楼主: xiaonichen
[Windows VPS] servarica的这个I/O是真的吗
发表于 2020-12-4 10:04:43 | 只看该作者
这是LTE那边这2天这家的测试,IO老早正常了
Tue Dec  1 04:20:06 EST 2020
Basic System Information:
Processor  : Intel(R) Xeon(R) CPU E5-2650 v2 @ 2.60GHz
CPU cores  : 2 @ 2593.638 MHz
AES-NI     :  Enabled
VM-x/AMD-V :  Disabled
RAM        : 1.8 GiB
Swap       : 1024.0 MiB
Disk       : 2.0 TiB
fio Disk Speed Tests (Mixed R/W 50/50):
Read       | 22.02 MB/s    (5.5k) | 145.99 MB/s   (2.2k)
Write      | 22.04 MB/s    (5.5k) | 146.76 MB/s   (2.2k)
Total      | 44.06 MB/s   (11.0k) | 292.75 MB/s   (4.5k)
Read       | 258.00 MB/s    (503) | 208.54 MB/s    (203)
Write      | 271.71 MB/s    (530) | 222.43 MB/s    (217)
Total      | 529.71 MB/s   (1.0k) | 430.97 MB/s    (420)
Yet-Another-Bench-Script
v2020-11-20
https://github.com/masonr/yet-another-bench-script
Tue Dec 1 20:39:07 EST 2020
CPU cores : 4 @ 2593.713 MHz
AES-NI :  Enabled
RAM : 5.6 GiB
Swap : 1024.0 MiB
Disk : 3.9 TiB
Block Size        4k (IOPS)        64k (IOPS)
Read        30.63 MB/s (7.6k)        178.95 MB/s (2.7k)
Write        30.66 MB/s (7.6k)        179.89 MB/s (2.8k)
Total        61.30 MB/s (15.3k)        358.85 MB/s (5.6k)
Block Size        512k (IOPS)        1m (IOPS)
Read        231.19 MB/s (451)        251.65 MB/s (245)
Write        243.48 MB/s (475)        268.41 MB/s (262)
Total        474.68 MB/s (926)        520.06 MB/s (507)
Provider | Location (Link) | Send Speed | Recv Speed
Clouvider | London, UK (10G) | 944 Mbits/sec | 933 Mbits/sec
Online.net | Paris, FR (10G) | 485 Mbits/sec | 925 Mbits/sec
WorldStream | The Netherlands (10G) | 926 Mbits/sec | 927 Mbits/sec
Biznet | Jakarta, Indonesia (1G) | busy | 68.6 Mbits/sec
Clouvider | NYC, NY, US (10G) | 1.01 Gbits/sec | 974 Mbits/sec
Velocity Online | Tallahassee, FL, US (10G) | 960 Mbits/sec | 961 Mbits/sec
Clouvider | Los Angeles, CA, US (10G) | 953 Mbits/sec | 944 Mbits/sec
发表于 2020-12-4 10:05:17 | 只看该作者
我记得以前还有几百K的
发表于 2020-12-4 10:06:41 | 只看该作者
servarica这个IO很常见
每次活动都是钻石盘
楼主可以搜一下之前帖子
发表于 2020-12-4 11:12:28 | 只看该作者
恭喜楼主获得极品钻石盘。这是在hostloc上看到的最慢的速度了。
发表于 2020-12-4 11:15:22 来自手机 | 只看该作者
钻石恒永久
发表于 2020-12-4 13:54:52 | 只看该作者
吓得我测了下
发表于 2020-12-4 14:01:14 | 只看该作者
测了下去年的,貌似还可以
  1. root@debian:~# dd if=/dev/zero of=test bs=64k count=16k conv=fdatasync
  2. 16384+0 records in
  3. 16384+0 records out
  4. 1073741824 bytes (1.1 GB, 1.0 GiB) copied, 2.42616 s, 443 MB/s
  5. root@debian:~# dd if=/dev/zero of=test bs=64k count=16k conv=fdatasync
  6. 16384+0 records in
  7. 16384+0 records out
  8. 1073741824 bytes (1.1 GB, 1.0 GiB) copied, 2.25724 s, 476 MB/s
  9. root@debian:~# dd if=/dev/zero of=test bs=64k count=16k conv=fdatasync
  10. 16384+0 records in
  11. 16384+0 records out
  12. 1073741824 bytes (1.1 GB, 1.0 GiB) copied, 2.15994 s, 497 MB/s
发表于 2020-12-4 14:11:54 | 只看该作者
发表于 2020-12-4 14:14:14 来自手机 | 只看该作者
可以全额退款
20#
 楼主| 发表于 2020-12-4 14:22:37 | 只看该作者
你好韩
如果我们重新安装到更好的服务器上可以吗?您将在那里看到良好的IO性能。
PS:您当前的所有数据将被删除。
如果您还有其他疑问,请回复我们。
GMT+8, 2026-4-25 13:17 , Processed in 0.060528 second(s), 9 queries , Gzip On, MemCache On.
