楼主: Mr.
【更新1.3.0】漂亮的网站监控面板更新了!又有新功能了!
发表于 2020-4-23 21:15:55 | 只看该作者
收藏支持一下
132#
发表于 2020-4-23 21:17:33 来自手机 | 只看该作者
真的是漂亮的网站监控面板
133#
发表于 2020-5-4 09:00:41 | 只看该作者
看起来不错哦
134#
发表于 2020-5-4 09:06:43 | 只看该作者
提个建议:
这个比如一天挂了1分钟(举例),就标示为黄色,5分钟(举例)以上的才标红色。
没有用过UptimeRobot,不知道能实现不。建议下
135#
发表于 2020-5-4 14:18:29 | 只看该作者
支持支持
137#
发表于 2020-5-4 17:51:52 | 只看该作者
火钳刘明一下
138#
发表于 2020-5-29 01:40:51 | 只看该作者
大佬,我编译老是报错。
  1. [root@Her]# npm run build
  2. > uptime-status@1.3.0 build /home/UptimeStatus
  3. > react-app-rewired build
  4. /home/UptimeStatus/config-overrides.js:12
  5.       ...rule,
  6.       ^^^
  7. SyntaxError: Unexpected token ...
  8.     at createScript (vm.js:56:10)
  9.     at Object.runInThisContext (vm.js:97:10)
  10.     at Module._compile (module.js:549:28)
  11.     at Object.Module._extensions..js (module.js:586:10)
  12.     at Module.load (module.js:494:32)
  13.     at tryModuleLoad (module.js:453:12)
  14.     at Function.Module._load (module.js:445:3)
  15.     at Module.require (module.js:504:17)
  16.     at require (internal/module.js:20:19)
  17.     at Object.<anonymous> (/home/UptimeStatus/node_modules/react-app-rewired/config-overrides.js:5:18)
  18. npm ERR! Linux 3.10.0-1127.el7.x86_64
  19. npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "run" "build"
  20. npm ERR! node v6.17.1
  21. npm ERR! npm  v3.10.10
  22. npm ERR! code ELIFECYCLE
  23. npm ERR! uptime-status@1.3.0 build: `react-app-rewired build`
  24. npm ERR! Exit status 1
  25. npm ERR!
  26. npm ERR! Failed at the uptime-status@1.3.0 build script 'react-app-rewired build'.
  27. npm ERR! Make sure you have the latest version of node.js and npm installed.
  28. npm ERR! If you do, this is most likely a problem with the uptime-status package,
  29. npm ERR! not with npm itself.
  30. npm ERR! Tell the author that this fails on your system:
  31. npm ERR!     react-app-rewired build
  32. npm ERR! You can get information on how to open an issue for this project with:
  33. npm ERR!     npm bugs uptime-status
  34. npm ERR! Or if that isn't available, you can get their info via:
  35. npm ERR!     npm owner ls uptime-status
  36. npm ERR! There is likely additional logging output above.
  37. npm ERR! Please include the following file with any support request:
  38. npm ERR!     /home/UptimeStatus/npm-debug.log
139#
发表于 2020-5-29 01:53:37 | 只看该作者
我找了一个月 才看到居然有大佬做出来了
140#
发表于 2020-5-29 01:57:32 | 只看该作者
大佬牛皮 xmsl
GMT+8, 2026-5-2 18:13 , Processed in 0.061581 second(s), 7 queries , Gzip On, MemCache On.
