楼主: shc
重磅福利2:如何利用闲置服务器高效率挖矿回本/赚钱(updated)
发表于 2017-11-11 09:28:31 来自手机 | 只看该作者
shc 发表于 2017-11-11 09:26
我跟你一样的配置,不知道为啥了。。。
是不是之前的内存分配错误导致的啊,我用了你的方法但是内存还是分配错误,一会试试win看看怎么样
142#
 楼主| 发表于 2017-11-11 09:29:29 | 只看该作者
狗仔小分队 发表于 2017-11-11 09:27
3c高配全开算力200,根据几个小时钱算了一下,一个月最多4刀,大佬开一半cpu月入22刀,真羡慕 ...
200的算力大概每月至少也有10刀,你大概是哪里算错了。
143#
发表于 2017-11-11 09:29:50 来自手机 | 只看该作者
学习了,哈哈
144#
发表于 2017-11-11 09:35:04 | 只看该作者
 楼主| 发表于 2017-11-11 09:36:59 | 只看该作者
dream7758521 发表于 2017-11-11 09:35
RESULT REPORT
You haven't found any results yet.
RESULT REPORT
你这个hashrate report太奇怪了。。。。。。再让它挖一段时间看看什么情况吧
147#
 楼主| 发表于 2017-11-11 09:41:55 | 只看该作者
看不清,可以考虑使用我签名的图床。
149#
发表于 2017-11-11 09:46:01 | 只看该作者
root@pl2:~# screen -S miner
[2017-11-11 09:33:11] : Result accepted by the pool.
[2017-11-11 09:33:21] : Result accepted by the pool.
[2017-11-11 09:33:27] : Result accepted by the pool.
[2017-11-11 09:33:28] : Result accepted by the pool.
[2017-11-11 09:34:11] : Result accepted by the pool.
[2017-11-11 09:34:23] : Result accepted by the pool.
[2017-11-11 09:34:25] : Result accepted by the pool.
[2017-11-11 09:34:57] : Result accepted by the pool.
[2017-11-11 09:35:20] : New block detected.
[2017-11-11 09:35:33] : New block detected.
[2017-11-11 09:35:35] : Result accepted by the pool.
[2017-11-11 09:35:48] : Result accepted by the pool.
[2017-11-11 09:36:08] : Result accepted by the pool.
[2017-11-11 09:37:30] : Result accepted by the pool.
[2017-11-11 09:37:39] : New block detected.
[2017-11-11 09:37:41] : Result accepted by the pool.
[2017-11-11 09:37:55] : Result accepted by the pool.
[2017-11-11 09:38:00] : Result accepted by the pool.
[2017-11-11 09:38:21] : Result accepted by the pool.
[2017-11-11 09:39:25] : Result accepted by the pool.
[2017-11-11 09:39:48] : Result accepted by the pool.
[2017-11-11 09:40:08] : Result accepted by the pool.
[2017-11-11 09:40:09] : New block detected.
[2017-11-11 09:40:31] : Result accepted by the pool.
[2017-11-11 09:40:44] : Result accepted by the pool.
[2017-11-11 09:40:58] : Result accepted by the pool.
[2017-11-11 09:40:59] : Result accepted by the pool.
[2017-11-11 09:41:09] : Result accepted by the pool.
[2017-11-11 09:41:48] : Result accepted by the pool.
高的时候有330多,最高达到430,但一般是270左右
150#
 楼主| 发表于 2017-11-11 09:57:46 | 只看该作者
膜拜四路E7的大佬。。。
GMT+8, 2026-4-28 08:18 , Processed in 0.060433 second(s), 7 queries , Gzip On, MemCache On.
