楼主: lzdszdl
刚刚那个自建网易的套用解锁灰色【更新方法】
发表于 2020-12-19 01:14:46 | 只看该作者
注释了第四行就报错诶
  1. ERROR  Failed to compile with 1 errors        1:11:16 AM
  2. error  in ./src/store/actions.js
  3. Module Error (from ./node_modules/eslint-loader/index.js):
  4. /root/YesPlayMusic/src/store/actions.js
  5.   71:25  error  'updateHttps' is not defined  no-undef
  6. ✖ 1 problem (1 error, 0 warnings)
  7. [url=home.php?mod=space&uid=175]@[/url] ./src/store/index.js 10:0-32 40:11-18
  8. @ ./src/main.js
  9. @ multi ./src/main.js
  10. ERROR  Build failed with errors.
  11. error Command failed with exit code 1.
  12. info Visit https://yarnpkg.com/en/docs/cli/run for documentation about this command.
忘了一行 不好意思  发表于 2020-12-19 14:50
22#
发表于 2020-12-19 08:00:21 | 只看该作者
坐等一个docker
23#
 楼主| 发表于 2020-12-19 14:51:48 | 只看该作者
修了一个bug
24#
发表于 2020-12-19 16:24:08 | 只看该作者
还是有问题,比如搜索周杰伦,然后点周杰伦的名字,页面会空白,然后NeteaseCloudMusicApi会报参数错误
而且116行下的unblockSongUrl = getMP3(track.id);  后边应该为逗号
  1. server running @ http://localhost:3000
  2. (node:2616) Warning: Setting the NODE_TLS_REJECT_UNAUTHORIZED environment variable to '0' makes TLS connections and HTTPS requests insecure by disabling certificate verification.
  3. (Use `node --trace-warnings ...` to show where the warning was created)
  4. [ERR] /user/playlist?timestamp=1608366296548&limit=1000 { status: 400, body: { msg: '参数错误', code: 400, message: '参数错误' } }
  5. [OK] /scrobble?id=428203719&sourceid=34841412&time=180&timestamp=1608366296663
  6. [OK] /search?keywords=周杰伦&type=1004
  7. [OK] /search?keywords=周杰伦&type=1018
  8. [ERR] /artists?id=6452&timestamp=1608366306677 {
  9.   status: 400,
  10.   body: { msg: 'Cheating', code: -460, message: 'Cheating' }
  11. }
  12. [OK] /artist/mv?id=6452
  13. [OK] /artist/album?id=6452&limit=200
呜呜呜大佬强啊  发表于 2020-12-19 17:12
25#
发表于 2020-12-19 17:21:16 | 只看该作者
 楼主| 发表于 2020-12-19 17:36:01 | 只看该作者
我是坏虫 发表于 2020-12-19 17:21
https://music.malahu.org/#/album/37099125
这个歌还是不能听
能听 不能的话尝试刷新之类的 不能听大概率是网络问题(我服务器的网络问题
27#
发表于 2020-12-19 17:44:12 | 只看该作者
发表于 2020-12-19 18:01:14 | 只看该作者
lzdszdl 发表于 2020-12-19 17:36
能听 不能的话尝试刷新之类的 不能听大概率是网络问题(我服务器的网络问题 ...
老哥,我这里默认是https协议
然而other.player.nf01.sycdn.kuwo.cn根本没配置SSL
29#
发表于 2020-12-19 20:26:34 | 只看该作者
大佬nb,感谢大佬辛苦写的教程
30#
发表于 2020-12-19 20:40:59 | 只看该作者
https://music.malahu.org/#/playlist/359353769
测试了不可以播
GMT+8, 2025-12-24 19:50 , Processed in 0.063216 second(s), 10 queries , Gzip On, MemCache On.
