楼主: linode-jspinosi
如何自建域名解析DNS
发表于 2020-10-16 16:18:19 | 只看该作者
unbound dnsdist
发表于 2020-10-16 16:20:05 | 只看该作者
那种?  域名解析DNS还是像114.114.114 8.8.8.8 的权威DNS??
发表于 2020-10-16 17:42:55 | 只看该作者
114.114.114.114, 8.8.8.8 等 Public DNS 是递归 DNS,ns3.dnsv3.com, ns4.alidns.com 等才是权威 DNS
tir
反了反了,emmmm  发表于 2020-10-16 18:31
发表于 2020-10-16 18:00:34 | 只看该作者
发表于 2020-10-16 18:03:04 | 只看该作者
发表于 2020-10-16 18:04:18 | 只看该作者
发表于 2020-10-16 18:05:48 | 只看该作者
骚货 发表于 2020-10-16 06:00
并不会,又不是什么违法的,
大陆安排 dns 服务是需要资质的
发表于 2020-10-16 18:14:09 | 只看该作者
Tracker 发表于 2020-10-16 18:04
114.114.114.114, 8.8.8.8 等是权威 DNS,198.41.0.4、199.9.14.201 等是根DNS
Name servers
The Domain Name System is maintained by a distributed database system, which uses the client–server model. The nodes of this database are the name servers. Each domain has at least one authoritative DNS server that publishes information about that domain and the name servers of any domains subordinate to it. The top of the hierarchy is served by the root name servers, the servers to query when looking up (resolving) a TLD.
Authoritative name server
An authoritative name server is a name server that only gives answers to DNS queries from data that has been configured by an original source, for example, the domain administrator or by dynamic DNS methods, in contrast to answers obtained via a query to another name server that only maintains a cache of data.
An authoritative name server can either be a primary server or a secondary server. Historically the terms master/slave and primary/secondary were sometimes used interchangeably but the current practice is to use the latter form. A primary server is a server that stores the original copies of all zone records. A secondary server uses a special automatic updating mechanism in the DNS protocol in communication with its primary to maintain an identical copy of the primary records.
Every DNS zone must be assigned a set of authoritative name servers. This set of servers is stored in the parent domain zone with name server (NS) records.
An authoritative server indicates its status of supplying definitive answers, deemed authoritative, by setting a protocol flag, called the "Authoritative Answer" (AA) bit in its responses. This flag is usually reproduced prominently in the output of DNS administration query tools, such as dig, to indicate that the responding name server is an authority for the domain name in question.
Address resolution mechanism
Domain name resolvers determine the domain name servers responsible for the domain name in question by a sequence of queries starting with the right-most (top-level) domain label.
A DNS resolver that implements the iterative approach mandated by RFC 1034; in this case, the resolver consults three name servers to resolve the fully qualified domain name "www.wikipedia.org".
For proper operation of its domain name resolver, a network host is configured with an initial cache (hints) of the known addresses of the root name servers. The hints are updated periodically by an administrator by retrieving a dataset from a reliable source.
Assuming the resolver has no cached records to accelerate the process, the resolution process starts with a query to one of the root servers. In typical operation, the root servers do not answer directly, but respond with a referral to more authoritative servers, e.g., a query for "www.wikipedia.org" is referred to the org servers. The resolver now queries the servers referred to, and iteratively repeats this process until it receives an authoritative answer. The diagram illustrates this process for the host that is named by the fully qualified domain name "www.wikipedia.org".
This mechanism would place a large traffic burden on the root servers, if every resolution on the Internet required starting at the root. In practice caching is used in DNS servers to off-load the root servers, and as a result, root name servers actually are involved in only a relatively small fraction of all requests.
Recursive and caching name server
In theory, authoritative name servers are sufficient for the operation of the Internet. However, with only authoritative name servers operating, every DNS query must start with recursive queries at the root zone of the Domain Name System and each user system would have to implement resolver software capable of recursive operation.
To improve efficiency, reduce DNS traffic across the Internet, and increase performance in end-user applications, the Domain Name System supports DNS cache servers which store DNS query results for a period of time determined in the configuration (time-to-live) of the domain name record in question. Typically, such caching DNS servers also implement the recursive algorithm necessary to resolve a given name starting with the DNS root through to the authoritative name servers of the queried domain. With this function implemented in the name server, user applications gain efficiency in design and operation.
The combination of DNS caching and recursive functions in a name server is not mandatory; the functions can be implemented independently in servers for special purposes.
Internet service providers typically provide recursive and caching name servers for their customers. In addition, many home networking routers implement DNS caches and recursors to improve efficiency in the local network.
Source: https://en.wikipedia.org/wiki/Domain_Name_System
发表于 2020-10-16 18:19:02 | 只看该作者
公共DNS是递归DNS,在域名注册商处为你的域名设置的 Name Server 才是(相对于你这个域名的)权威DNS
Windows 可以 nslookup loc.qiche.eu.org 114.114.114.114 和 nslookup loc.qiche.eu.org f1g1ns1.dnspod.net 找不同
  1. C:\Users\app>nslookup loc.qiche.eu.org 114.114.114.114
  2. 服务器:  public1.114dns.com
  3. Address:  114.114.114.114
  4. 非权威应答:
  5. 名称:    loc.qiche.eu.org
  6. Address:  23.225.155.84
  7. C:\Users\app>
  1. C:\Users\app>nslookup loc.qiche.eu.org f1g1ns1.dnspod.net
  2. 服务器:  UnKnown
  3. Address:  61.151.180.44
  4. 名称:    loc.qiche.eu.org
  5. Address:  23.225.155.84
  6. C:\Users\app>
只有向该域名的权威DNS查询DNS才不会显示非权威应答
20#
发表于 2020-10-16 18:20:18 来自手机 | 只看该作者
GMT+8, 2026-1-15 21:44 , Processed in 0.064959 second(s), 10 queries , Gzip On, MemCache On.
