楼主: cx9208
bbr 原版/魔改/plus+锐速 四合一脚本
发表于 2018-12-29 00:17:05 | 只看该作者
这个是ubuntu16 x64的
  1. root@vps:~/bbrplus# dpkg -i linux-headers-4.14.90.deb
  2. (Reading database ... 99177 files and directories currently installed.)
  3. Preparing to unpack linux-headers-4.14.90.deb ...
  4. Unpacking linux-headers-4.14.90 (4.14.90-1) over (4.14.90-1) ...
  5. Setting up linux-headers-4.14.90 (4.14.90-1) ...
  6. root@vps:~/bbrplus# dpkg -i linux-image-4.14.90.deb
  7. (Reading database ... 99177 files and directories currently installed.)
  8. Preparing to unpack linux-image-4.14.90.deb ...
  9. Unpacking linux-image-4.14.90 (4.14.90-1) over (4.14.90-1) ...
  10. Setting up linux-image-4.14.90 (4.14.90-1) ...
  11. update-initramfs: Generating /boot/initrd.img-4.14.90
  12. cryptsetup: WARNING: failed to detect canonical device of /dev/vda1
  13. cryptsetup: WARNING: could not determine root device from /etc/fstab
  14. W: mdadm: /etc/mdadm/mdadm.conf defines no arrays.
  15. Searching for GRUB installation directory ... found: /boot/grub
  16. Searching for default file ... found: /boot/grub/default
  17. Testing for an existing GRUB menu.lst file ... found: /boot/grub/menu.lst
  18. Searching for splash image ... none found, skipping ...
  19. Found kernel: /boot/vmlinuz-4.14.90
  20. Found kernel: /boot/vmlinuz-4.4.0-116-generic
  21. Found kernel: /boot/vmlinuz-4.14.90
  22. Found kernel: /boot/vmlinuz-4.4.0-116-generic
  23. Updating /boot/grub/menu.lst ... done
  24. Generating grub configuration file ...
  25. Found linux image: /boot/vmlinuz-4.14.90
  26. Found initrd image: /boot/initrd.img-4.14.90
  27. Found linux image: /boot/vmlinuz-4.4.0-116-generic
  28. Found initrd image: /boot/initrd.img-4.4.0-116-generic
  29. done
122#
 楼主| 发表于 2018-12-29 00:29:09 | 只看该作者
a1328788808 发表于 2018-12-29 00:04
这两个是debian8 x64的。
/var/lib/dkms/amzn-drivers-ena-linux/1.1.3/build/make.log
这个在用脚本前apt-get install libelf-dev就可以了,我查了下只是两个厂商驱动,使用没问题的话可以不管
123#
发表于 2018-12-29 00:40:30 来自手机 | 只看该作者
cx9208 发表于 2018-12-29 00:29
这个在用脚本前apt-get install libelf-dev就可以了,我查了下只是两个厂商驱动,使用没问题的话可以不管 ...
刚专门开了台新机器,又试了一下,还是一样的错误提示。
124#
发表于 2018-12-29 00:42:03 | 只看该作者
谢谢大佬,收藏了
125#
 楼主| 发表于 2018-12-29 08:48:15 | 只看该作者
这样吗,因为我在安装wireguard的时候也出现了一样的错误,但在安装了那个之后就好了。那我再研究下,解决了告诉你
126#
 楼主| 发表于 2018-12-29 09:12:38 | 只看该作者
你是什么idc?我vultr新开的debian8安装内核没有任何问题……
128#
发表于 2018-12-29 09:18:30 | 只看该作者
我把正在运行的服务器搞死了,,,,,,幸好是阿里云。就用的bbrplus,安装内核失败,没有网络了/
129#
发表于 2018-12-29 09:26:18 | 只看该作者
LZ辛苦了,好东西啊!
130#
发表于 2018-12-29 09:38:20 | 只看该作者
bbr plus效果会更好么
GMT+8, 2026-5-7 05:39 , Processed in 0.062961 second(s), 7 queries , Gzip On, MemCache On.
