payMode": 1,"regionId": 21,"goodsDetail": {"productCode": "p_lighthouse","subProductCode": "sp_lighthouse_bundle2022_gen_lin_01","pid": 1012949,"sv_lighthouse_compute_gen_lin_med2_1024": 1,"sv_lighthouse_rootdisk_gen_lin_med2_1024": 1,"sv_lighthouse_trafficpkg_gen_lin_med2_1024": 1,"productInfo": [{"name": "运算组件","value": "2核CPU、2GB内存 (通用型Linux-2核2G-30G-1T)"},{"name": "系统盘","value": "30GB SSD云硬盘 (通用型Linux-2核2G-30G-1T)"},{"name": "流量包","value": "1TB/月流量包 (通用型Linux-2核2G-30G-1T)"},{"name": "地域","value": "孟买"}],"resourceId": "lhins-这里请修改成你小鸡的代号","autoRenewFlag": 0,"timeUnit": "d","timeSpan": 这一串中文全部改成对应的数值按照上面提示的走}}]}
84#
 楼主| 发表于 2022-1-29 01:00:13 | 只看该作者
更新除了HK以外的32方案车位
85#
 楼主| 发表于 2022-1-29 01:08:12 | 只看该作者
3gW7d7jizJS 发表于 2022-1-28 23:01
楼主还有没 34的 硅谷代码啊?
给个号我我就有
86#
发表于 2022-1-29 01:44:38 | 只看该作者
我没号,我昨晚是帮同事弄的,没成功,我就没管了。然后他自己去买了42的,不过谢谢大佬回复。
87#
 楼主| 发表于 2022-1-29 02:07:29 | 只看该作者
3gW7d7jizJS 发表于 2022-1-29 01:44
我没号,我昨晚是帮同事弄的,没成功,我就没管了。然后他自己去买了42的,不过谢谢大佬回复。 ...
我刚才测试了下34已经断货,和24一样。预计腾讯云内鬼已经干掉了
88#
发表于 2022-1-29 11:13:04 | 只看该作者
大佬 打不开了
89#
 楼主| 发表于 2022-1-29 13:27:28 | 只看该作者
不存在
90#
发表于 2022-1-29 13:28:58 | 只看该作者
GMT+8, 2026-4-27 11:34 , Processed in 0.067043 second(s), 8 queries , Gzip On, MemCache On.
