楼主: shc
【大更新】可浏览器访问的桌面脚本已更新,现已支持RDP
发表于 2020-9-28 09:59:44 | 只看该作者
shc 发表于 2020-9-28 09:54
感觉是你服务器用的源的问题,从你的截图里看,直接用apt安装的xrdp和tomcat9都没装上…… ...
可能吧,换乌班图20成功了
82#
发表于 2020-9-28 10:05:24 | 只看该作者
cici9911 发表于 2020-9-26 10:58
就不能docker一下吗.这样就无所谓cent还是debian了
楼主傻傻的,一位没有docker,自家产品早都有了,才发布.
这是 centos安装的方法,其他类似就不说了
  1. wget https://download.docker.com/linux/centos/docker-ce.repo -O /etc/yum.repos.d/ocker-ce.repo
  2. yum install docker-ce -y
  3. systemctl start docker
  4. systemctl enable docker
  5. docker pull guacamole/guacamole
  6. docker pull guacamole/guacd
  7. docker run --name guacd --restart=always  -d guacamole/guacd
  8. docker run --name vnc --restart=always  --link guacd:guacd \
  9.   -e MYSQL_HOSTNAME='127.0.0.1' \
  10.   -e MYSQL_PORT='3306' \
  11.   -e MYSQL_DATABASE='vnc' \
  12.   -e MYSQL_USER='root' \
  13.   -e MYSQL_PASSWORD='root' \
  14.   -d -p 65535:8080 guacamole/guacamole
  15. cat << EOF > /etc/nginx/conf.d/vnc.conf
  16. upstream vnc {
  17.     server  127.0.0.1:65535;
  18. }
  19. server {
  20.     listen                     80;
  21.     listen                     443 ssl;
  22.     server_name                xxx.com;
  23.     ssl_certificate            /home/ssl/xx.crt;
  24.     ssl_certificate_key        /home/ssl/xx.key;
  25.     ssl_ciphers                ECDHE-RSA-AES256-GCM-SHA384:ECDHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-SHA384:ECDHE-RSA-AES128-SHA256:ECDHE-RSA-AES256-SHA:ECDHE-RSA-AES128-SHA:DHE-RSA-AES256-SHA256:DHE-RSA-AES128-SHA256:DHE-RSA-AES256-SHA:DHE-RSA-AES128-SHA:ECDHE-RSA-DES-CBC3-SHA:EDH-RSA-DES-CBC3-SHA:AES256-GCM-SHA384:AES128-GCM-SHA256:AES256-SHA256:AES128-SHA256:AES256-SHA:AES128-SHA:DES-CBC3-SHA:HIGH:!aNULL:!eNULL:!EXPORT:!CAMELLIA:!DES:!MD5:!PSK:!RC4;
  26.     ssl_prefer_server_ciphers  on;
  27.     ssl_protocols              TLSv1 TLSv1.1 TLSv1.2;
  28.     ssl_session_cache          shared:SSL:5m;
  29.     ssl_session_timeout        5m;
  30.     if (\$scheme = http) {
  31.         return  301 https://\$host\$request_uri;
  32.     }
  33.     location / {
  34.         proxy_pass          http://vnc/guacamole/;
  35.         proxy_cookie_path   /guacamole/ /;
  36.         proxy_buffering     off;
  37.         proxy_http_version  1.1;
  38.         proxy_set_header    X-Real-IP \$remote_addr;
  39.         proxy_set_header    X-Forwarded-For \$proxy_add_x_forwarded_for;
  40.         proxy_set_header    Upgrade \$http_upgrade;
  41.         proxy_set_header    Connection \$http_connection;
  42.         access_log          off;
  43.     }
  44. }
  45. EOF
GMT+8, 2026-4-25 14:53 , Processed in 0.064266 second(s), 8 queries , Gzip On, MemCache On.
