12
返回列表 发新帖
楼主: affyun.org
修改Oracle的防火墙规则
发表于 2019-9-18 00:37:29 | 只看该作者
ICMP协议 应该Type 0 Code 8,写反了
 楼主| 发表于 2019-9-18 00:45:08 | 只看该作者
https://en.wikipedia.org/wiki/Ping_(networking_utility)#Echo_request
发表于 2019-9-18 01:39:45 来自手机 | 只看该作者
阿彪老哥 发表于 2019-9-17 22:30
块存储功能没有任何地方提示是免费的, 我开了一个100GB的, 直接从账户余额中扣费了, 说明这个块存储肯定 ...
When you create a Compute instance, the default boot volume size for the instance is 50 GB, which counts towards your allotment of 100 GB. You can customize the instance's boot volume size up to 100 GB; however, this will use up your full allotment of storage for Always Free Block Volume resources. Also, because the minimum boot volume size allowed for Compute instances is 50 GB, launching two instances will use all your Always Free Block Volume resources. Alternatively, you can launch one instance with the default boot volume size of 50 GB, and then create and attach a 50 GB block volume to expand the storage capacity of the instance. For more information, see Creating a Volume and
感谢!!!  发表于 2019-9-18 01:47
GMT+8, 2026-4-24 10:36 , Processed in 0.060635 second(s), 10 queries , Gzip On, MemCache On.
