12
返回列表 发新帖
楼主: PhotonVPS-Jim
VPS Benchmark
发表于 2009-12-14 14:09:57 | 只看该作者
原帖由 老李 于 2009-12-14 14:00 发表
烫老板他们的都自己开发了,PV也得加油了
汤老板他们本身就是做技术的
发表于 2009-12-14 14:23:52 | 只看该作者
BYTE UNIX Benchmarks (Version 4.1-wht.2, 8 threads)
System -- Linux xxx.xxxxxx.com 2.6.18-164.6.1.el5xen #1 SMP Tue Nov 3 16:48:13 EST 2009 x86_64 GNU/Linux
/dev/sda1             35284656   1399948  32092300   5% /
Start Benchmark Run: Mon Dec 14 06:09:35 UTC 2009
06:09:35 up 6 days, 23:05,  2 users,  load average: 0.00, 0.86, 1.48
End Benchmark Run: Mon Dec 14 06:20:09 UTC 2009
06:20:09 up 6 days, 23:16,  1 user,  load average: 30.97, 12.39, 5.89
                     INDEX VALUES
TEST                                        BASELINE     RESULT      INDEX
Dhrystone 2 using register variables        376783.7 22120719.7      587.1
Double-Precision Whetstone                      83.1     1267.8      152.6
Execl Throughput                               188.3     5394.4      286.5
File Copy 1024 bufsize 2000 maxblocks         2672.0   156052.0      584.0
File Copy 256 bufsize 500 maxblocks           1077.0    42439.0      394.0
File Read 4096 bufsize 8000 maxblocks        15382.0  1264463.0      822.0
Pipe Throughput                             111814.6   842000.0       75.3
Pipe-based Context Switching                 15448.6   245184.0      158.7
Process Creation                               569.3     7331.5      128.8
Shell Scripts (8 concurrent)                    44.8     1276.5      284.9
System Call Overhead                        114433.5  1187044.1      103.7
     FINAL SCORE                                                     248.3
看来这个服务器上载的都是资源大户。
发表于 2009-12-14 14:27:51 | 只看该作者
这是我的,xen 512的
System -- Linux server.0411.in 2.6.18-164.6.1.el5xen #1 SMP Tue Nov 3 16:48:13 EST 2009 x86_64 x86_64 x86_64 GNU/Linux
/dev/sda1             35284656  12138300  21353948  37% /
Start Benchmark Run: Mon Dec 14 14:17:29 CST 2009
14:17:29 up 14 days, 15:32,  1 user,  load average: 0.56, 1.48, 1.77
End Benchmark Run: Mon Dec 14 14:28:10 CST 2009
14:28:10 up 14 days, 15:43,  1 user,  load average: 31.11, 12.35, 5.95
                     INDEX VALUES
Dhrystone 2 using register variables        376783.7 16244495.3      431.1
Double-Precision Whetstone                      83.1     1334.8      160.6
Execl Throughput                               188.3     2985.7      158.6
File Copy 1024 bufsize 2000 maxblocks         2672.0   152633.0      571.2
File Copy 256 bufsize 500 maxblocks           1077.0    42243.0      392.2
File Read 4096 bufsize 8000 maxblocks        15382.0  1312275.0      853.1
Pipe Throughput                             111814.6  1342341.8      120.1
Pipe-based Context Switching                 15448.6   357396.1      231.3
Process Creation                               569.3    11941.5      209.8
Shell Scripts (8 concurrent)                    44.8     1847.8      412.5
System Call Overhead                        114433.5  1757013.6      153.5
     FINAL SCORE                                                     278.3
发表于 2009-12-14 15:14:34 | 只看该作者
回复 13# 的帖子
XEN的分数普遍偏低,EDH的VPS我测试也是200多分
发表于 2009-12-14 15:31:05 | 只看该作者
photon 是不是openvz和xen都没面板?
发表于 2009-12-14 15:33:29 | 只看该作者
回复 15# 的帖子
都没有。
发表于 2009-12-15 08:38:42 | 只看该作者
没面板怎么重启
难道让它自动耗尽资源而死?
发表于 2009-12-15 09:57:34 | 只看该作者
回复 17# 的帖子
唯有联系客服帮重启了。
GMT+8, 2026-4-26 03:48 , Processed in 0.063275 second(s), 9 queries , Gzip On, MemCache On.
