12
返回列表 发新帖
楼主: LiuJia
通过debian-installer远程dd安装Windows
 楼主| 发表于 2022-12-29 15:55:14 | 只看该作者
zxxx 发表于 2022-12-29 15:13
https://github.com/fincham/kexec-remote-debian-install/raw/master/build.py
这个脚本大佬保存了吗 ...
大概内容是这样的:
  1. #!/usr/bin/env python
  2. #
  3. # Copyright (c) 2015 Catalyst.net Ltd
  4. # This program is free software: you can redistribute it and/or modify
  5. # it under the terms of the GNU General Public License as published by
  6. # the Free Software Foundation, either version 3 of the License, or
  7. # (at your option) any later version.
  8. #
  9. # This program is distributed in the hope that it will be useful,
  10. # but WITHOUT ANY WARRANTY; without even the implied warranty of
  11. # MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
  12. # GNU General Public License for more details.
  13. #
  14. # You should have received a copy of the GNU General Public License
  15. # along with this program. If not, see <http://www.gnu.org/licenses/>.
  16. #
  17. import argparse
  18. import os
  19. import random
  20. import shutil
  21. import StringIO
  22. import subprocess
  23. import tempfile
  24. """
  25. Produce an initrd image which can be used to remotely re-install Debian or Ubuntu.
  26. Michael Fincham <michael.fincham@catalyst.net.nz>
  27. """
  28. def find(root):
  29.     for root, dirs, files in os.walk(root):
  30.         print dirs
  31.         print files
  32. if __name__ == "__main__":
  33.     parser = argparse.ArgumentParser(description=__doc__)
  34.     parser.add_argument('initrd', help='path to initrd.gz file to repack')
  35.     parser.add_argument('interface', help='which interface to configure')
  36.     parser.add_argument('address', help='IP address to configure on INTERFACE')
  37.     parser.add_argument('netmask', help='netmask to configure on interface')
  38.     parser.add_argument('gateway', help='default gateway to use')
  39.     parser.add_argument('nameservers', help='space separated list of name servers to use')
  40.     parser.add_argument('--locale', default='en_NZ.UTF-8', help='locale to use, defaults to en_NZ.UTF-8')
  41.     parser.add_argument('--keymap', default='us', help='keyboard keymap to use, defaults to us')
  42.     args = parser.parse_args()
  43.     password = "".join("{:02x}".format(ord(c)) for c in open("/dev/urandom","rb").read(16))
  44.     preseed_template = """
  45. d-i anna/choose_modules string network-console
  46. d-i preseed/early_command string anna-install network-console
  47. d-i network-console/password password {password}
  48. d-i network-console/password-again password {password}
  49. d-i netcfg/choose_interface select {interface}
  50. d-i netcfg/disable_dhcp boolean true
  51. d-i netcfg/get_ipaddress string {address}
  52. d-i netcfg/get_netmask string {netmask}
  53. d-i netcfg/get_gateway string {gateway}
  54. d-i netcfg/get_nameservers string {nameservers}
  55. d-i netcfg/confirm_static boolean true
  56. d-i debian-installer/locale string {locale}
  57. d-i console-keymaps-at/keymap select {keymap}
  58.     """
  59.     preseed = preseed_template.format(
  60.         password=password,
  61.         interface=args.interface,
  62.         nameservers=args.nameservers,
  63.         address=args.address,
  64.         netmask=args.netmask,
  65.         gateway=args.gateway,
  66.         locale=args.locale,
  67.         keymap=args.keymap,
  68.     )
  69.     print preseed
  70.     initrd_path = os.path.abspath(args.initrd)
  71.     original_cwd = os.getcwd()
  72.     working_directory = tempfile.mkdtemp()
  73.     os.chdir(working_directory)
  74.     with open('initrd.cpio','wb') as initrd_cpio:
  75.         print "Unpacking initrd..."
  76.         subprocess.check_call(("gzip -cd %s" % initrd_path).split(), stdout=initrd_cpio)
  77.     with open('initrd.cpio','rb') as initrd_cpio:
  78.         subprocess.check_call(("cpio -id").split(), stdin=initrd_cpio)
  79.     print ""
  80.     print "Re-packing initrd..."
  81.     os.unlink('initrd.cpio')
  82.     with open('preseed.cfg', 'w') as preseed_file:
  83.         preseed_file.write(preseed)
  84.     file_list = subprocess.check_output("find .".split())
  85.     with open('initrd.cpio', 'w') as initrd_cpio:
  86.         cpio_process = subprocess.Popen('cpio -H newc -o'.split(), stdin=subprocess.PIPE, stdout=initrd_cpio)
  87.         cpio_process.communicate(file_list)
  88.     with open(initrd_path,'wb') as initrd_cpio:
  89.         subprocess.check_call("gzip -c initrd.cpio".split(), stdout=initrd_cpio)
  90.     os.chdir(original_cwd)
  91.     shutil.rmtree(working_directory)
发表于 2022-12-29 17:37:11 来自手机 | 只看该作者
LiuJia 发表于 2022-12-29 15:55
大概内容是这样的:
感谢
GMT+8, 2026-4-21 10:44 , Processed in 0.055033 second(s), 6 queries , Gzip On, MemCache On.
