楼主: MikuSama
天翼云盘命令行上传下载全能工具【0425更新】
发表于 2020-4-12 15:15:51 | 只看该作者
能映射到本地就爽了
---来自小白的小声比比
62#
 楼主| 发表于 2020-4-12 15:32:22 | 只看该作者
yueyyy 发表于 2020-4-12 15:15
能映射到本地就爽了
---来自小白的小声比比
有在考虑新增这个功能
63#
 楼主| 发表于 2020-4-12 15:33:31 | 只看该作者
iiko 发表于 2020-4-12 15:09
parentId": "-11", # 上传文件夹 根目录
请问上传到别的目录怎么改呀
这个功能我近期会增加的。如果想自己改,可以抓包看看别的文件夹的fileId,然后改这个就行了
64#
发表于 2020-4-12 15:35:50 | 只看该作者
MikuSama 发表于 2020-4-12 15:33
这个功能我近期会增加的。如果想自己改,可以抓包看看别的文件夹的fileId,然后改这个就行了 ...
好的大佬,请问安装依赖时出错了怎么搞啊
Microsoft Windows [版本 10.0.18363.720]
(c) 2019 Microsoft Corporation。保留所有权利。
C:\Windows\system32>pip install -r C:\tool\cloud189-master\requirements.txt
WARNING: pip is being invoked by an old script wrapper. This will fail in a future version of pip.
Please see https://github.com/pypa/pip/issues/5599 for advice on fixing the underlying issue.
To avoid this problem you can invoke Python with '-m pip' instead of running pip directly.
Requirement already satisfied: requests in c:\program files\python\lib\site-packages (from -r C:\tool\cloud189-master\requirements.txt (line 1)) (2.22.0)
WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'ProxyError('Cannot connect to proxy.', NewConnectionError('<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x000001D9D64D0908>: Failed to establish a new connection: [WinError 10061] 由于目标计算机积极拒绝,无法连接。',))': /simple/rsa/
WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'ProxyError('Cannot connect to proxy.', NewConnectionError('<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x000001D9D64D0B00>: Failed to establish a new connection: [WinError 10061] 由于目标计算机积极拒绝,无法连接。',))': /simple/rsa/
WARNING: Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'ProxyError('Cannot connect to proxy.', NewConnectionError('<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x000001D9D64D06A0>: Failed to establish a new connection: [WinError 10061] 由于目标计算机积极拒绝,无法连接。',))': /simple/rsa/
WARNING: Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'ProxyError('Cannot connect to proxy.', NewConnectionError('<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x000001D9D64D0DA0>: Failed to establish a new connection: [WinError 10061] 由于目标计算机积极拒绝,无法连接。',))': /simple/rsa/
WARNING: Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'ProxyError('Cannot connect to proxy.', NewConnectionError('<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x000001D9D64D0E80>: Failed to establish a new connection: [WinError 10061] 由于目标计算机积极拒绝,无法连接。',))': /simple/rsa/
ERROR: Could not find a version that satisfies the requirement rsa (from -r C:\tool\cloud189-master\requirements.txt (line 2)) (from versions: none)
ERROR: No matching distribution found for rsa (from -r C:\tool\cloud189-master\requirements.txt (line 2))
65#
发表于 2020-4-12 15:48:19 | 只看该作者
上传速度好慢呀,才1.3 MB/s 左右,我用客户端和别的工具上传都是满速的哦,我30M上行
66#
 楼主| 发表于 2020-4-12 15:49:31 | 只看该作者
iiko 发表于 2020-4-12 15:48
上传速度好慢呀,才1.3 MB/s 左右,我用客户端和别的工具上传都是满速的哦,我30M上行 ...
我用网页端也确实不能满速上传,看返回的JSON数据,应该是被限速了。
67#
发表于 2020-4-12 15:54:15 | 只看该作者
是的限速了,大佬听说能逆向客户端api来搞
68#
发表于 2020-4-12 16:56:22 | 只看该作者
这个必火啊
69#
发表于 2020-4-12 16:59:40 | 只看该作者
有没有自动备份脚本
70#
 楼主| 发表于 2020-4-12 21:43:41 | 只看该作者
这种根本不需要逆向吧,只需要抓个包就能解决,因为上传的URL是根据API来获取的。
GMT+8, 2026-1-17 16:17 , Processed in 0.074506 second(s), 7 queries , Gzip On, MemCache On.
