举报
原帖由 zyypp 于 2009-9-11 18:40 发表 ....我试验的就 ok 啊 好奇
user www www; worker_processes 1; error_log /logs/nginx_error.log crit; pid /nginx/nginx.pid; #Specifies the value for maximum file descriptors that can be opened by this process. worker_rlimit_nofile 51200; events { use epoll; worker_connections 51200; } http { include mime.types; default_type application/octet-stream; server_names_hash_bucket_size 128; client_header_buffer_size 32k; large_client_header_buffers 4 64k; client_max_body_size 8m; sendfile on; tcp_nopush on; keepalive_timeout 60; tcp_nodelay on; fastcgi_connect_timeout 300; fastcgi_send_timeout 300; fastcgi_read_timeout 300; fastcgi_buffer_size 64k; fastcgi_buffers 4 64k; fastcgi_busy_buffers_size 128k; fastcgi_temp_file_write_size 128k; gzip on; gzip_min_length 1k; gzip_buffers 4 16k; gzip_http_version 1.1; gzip_comp_level 2; gzip_types text/plain application/x-javascript text/css application/xml; gzip_vary on; upstream ipmac { server 192.168.0.254:81 weight=1; } server { listen 80; server_name 192.168.0.205 index index.html index.htm index.php; proxy_temp_path /htdocs/tmp; root /htdocs/www; location / { autoindex on; } location ^~ /pass/123/ { auth_basic "Restricted"; auth_basic_user_file /nginx/conf/htpasswd; } location ^~ /ip { proxy_pass http://192.168.0.254:81/; proxy_redirect off; proxy_set_header Host $host; proxy_set_header X-Real-IP $remote_addr; proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for; client_max_body_size 10m; client_body_buffer_size 128k; proxy_connect_timeout 90; proxy_send_timeout 300; proxy_read_timeout 300; proxy_buffer_size 64k; proxy_buffers 4 62k; proxy_busy_buffers_size 128k; proxy_temp_file_write_size 128k; } location ~ .*\.(php|php5)?$ { fastcgi_pass unix:/tmp/php-cgi.sock; fastcgi_index index.php; include fcgi.conf; } location /status { access_log off; } log_format access '$remote_addr - $remote_user [$time_local] "$request" ' '$status $body_bytes_sent "$http_referer" ' '"$http_user_agent" $http_x_forwarded_for'; access_log /logs/access.log access; } }
haha:qqqDZ5y6EacRg
本版积分规则 发表回复 回帖后跳转到最后一页
GMT+8, 2026-1-12 10:13 , Processed in 0.066905 second(s), 9 queries , Gzip On, MemCache On.
