[Windows VPS] 求个cf workers反代代码
发表于 2021-6-24 16:32:20 | 只看该作者
我也网上找的
// Website you intended to retrieve for users.
const upstream = 'xxx.com'
// Custom pathname for the upstream website.
const upstream_path = '/'
// Website you intended to retrieve for users using mobile devices.
const upstream_mobile = 'xxx.com'
// Countries and regions where you wish to suspend your service.
const blocked_region = []
// IP addresses which you wish to block from using your service.
const blocked_ip_address = ['0.0.0.0', '127.0.0.1']
// Whether to disable cache.
const disable_cache = false
// Replace texts.
const replace_dict = {
    '$upstream': '$custom_domain',
    '//share.iridium.cyou': 'frqkm.iri.workers.dev'
addEventListener('fetch', event => {
    event.respondWith(fetchAndApply(event.request));
async function fetchAndApply(request) {
    const region = request.headers.get('cf-ipcountry').toUpperCase();
    const ip_address = request.headers.get('cf-connecting-ip');
    const user_agent = request.headers.get('user-agent');
    let response = null;
    let url = new URL(request.url);
    let url_hostname = url.hostname;
    url.protocol = 'https:';
    if (await device_status(user_agent)) {
        var upstream_domain = upstream;
    } else {
        var upstream_domain = upstream_mobile;
    url.host = upstream_domain;
    if (url.pathname == '/') {
        url.pathname = upstream_path;
    } else {
        url.pathname = upstream_path + url.pathname;
    if (blocked_region.includes(region)) {
        response = new Response('Access denied: WorkersProxy is not available in your region yet.', {
            status: 403
    } else if (blocked_ip_address.includes(ip_address)) {
        response = new Response('Access denied: Your IP address is blocked by WorkersProxy.', {
            status: 403
    } else {
        let method = request.method;
        let request_headers = request.headers;
        let new_request_headers = new Headers(request_headers);
        new_request_headers.set('Host', upstream_domain);
        new_request_headers.set('Referer', url.protocol + '//' + url_hostname);
        let original_response = await fetch(url.href, {
            method: method,
            headers: new_request_headers
        connection_upgrade = new_request_headers.get("Upgrade");
        if (connection_upgrade && connection_upgrade.toLowerCase() == "websocket") {
            return original_response;
        let original_response_clone = original_response.clone();
        let original_text = null;
        let response_headers = original_response.headers;
        let new_response_headers = new Headers(response_headers);
        let status = original_response.status;
                if (disable_cache) {
                        new_response_headers.set('Cache-Control', 'no-store');
        new_response_headers.set('access-control-allow-origin', '*');
        new_response_headers.set('access-control-allow-credentials', true);
        new_response_headers.delete('content-security-policy');
        new_response_headers.delete('content-security-policy-report-only');
        new_response_headers.delete('clear-site-data');
                if (new_response_headers.get("x-pjax-url")) {
            new_response_headers.set("x-pjax-url", response_headers.get("x-pjax-url").replace("//" + upstream_domain, "//" + url_hostname));
        const content_type = new_response_headers.get('content-type');
        if (content_type != null && content_type.includes('text/html') && content_type.includes('UTF-8')) {
            original_text = await replace_response_text(original_response_clone, upstream_domain, url_hostname);
        } else {
            original_text = original_response_clone.body
        response = new Response(original_text, {
            status,
            headers: new_response_headers
    return response;
async function replace_response_text(response, upstream_domain, host_name) {
    let text = await response.text()
    var i, j;
    for (i in replace_dict) {
        j = replace_dict[i]
        if (i == '$upstream') {
            i = upstream_domain
        } else if (i == '$custom_domain') {
            i = host_name
        if (j == '$upstream') {
            j = upstream_domain
        } else if (j == '$custom_domain') {
            j = host_name
        let re = new RegExp(i, 'g')
        text = text.replace(re, j);
    return text;
async function device_status(user_agent_info) {
    var agents = ["Android", "iPhone", "SymbianOS", "Windows Phone", "iPad", "iPod"];
    var flag = true;
    for (var v = 0; v < agents.length; v++) {
        if (user_agent_info.indexOf(agents[v]) > 0) {
            flag = false;
            break;
    return flag;
 楼主| 发表于 2021-6-24 16:53:44 | 只看该作者
iridium 发表于 2021-6-24 16:32
我也网上找的
老哥,你不能照搬啊,用这个反代这个项目的heroku域名会有问题
比如使用搜索引擎的时候,翻页会出错
发表于 2021-6-24 16:54:33 | 只看该作者
很早之前看到有个大佬的,一直很好用
演示:https://cloudflareworkers.com/#12a9195720fe4ed660949efdbd9c0219:https://www.google.com/
代码:
  1. addEventListener('fetch', event => {
  2.   event.respondWith(handleRequest(event.request))
  3. })
  4. /**
  5. * Fetch and log a given request object
  6. * @param {Request} request
  7. */
  8. async function handleRequest(request) {
  9.   console.log('Got request', request)
  10.   const response = await fetch(request)
  11.   console.log('Got response', response)
  12.   return response
  13. }
 楼主| 发表于 2021-6-24 17:19:35 | 只看该作者
du-sh 发表于 2021-6-24 16:54
很早之前看到有个大佬的,一直很好用
演示:https://cloudflareworkers.com/#12a9195720fe4ed660949efdbd9c ...
这个怎么自己部署啊?
发表于 2021-6-24 17:22:11 | 只看该作者
叫我ams就好了 发表于 2021-6-24 17:19
这个怎么自己部署啊?
我没研究过CFworkers,你研究下他的,大概思路人家已经实现了,谷歌下相关资料,应该也有官方教程
 楼主| 发表于 2021-6-24 17:36:35 | 只看该作者
du-sh 发表于 2021-6-24 17:22
我没研究过CFworkers,你研究下他的,大概思路人家已经实现了,谷歌下相关资料,应该也有官方教程 ...
这个是官方的实例程序啊
有其他基于这个做的反代,比如楼上老哥发的那段,但是反代我这个heroku域名用不了
不知道是不是**作不对
发表于 2021-6-24 21:45:17 | 只看该作者
测试一下 https://*.workers.dev/
 楼主| 发表于 2021-6-25 03:37:20 | 只看该作者
Reverie 发表于 2021-6-24 21:45
测试一下 https://name-herokuapp-com.f-zxx.workers.dev/
不太行啊
发表于 2021-6-25 14:34:16 | 只看该作者
https://name.herokuapp.com/ 直接访问也是这提示
20#
 楼主| 发表于 2021-6-25 15:08:47 | 只看该作者
这个name要改成自己heroku应用的名字,意思是你直接反代了?
GMT+8, 2026-4-22 18:08 , Processed in 0.062179 second(s), 9 queries , Gzip On, MemCache On.
