12
返回列表 发新帖
楼主: ouxmm
[Windows VPS] 请假mjj,香港vps看netflix,却走的德国法兰克福cdn
 楼主| 发表于 2021-9-30 19:34:44 | 只看该作者
xqdoo00o 发表于 2021-9-30 19:27
那阿里云上运行命令 traceroute ipv4-c047-hkg001-ix.1.oca.nflxvideo.net
发下结果看看
再发下命令 bash ...
这个cdn是没有问题的,ping延时1、2ms,下面是截图
traceroute:
ping:
流媒体检测:
好像图有点小,上文本吧:
流媒体检测:
** 正在测试IPv4解锁情况
** 您的网络为: Alibaba
Dazn:                                        No
HotStar:                                Yes (Region: SG)
Disney+:                                Yes (Region: SG)
Netflix:                                Yes (Region: SG)
有图比 Premium:                        Yes (Region: HK)
Amazon Prime Video:                        Yes (Region: SG)
TVBAnywhere+:                                No
Tiktok Region:                                HK (IDC IP Detected)
iQyi Oversea Region:                        HK
Viu.com:                                Yes (Region: HK)
有图比 CDN:                                Hong Kong
Netflix Preferred CDN:                        Hong Kong
Steam Currency:                        HKD
==============[ Taiwan ]===============
KKTV:                                        No
LiTV:                                        No
4GTV.TV:                                No
LineTV.TW:                                No
Hami Video:                                No
CatchPlay+:                                No
HBO GO Asia:                                Yes (Region: HK)
Bahamut Anime:                                No
Eleven Sports TW:                        No
Bilibili Taiwan Only:                        No
=============[ Hong Kong ]=============
Now E:                                        Yes
Viu.TV:                                Yes
MyTVSuper:                                No
BiliBili Hongkong/Macau/Taiwan:        Yes
traceroute 的反馈:
traceroute to ipv4-c047-hkg001-ix.1.oca.nflxvideo.net (23.246.57.152), 30 hops max, 60 byte packets
1  10.247.210.42 (10.247.210.42)  1.485 ms 10.247.209.42 (10.247.209.42)  1.404 ms  1.362 ms
2  * * *
3  10.36.51.161 (10.36.51.161)  1.488 ms 10.36.51.185 (10.36.51.185)  1.479 ms 10.36.51.129 (10.36.51.129)  1.906 ms
4  47.246.116.62 (47.246.116.62)  3.019 ms 47.246.116.54 (47.246.116.54)  1.709 ms  1.688 ms
5  116.251.86.190 (116.251.86.190)  9.485 ms 47.246.115.106 (47.246.115.106)  1.885 ms 47.246.115.98 (47.246.115.98)  1.869 ms
6  103.203.158.75 (103.203.158.75)  2.313 ms  1.703 ms 2906.hkg.equinix.com (36.255.56.111)  1.911 ms
7  * * *
8  * * *
9  * * *
10  * * *
11  * * *
12  * * *
13  * * *
14  * * *
15  * * *
16  * * *
17  * * *
18  * * *
19  * * *
20  * * *
21  * * *
22  * * *
23  * * *
24  * * *
25  * * *
26  * * *
27  * * *
28  * * *
29  * * *
30  * * *
ping:
root@iZj6c3mlglm387q2njsit9Z:~# ping ipv4-c047-hkg001-ix.1.oca.nflxvideo.net
PING ipv4-c047-hkg001-ix.1.oca.nflxvideo.net (23.246.57.152) 56(84) bytes of data.
64 bytes from ipv4-c047-hkg001-ix.1.oca.nflxvideo.net (23.246.57.152): icmp_seq=1 ttl=58 time=2.24 ms
64 bytes from ipv4-c047-hkg001-ix.1.oca.nflxvideo.net (23.246.57.152): icmp_seq=2 ttl=58 time=2.45 ms
64 bytes from ipv4-c047-hkg001-ix.1.oca.nflxvideo.net (23.246.57.152): icmp_seq=3 ttl=58 time=1.79 ms
64 bytes from ipv4-c047-hkg001-ix.1.oca.nflxvideo.net (23.246.57.152): icmp_seq=4 ttl=58 time=1.79 ms
64 bytes from ipv4-c047-hkg001-ix.1.oca.nflxvideo.net (23.246.57.152): icmp_seq=5 ttl=58 time=1.79 ms
64 bytes from ipv4-c047-hkg001-ix.1.oca.nflxvideo.net (23.246.57.152): icmp_seq=6 ttl=58 time=1.79 ms
64 bytes from ipv4-c047-hkg001-ix.1.oca.nflxvideo.net (23.246.57.152): icmp_seq=7 ttl=58 time=1.78 ms
64 bytes from ipv4-c047-hkg001-ix.1.oca.nflxvideo.net (23.246.57.152): icmp_seq=8 ttl=58 time=1.78 ms
64 bytes from ipv4-c047-hkg001-ix.1.oca.nflxvideo.net (23.246.57.152): icmp_seq=9 ttl=58 time=1.79 ms
64 bytes from ipv4-c047-hkg001-ix.1.oca.nflxvideo.net (23.246.57.152): icmp_seq=10 ttl=58 time=1.80 ms
64 bytes from ipv4-c047-hkg001-ix.1.oca.nflxvideo.net (23.246.57.152): icmp_seq=11 ttl=58 time=1.80 ms
64 bytes from ipv4-c047-hkg001-ix.1.oca.nflxvideo.net (23.246.57.152): icmp_seq=12 ttl=58 time=1.77 ms
64 bytes from ipv4-c047-hkg001-ix.1.oca.nflxvideo.net (23.246.57.152): icmp_seq=13 ttl=58 time=1.78 ms
64 bytes from ipv4-c047-hkg001-ix.1.oca.nflxvideo.net (23.246.57.152): icmp_seq=14 ttl=58 time=2.27 ms
64 bytes from ipv4-c047-hkg001-ix.1.oca.nflxvideo.net (23.246.57.152): icmp_seq=15 ttl=58 time=1.97 ms
64 bytes from ipv4-c047-hkg001-ix.1.oca.nflxvideo.net (23.246.57.152): icmp_seq=16 ttl=58 time=2.03 ms
发表于 2021-9-30 19:42:02 | 只看该作者
traceroute:
那就不应该了,netflix cdn显示hk 应该走hkcdn啊。
 楼主| 发表于 2021-9-30 19:47:34 | 只看该作者
是的,我也很奇怪,但确实是这样。
同样的netflix账号,只要切换到hkcmi,就能正常,走的是hk本地cdn。
排查过程中我也试过,从阿里云香港和hkcmi分别ping **flix.com,得到的ip是一样的。
说明两台服务器访问的是同一台奈非服务器,但奈非服务器却区别对待,一个给我香港本地cdn,一个给我德国cdn。
所以有点怀疑是不是奈非的IP库更新了,认为阿里云香港的ip是欧盟地区的
GMT+8, 2026-4-30 11:26 , Processed in 0.066163 second(s), 9 queries , Gzip On, MemCache On.
