12
返回列表 发新帖
楼主: lsza
有没有老司机开车,求个Centos的BT下载工具,或者transmission...
发表于 2016-9-16 09:04:27 | 只看该作者
自用的CentOS 6 一键安装2.92版本,并安装漂亮的第三方web control
transmission-daemon 最关键的一点就是修改配置文件必须保证程序不在后台运行。
程序不在后台运行。
没在运行。
  1. #!/bin/bash
  2. arch=i686
  3. if [[ `uname -m` == "x86_64" ]];then
  4. arch="x86_64"
  5. fi
  6. if [ $arch == "x86_64" ];then
  7.         wget http://geekery.altervista.org/geekery-el6-x86_64.repo -O /etc/yum.repos.d/geekery-el6-x86_64.repo
  8. else
  9.         wget http://geekery.altervista.org/geekery-el6-i686.repo -O /etc/yum.repos.d/geekery-el6-i686.repo
  10. fi
  11. yum install -y wget
  12. yum install -y transmission-daemon
  13. /etc/init.d/transmission-daemon start
  14. sleep 3
  15. /etc/init.d/transmission-daemon stop
  16. sleep 3
  17. cp /var/lib/transmission/settings.json /var/lib/transmission/settings.json.bak
  18. sed -i 's/"download-queue-size": 5/"download-queue-size": 8/g' /var/lib/transmission/settings.json
  19. sed -i 's/"rpc-whitelist-enabled": true/"rpc-whitelist-enabled": false/g' /var/lib/transmission/settings.json
  20. sed -i 's/"dht-enabled": true/"dht-enabled": false/g' /var/lib/transmission/settings.json
  21. wget --no-check-certificate https://github.com/ronggang/transmission-web-control/raw/master/release/tr-control-easy-install.sh -O /tmp/tr-control-easy-install.sh
  22. chmod 755 /tmp/tr-control-easy-install.sh
  23. /tmp/tr-control-easy-install.sh
  24. /etc/init.d/transmission-daemon start
发表于 2016-9-16 10:00:41 | 只看该作者
在用aria2c
启用dht速度感觉也不上去
回头试试其它
发表于 2016-9-18 16:46:04 | 只看该作者
4楼给那个网址不错 保存了
GMT+8, 2026-4-16 08:40 , Processed in 0.057027 second(s), 8 queries , Gzip On, MemCache On.
