楼主: qiqi13245
[经验] 比VNC更稳定 更快 nomachine NX安装教程(心得)
发表于 2010-1-11 20:19:30 | 只看该作者
安装Node出错,什么原因,错误如下
#rpm -ivh nxnode-3.4.0-6.x86_64.rpm
error: Failed dependencies:
        lsof is needed by nxnode-3.4.0-6.x86_64
32#
 楼主| 发表于 2010-1-11 20:22:07 | 只看该作者
是64的
33#
发表于 2010-1-11 20:24:43 | 只看该作者
是的,Client顺利安装,安装Node出错
34#
发表于 2010-1-11 20:43:34 | 只看该作者
回复 31# 的帖子
需要 lsof
35#
发表于 2010-1-11 20:50:53 | 只看该作者
谢谢老大了,原来需要安装LSOF
36#
 楼主| 发表于 2010-1-11 20:53:24 | 只看该作者
以来问题
37#
 楼主| 发表于 2010-1-11 20:53:31 | 只看该作者
说错了依赖
38#
发表于 2010-1-11 21:49:52 | 只看该作者
安装NXSERVER也有问题
#rpm -ivh nxserver-3.4.0-8.x86_64.rpm
Preparing...                ########################################### [100%]
   1:nxserver               ########################################### [100%]
NX> 700 Installing: server at: Mon Jan 11 12:51:01 2010.
NX> 700 Autodetected system: redhat.
NX> 700 Install log is: /usr/NX/var/log/install.
NX> 700 Creating configuration file: /usr/NX/etc/server.cfg.
NX> 723 Cannot start NX statistics:
NX> 709 NX statistics are disabled for this server.
NX> 700 WARNING: Error when trying to connect to NX server, error is:
NX> 700 WARNING: Warning: Permanently added '127.0.0.1' (RSA) to the list of kno.n hosts.
NX> 700 WARNING: nxsetup cannot validate the sanity of the current installation:
NX> 700 WARNING: the current system or NX configuration could be broken.
NX> 700 WARNING: If difficulties arise (for example sessions cannot be started),
NX> 700 WARNING: it is advisable that you try to uninstall the NX server and the
NX> 700 WARNING: NX client packages then install them again.
NX> 700 WARNING: Search also the NoMachine Knowledge Base at the URL below:
NX> 700 WARNING: http://www.nomachine.com/kb
NX> 700 WARNING: for common errors encountered when performing a software update
NX> 700 WARNING: and the related hints on how to solve them..
39#
发表于 2010-1-11 21:52:18 | 只看该作者
  好像vnc 比較多人用
GMT+8, 2026-1-2 15:47 , Processed in 0.103313 second(s), 9 queries , Gzip On, MemCache On.
