楼主: gouwaming
新买的VPS权限怎么设置
 楼主| 发表于 2009-9-7 15:03:09 | 只看该作者
独立的也有SSL
GD给我回信说
Dear lin yuanzi,
Thank you for contacting Online Support.
It appears that your domain name is not pointing to the correct IP address and there is no index page in your hosting account.
To locate the IP address for your hosting account:
• Select 'Hosting' under the 'My Products' section.
• Click the hosting account that you would like to look up the information for.
• Notice the 'Hosting Account Details' listing on the right side of the page.
• Here you'll be able to see the IP address for your server.
To modify the A-Record for your domain:
1. Select Domain Manager from the My Products menu.
2. Click on the domain which you wish to change the A-Record for.
3. Click Total DNS Control and MX Records.
4. Under the A (Host) section, click the pencil icon to the right of the @ record.
5. Enter the new IP address.
6. Click OK
NOTE: Changes to the settings of a domain can take up to 48 hours to become effective because of the number of networks involved, and because these networks are controlled by several different agencies. This delay applies to all domains with any Registrar. Please allow for this delay when planning web sites or configuring a domain to work with your services.
When I visit your site I can see that it is pointing to your hosting account correctly but you don't have a valid file in the main directory that the server can use as the main page. This file is referred to as an "index page." You will need to create an index page, using one of the following filenames (or rename your main HTML page to one of these names):
The order of precedence for our Windows shared hosting accounts is as follows (top is the highest priority):
default.asp
default.html
default.htm
default.aspx
default.php
default.shtml
default.shtm
index.html
index.htm
index.asp
index.php
index.shtml
index.shtm
home.html
home.htm
home.shtml
home.shtm
welcome.html
welcome.asp
If this information does not provide an answer to your request please clarify exactly what you are trying to do so we may provide the correct information.
Please let us know if we can help in any other way.
Sincerely,
Alycia P.
Online Support Team
32#
发表于 2009-9-7 15:05:49 | 只看该作者
回复 31# 的帖子
信里面是告诉你怎么查看自己的空间IP地址,还有默认首页地址。
33#
 楼主| 发表于 2009-9-7 15:12:19 | 只看该作者
这个IP应该是72.167.232.153吧
34#
 楼主| 发表于 2009-9-7 15:12:38 | 只看该作者
Server IP Address : 72.167.232.153
Dedicated Hosting IP : 97.74.173.197
Billing Date : 02/15/2010
Status : Setup
Disk Space : 925.78 MB of 150000.00
35#
发表于 2009-9-7 15:39:55 | 只看该作者
回复 34# 的帖子
这个才是独立IP地址。
GMT+8, 2026-4-25 19:29 , Processed in 0.064726 second(s), 10 queries , Gzip On, MemCache On.
