楼主: Aaron00
写了一款支持对接多家云存储且公私兼备的网盘系统:Cloudreve
发表于 2018-2-17 17:50:36 | 只看该作者
有空拜膜一下
43#
 楼主| 发表于 2018-2-17 17:54:52 | 只看该作者
ownones 发表于 2018-2-17 17:50
刚刚还在你的站测试过,你是不是创建了学习资料文件夹,我不能再创建这个名字的文件夹 ...
确实,很大的bug这么久居然没被发现
感谢
44#
发表于 2018-2-17 17:55:05 | 只看该作者
公开分享的  要登录才能预览和下载?
45#
发表于 2018-2-17 17:55:15 | 只看该作者
能否直接在干净新系统无脑一键,懒人的需求。
  1. Updating dependencies (including require-dev)
  2. Your requirements could not be resolved to an installable set of packages.
  3.   Problem 1
  4.     - The requested PHP extension ext-curl * is missing from your system. Install or enable PHP's curl extension.
  5.   Problem 2
  6.     - The requested PHP extension ext-gd * is missing from your system. Install or enable PHP's gd extension.
  7.   Problem 3
  8.     - Installation request for upyun/sdk ^3.3 -> satisfiable by upyun/sdk[3.3.0].
  9.     - upyun/sdk 3.3.0 requires ext-curl * -> the requested PHP extension curl is missing from your system.
  10.   Problem 4
  11.     - sabre/dav 3.2.2 requires ext-dom * -> the requested PHP extension dom is missing from your system.
  12.     - sabre/dav 3.2.1 requires ext-dom * -> the requested PHP extension dom is missing from your system.
  13.     - sabre/dav 3.2.0 requires ext-dom * -> the requested PHP extension dom is missing from your system.
  14.     - Installation request for sabre/dav ~3.2.0 -> satisfiable by sabre/dav[3.2.0, 3.2.1, 3.2.2].
  15.   To enable extensions, verify that they are enabled in those .ini files:
  16.     - /etc/php/7.0/cli/php.ini
  17.     - /etc/php/7.0/cli/conf.d/10-opcache.ini
  18.     - /etc/php/7.0/cli/conf.d/10-pdo.ini
  19.     - /etc/php/7.0/cli/conf.d/20-calendar.ini
  20.     - /etc/php/7.0/cli/conf.d/20-ctype.ini
  21.     - /etc/php/7.0/cli/conf.d/20-exif.ini
  22.     - /etc/php/7.0/cli/conf.d/20-fileinfo.ini
  23.     - /etc/php/7.0/cli/conf.d/20-ftp.ini
  24.     - /etc/php/7.0/cli/conf.d/20-gettext.ini
  25.     - /etc/php/7.0/cli/conf.d/20-iconv.ini
  26.     - /etc/php/7.0/cli/conf.d/20-json.ini
  27.     - /etc/php/7.0/cli/conf.d/20-phar.ini
  28.     - /etc/php/7.0/cli/conf.d/20-posix.ini
  29.     - /etc/php/7.0/cli/conf.d/20-readline.ini
  30.     - /etc/php/7.0/cli/conf.d/20-shmop.ini
  31.     - /etc/php/7.0/cli/conf.d/20-sockets.ini
  32.     - /etc/php/7.0/cli/conf.d/20-sysvmsg.ini
  33.     - /etc/php/7.0/cli/conf.d/20-sysvsem.ini
  34.     - /etc/php/7.0/cli/conf.d/20-sysvshm.ini
  35.     - /etc/php/7.0/cli/conf.d/20-tokenizer.ini
  36.   You can also run `php --ini` inside terminal to see which files are used by PHP in CLI mode.
46#
发表于 2018-2-17 17:58:20 | 只看该作者
PNG图片上传了 看不了
47#
 楼主| 发表于 2018-2-17 17:59:29 | 只看该作者
fl20002 发表于 2018-2-17 17:58
PNG图片上传了 看不了
可能是因为我的七牛没启用https
48#
发表于 2018-2-17 18:11:03 | 只看该作者
大佬刚发帖,我就看了。然后想注册一个,在然后试了几次验证码让我乖乖去打游戏了。
liusu 该用户已被删除
49#
发表于 2018-2-17 18:14:13 | 只看该作者
发表于 2018-2-17 18:18:23 | 只看该作者
马克一下 谢谢楼主分享
GMT+8, 2026-4-27 08:31 , Processed in 0.079557 second(s), 8 queries , Gzip On, MemCache On.
