CeraNetworks网络延迟测速工具IP归属甄别
楼主: 老神仙
ONLINE系统安装完了,开始PK硬盘时间
发表于 2017-6-28 19:19:42 | 只看该作者
老神仙 发表于 2017-6-28 18:36
smartctl -a /dev/sg0  或者1
谢谢你!
但我输入 smartctl -a /dev/sg1 后提示:
smartctl 6.6 2016-05-31 r4324 [x86_64-linux-4.4.67-1-pve] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Vendor:               HP
Product:              LOGICAL VOLUME
Revision:             6.64
User Capacity:        450,062,645,760 bytes [450 GB]
Logical block size:   512 bytes
Rotation Rate:        15000 rpm
Logical Unit id:      0x600508b1001c794ae90b4de71e59cd82
Serial number:        PACCRID114507NF
Device type:          disk
Local Time is:        Wed Jun 28 13:14:33 2017 CEST
SMART support is:     Unavailable - device lacks SMART capability.
=== START OF READ SMART DATA SECTION ===
Current Drive Temperature:     0 C
Drive Trip Temperature:        0 C
Error Counter logging not supported
Device does not support Self Test logging
输入 smartctl -a /dev/sg0 显示:
Vendor:               HP
Product:              P410
Revision:             6.64
Device type:          storage array
Local Time is:        Wed Jun 28 13:15:53 2017 CEST
发表于 2017-6-28 19:22:43 | 只看该作者
Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       15750
发表于 2017-6-28 21:19:57 | 只看该作者
SMART Attributes Data Structure revision number: 1
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x000f   130   130   039    Pre-fail  Always       -       1208226
  5 Reallocated_Sector_Ct   0x0033   013   013   001    Pre-fail  Always       -       2040
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       14916
12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       31
13 Read_Soft_Error_Rate    0x0032   130   100   000    Old_age   Always       -       429497937826
179 Used_Rsvd_Blk_Cnt_Tot   0x0033   052   052   010    Pre-fail  Always       -       2038
180 Unused_Rsvd_Blk_Cnt_Tot 0x0032   100   100   000    Old_age   Always       -       270
181 Program_Fail_Cnt_Total  0x003a   100   100   000    Old_age   Always       -       0
182 Erase_Fail_Count_Total  0x003a   100   100   000    Old_age   Always       -       0
184 End-to-End_Error        0x0032   100   100   000    Old_age   Always       -       0
194 Temperature_Internal    0x0022   100   100   000    Old_age   Always       -       37
195 Hardware_ECC_Recovered  0x0032   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -       0
199 CRC_Error_Count         0x003e   100   100   000    Old_age   Always       -       0
201 Soft_Read_Error_Rate    0x0033   100   100   010    Pre-fail  Always       -       433793729159
226 Workld_Media_Wear_Indic 0x0032   100   100   000    Old_age   Always       -       2109
227 Workld_Host_Reads_Perc  0x0032   100   100   000    Old_age   Always       -       4
228 Workload_Minutes        0x0032   100   100   000    Old_age   Always       -       894849
233 Media_Wearout_Indicator 0x0032   100   100   000    Old_age   Always       -       248155
245 Unknown_Attribute       0x0032   098   098   000    Old_age   Always       -       0
发表于 2017-6-28 21:24:22 | 只看该作者
我弄台  19000+的
发表于 2017-6-28 21:35:45 | 只看该作者
买了卖……卖了买……哈哈哈,好无聊……
发表于 2017-6-28 21:50:13 | 只看该作者
真不想打击你们。
  9 Power_On_Hours          0x0032   097   096   000    Old_age   Always       -       1543
发表于 2017-6-29 00:13:10 | 只看该作者
ahao358 发表于 2017-6-28 19:19
谢谢你!
smartctl 6.6 2016-05-31 r4324 [x86_64-linux-4.4.67 ...
你sdisk -i下啊
发表于 2017-6-29 00:22:50 | 只看该作者
妈卖批哟,两个盘都是28000+,还能用么
发表于 2017-6-29 00:30:39 | 只看该作者
  1 Raw_Read_Error_Rate     0x000f   081   063   044    Pre-fail  Always       -       139668271
  3 Spin_Up_Time            0x0003   092   091   070    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       18
  5 Reallocated_Sector_Ct   0x0033   100   100   036    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000f   094   060   030    Pre-fail  Always       -       2951475660
  9 Power_On_Hours          0x0032   063   063   000    Old_age   Always       -       32608
10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -       0
12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       18
180 Unknown_HDD_Attribute   0x003b   100   100   030    Pre-fail  Always       -       4294967295
184 End-to-End_Error        0x0032   100   100   003    Old_age   Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
188 Command_Timeout         0x0032   100   099   000    Old_age   Always       -       4295032833
189 High_Fly_Writes         0x003a   100   100   000    Old_age   Always       -       0
190 Airflow_Temperature_Cel 0x0022   070   065   045    Old_age   Always       -       30 (Min/Max 29/33)
191 G-Sense_Error_Rate      0x0032   100   100   000    Old_age   Always       -       0
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       17
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       1375
194 Temperature_Celsius     0x0022   030   040   000    Old_age   Always       -       30 (0 20 0 0 0)
195 Hardware_ECC_Recovered  0x001a   117   099   000    Old_age   Always       -       139668271
196 Reallocated_Event_Count 0x0033   100   100   036    Pre-fail  Always       -       0
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       0
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       0
20#
发表于 2017-6-29 00:30:45 | 只看该作者
我来安慰楼上诸位。
9 Power_On_Hours          0x0032   053   053   000    Old_age   Always       -       34916
9 Power_On_Hours          0x0032   053   053   000    Old_age   Always       -       34945
GMT+8, 2026-5-1 02:30 , Processed in 0.069704 second(s), 8 queries , Gzip On, MemCache On.
