12
返回列表 发新帖
楼主: yang
被DreamHost强制搬家
发表于 2010-10-30 20:00:49 | 只看该作者
回复 7# 的帖子
全额帐号是不是啥域名都可以绑哇,你还真是DH的忠实用户
发表于 2010-10-30 20:01:58 | 只看该作者
有没有说原因,大流量而被搬的话都是搬到不好的机器上。
发表于 2010-10-30 20:05:36 | 只看该作者
我想抽他,断了好几天了,而且不是一次两次
 楼主| 发表于 2010-10-30 20:39:51 | 只看该作者
什么域名都可以绑,DH用起来还算顺手。
没说原因,只是通知我而已。
邮件内容:
Hey yang!
This is just a note to let you know that we will be moving your account to
a new server some time within the next 7 days!
PLEASE READ THIS ENTIRE MESSAGE as it may help you fix (or avoid) any problems
that come up as a result of the move.
We have also created a wiki article that explains everything you will need to know
about why we are moving you, steps you can take before the move to prevent problems
and solutions on how to fix things that may break after the move:
http://wiki.dreamhost.com/Server_Moves
Below is a brief summary of the more common problems we're seeing after customers are
moved to their new server. You can get more detailed information at the wiki article
above though.
DOMAINS:
Server Paths:
Please make sure you don't have anything like "/home/.SOMETHING/username" or /mnt/local/home/username
as the path in any of your sites' scripts. Instead, it should just be "/home/username".
In most cases, this path is listed somewhere in your sites configuration files. You should
check all of your sites main files to make sure that the path is correct (including any
plugins you may have installed).
Custom DNS:
If you run your own DNS outside of DreamHost (i.e. you're not using ns1.dreamhost.com,
ns2.dreamhost.com and ns3.dreamhost.com as your domains nameservers) you'll need to update
your records after your account has been moved. Once you have received the email letting
you know that your account has been moved, go to the 'Manage Domains' section of your
web panel and click on the 'DNS' link for your domains to see what the new IP is for that domain.
Custom PHP
If you built your own custom PHP (or php.ini), it may break from this move. This is
because the old servers used a 32bit architecture and the new servers are 64bit.
Unfortunately, this isn't something we can help you troubleshoot, but you'll just
need to rebuild your custom php (or php.ini) again using the new servers libraries.
FTP:
If you are using your server name (server.dreamhost.com) as your FTP hostname, be
sure to change that to your domain name (domain.com). The domain name will always
point to the correct server in the event that it is changed again in the future.
If for some reason you can't use your domain name, you can find the name of your
new server under the 'Manage Account' section of your web panel.
UNIQUE IP:
If you have a unique IP on your account, it has likely changed with the move.
That's it really.. and we really apologize for the abrupt nature of this move!
Thanks!
The Happy DreamHost Moving Team
发表于 2010-10-30 20:42:09 | 只看该作者
DH 在维护么?有台服务器 georgetown.dreamhost.com 无法访问,主站 dreamhost.com 也连不上啊
发表于 2010-10-30 21:40:58 | 只看该作者
GD天天歧视我 没事经常给我换IP
发表于 2010-10-31 09:03:02 | 只看该作者
原帖由 easyboy 于 2010-10-30 21:40 发表
GD天天歧视我 没事经常给我换IP
你买ssh不就完了,独立ip多爽
GMT+8, 2026-4-20 18:00 , Processed in 0.061436 second(s), 6 queries , Gzip On, MemCache On.
