12
返回列表 发新帖
#脚本# 搭建MTProxy 为 Telegr*am 上网
发表于 2018-6-11 03:23:06 | 只看该作者
凉 Debian 上 直接崩了....
  1. [124493][2018-06-11 03:06:53.965587 local] Invoking engine mtproxy-0.01 compiled at Jun 11 2018 03:05:27 by gcc 6.4.0 20180424 64-bit after commit 20824f5fa8af3939e667fba5c1785f02059c1c43
  2. [124493][2018-06-11 03:06:53.965725 local] config_filename = 'proxy-multi.conf'
  3. [124493][2018-06-11 03:06:53.965944 local] creating 1 workers
  4. mtproto-proxy: common/pid.c:42: init_common_PID: Assertion `!(p & 0xffff0000)' failed.
  5. mtproto-proxy: common/pid.c:42: init_common_PID: Assertion `!(p & 0xffff0000)' failed.
  6. [pid 124493] [time 1528657613]
  7. ------- Stack Backtrace -------
  8. [pid 124494] [time 1528657613]
  9. ------- Stack Backtrace -------
  10. ./mtproto-proxy./mtproto-proxy((print_backtraceprint_backtrace+0x+0x1616))[0x[0x557d3e2625a6557d3e2625a6]
  11. ]
  12. ./mtproto-proxy./mtproto-proxy(extended_debug_handler(+0xextended_debug_handler10+0x)10[0x)557d3e2626e0[0x]
  13. 557d3e2626e0]
  14. /lib/x86_64-linux-gnu/libpthread.so.0/lib/x86_64-linux-gnu/libpthread.so.0((+0x11f50+0x)11f50[0x)7f0270d78f50[0x]
  15. 7f0270d78f50]
  16. /lib/x86_64-linux-gnu/libc.so.6/lib/x86_64-linux-gnu/libc.so.6((gsignalgsignal+0x+0x10b10b))[0x7f02709e1e7b[0x]
  17. 7f02709e1e7b]
  18. /lib/x86_64-linux-gnu/libc.so.6/lib/x86_64-linux-gnu/libc.so.6((abortabort+0x+0x151151))[0x[0x7f02709e32317f02709e3231]
  19. ]
  20. /lib/x86_64-linux-gnu/libc.so.6/lib/x86_64-linux-gnu/libc.so.6((+0x+0x2d9da2d9da))[0x[0x7f02709da9da7f02709da9da]
  21. ]
  22. /lib/x86_64-linux-gnu/libc.so.6(/lib/x86_64-linux-gnu/libc.so.6+0x(2da52+0x)2da52[0x)7f02709daa52[0x]
  23. 7f02709daa52]
  24. ./mtproto-proxy./mtproto-proxy((+0x+0x4f4a14f4a1))[0x[0x557d3e2664a1557d3e2664a1]
  25. ]
  26. ./mtproto-proxy./mtproto-proxy((engine_initengine_init+0xc5+0x)c5[0x)557d3e25cd05[0x]
  27. 557d3e25cd05]
  28. ./mtproto-proxy./mtproto-proxy((default_maindefault_main+0x+0x113113))[0x[0x557d3e25db33557d3e25db33]
  29. ]
  30. /lib/x86_64-linux-gnu/libc.so.6/lib/x86_64-linux-gnu/libc.so.6((__libc_start_main__libc_start_main+0xe7+0x)e7[0x)7f02709cea87[0x]
  31. 7f02709cea87]
  32. ./mtproto-proxy./mtproto-proxy((_start+0x2a)[0x557d3e2281da]
  33. [pid 124493] [time 1528657613] -------------------------------
  34. [pid 124493] [time 1528657613] mtproxy-0.01 compiled at Jun 11 2018 03:05:27 by gcc 6.4.0 20180424 64-bit after commit 20824f5fa8af3939e667fba5c1785f02059c1c43_start[pid 124493] [time 1528657613]
  35. +0x2a)[0x557d3e2281da]
  36. [pid 124494] [time 1528657613] -------------------------------
  37. [pid 124494] [time 1528657613] mtproxy-0.01 compiled at Jun 11 2018 03:05:27 by gcc 6.4.0 20180424 64-bit after commit 20824f5fa8af3939e667fba5c1785f02059c1c43[pid 124494] [time 1528657613]
发表于 2018-6-11 03:30:51 | 只看该作者
发表于 2018-6-11 03:50:32 | 只看该作者
socks5 似乎更简单
发表于 2018-6-11 08:56:51 | 只看该作者
感谢楼主分享安装脚本,这提供了多一种登录tg的选择。
发表于 2018-6-11 09:04:08 | 只看该作者
ChinaDNS 发表于 2018-6-10 22:48
最好加上定时脚本定时更新proxy-multi.conf
而且在bot @MTProxybot 里添加可以看一些信息~
看你的头像容易晕车
发表于 2018-6-11 09:27:12 | 只看该作者
大佬的频道我已经关注了,就不点开代理啦
发表于 2018-6-11 11:29:45 | 只看该作者
@雨落无声4617 对了如果是NAT鸡的话需要添加
  1. --nat-info 内网IP:外网IP
发表于 2018-6-11 11:42:52 来自手机 | 只看该作者
能否与酸酸共存
发表于 2018-6-11 11:44:37 | 只看该作者
当然可以,别占用同一个端口
20#
发表于 2018-6-11 21:10:00 | 只看该作者
谢谢楼主分享
GMT+8, 2026-4-22 12:51 , Processed in 0.065749 second(s), 9 queries , Gzip On, MemCache On.
