12
返回列表 发新帖
楼主: onepeople
ZFAKA已经加入宝塔一键部署了
发表于 2019-6-20 13:40:25 | 只看该作者
强呀 这就方便很多了 舒服
发表于 2019-6-20 14:59:25 | 只看该作者
暂时在宝塔里面没发现部署的源码
发表于 2019-6-20 21:12:01 | 只看该作者
宝塔里面一键部署了,但无法用宝塔申请let's encrypt证书,提示“签发失败,域名解析错误,或解析未生效,或域名未北岸!”。
我的域名是freenom的免费域名,mcloud.ml,错误信息:
  1. {u'siteName': u'mcloud.ml', u'path': u'/www/server/panel/vhost/cert/mcloud.ml', u'DOMAINS': u'DNS:mcloud.ml', u'sitePath': u'/www/wwwroot/mcloud.ml/public'}
  2. Generate account key...
  3. Generate domain key...
  4. Generate CSR.../www/server/panel/vhost/cert/mcloud.ml/privkey.csr
  5. Parsing account key...
  6. Parsing CSR...
  7. Found domains: mcloud.ml
  8. Getting directory...
  9. Directory found!
  10. Registering account...
  11. Registered!
  12. Creating new order...
  13. Order created!
  14. Verifying mcloud.ml...
  15. Traceback (most recent call last):
  16. File "/www/server/panel/class/letsencrypt.py", line 233, in
  17. signed_crt = get_crt(ACCOUNT_KEY, DOMAIN_CSR, DOMAIN_DIR, ) ##########
  18. File "/www/server/panel/class/letsencrypt.py", line 170, in get_crt
  19. raise ValueError("Challenge did not pass for {0}: {1}".format(domain, authorization))
  20. ValueError: Challenge did not pass for mcloud.ml: {u'status': u'invalid', u'challenges': [{u'status': u'invalid', u'url': u'https://acme-v02.api.letsencrypt.org/acme/challenge/H_FOc8SYTNOmdvwdDRZw1SVXCl-e4ZLlm_I9TaLF3-g/17302500035', u'token': u'PZJa2r5NY24dZgGHoyEyn2onol46wa6RU1rRdpcsY4o', u'type': u'tls-alpn-01'}, {u'status': u'invalid', u'url': u'https://acme-v02.api.letsencrypt.org/acme/challenge/H_FOc8SYTNOmdvwdDRZw1SVXCl-e4ZLlm_I9TaLF3-g/17302500037', u'token': u'jJC6KyOAE***56pfc02oz7g-F118JWljFBJDUv-Np6B9c', u'type': u'dns-01'}, {u'status': u'invalid', u'validationRecord': [{u'url': u'http://mcloud.ml/.well-known/acme-challenge/atmlJbm_710e_uMaRDKHv6Wov0TtbNakzkF61LQFnxg', u'hostname': u'mcloud.ml', u'addressUsed': u'91.203.192.178', u'port': u'80', u'addressesResolved': [u'91.203.192.178']}], u'url': u'https://acme-v02.api.letsencrypt.org/acme/challenge/H_FOc8SYTNOmdvwdDRZw1SVXCl-e4ZLlm_I9TaLF3-g/17302500039', u'token': u'atmlJbm_710e_uMaRDKHv6Wov0TtbNakzkF61LQFnxg', u'error': {u'status': 403, u'type': u'urn:ietf:params:acme:error:unauthorized', u'detail': u'Invalid response from http://mcloud.ml/.well-known/acme-challenge/atmlJbm_710e_uMaRDKHv6Wov0TtbNakzkF61LQFnxg [91.203.192.178]: "\\r\\n\\r\\n\\r\\n
  21. 404 Not Found
  22. \\r\\n
  23. nginx
  24. \\r\\n"'}, u'type': u'http-01'}], u'identifier': {u'type': u'dns', u'value': u'mcloud.ml'}, u'expires': u'2019-06-27T13:07:50Z'}
看样子是 .well-known 目录403、404?不懂,不知道是宝塔的问题,还是一键包的问题……
GMT+8, 2026-4-28 13:10 , Processed in 0.067164 second(s), 9 queries , Gzip On, MemCache On.
