12
返回列表 发新帖
楼主: HXS
请教,nginx如果要密码保护wp-admiin目录,该怎么写nginx.conf
 楼主| 发表于 2016-6-18 22:32:26 | 只看该作者
funders 发表于 2016-6-18 22:13
怎么可能  我就这样保护我的wp后台的啊,不能执行php我怎么登录呢
不行,我加了之后404
发表于 2016-6-18 22:38:14 | 只看该作者
HXS 发表于 2016-6-18 22:32
不行,我加了之后404
  1. server {
  2.     listen       80;
  3.     server_name www.xxxxxxx.com xxxxxxx.com;
  4.     return 301 https://$host$request_uri;
  5. }
  6. server
  7.     {
  8.         listen 443;
  9.         #listen [::]:80;
  10.         server_name www.xxxxxxx.com xxxxxxx.com;
  11.         index index.html index.htm index.php default.html default.htm default.php;
  12.         root  /data/www/xxxxxxx.com;
  13.         ssl on;
  14. #    ssl_certificate /etc/nginx/ssl/xxxxxxx.com_bundle.crt;
  15. #    ssl_certificate_key /etc/nginx/ssl/xxxxxxx.com.key;
  16.         ssl_certificate /data/ssl.xxxxxxx/xxxxxxx.com.crt;
  17.         ssl_certificate_key /data/ssl.xxxxxxx/xxxxxxx.com.key;
  18.         ssl_session_timeout 5m;
  19.         ssl_protocols TLSv1 TLSv1.1 TLSv1.2;
  20.         ssl_ciphers "EECDH+AESGCM:EDH+AESGCM:ECDHE-RSA-AES128-GCM-SHA256:AES256+EECDH:DHE-RSA-AES128-GCM-SHA256:AES256+EDH:ECDHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-SHA384:ECDHE-RSA-AES128-SHA256:ECDHE-RSA-AES256-SHA:ECDHE-RSA-AES128-SHA:DHE-RSA-AES256-SHA256:DHE-RSA-AES128-SHA256:DHE-RSA-AES256-SHA:DHE-RSA-AES128-SHA:ECDHE-RSA-DES-CBC3-SHA:EDH-RSA-DES-CBC3-SHA:AES256-GCM-SHA384:AES128-GCM-SHA256:AES256-SHA256:AES128-SHA256:AES256-SHA:AES128-SHA:DES-CBC3-SHA:HIGH:!aNULL:!eNULL:!EXPORT:!DES:!MD5:!PSK:!RC4";
  21.         ssl_prefer_server_ciphers on;
  22.         ssl_session_cache shared:SSL:10m;
  23.         ssl_dhparam /etc/ssl/certs/dhparam.pem;
  24.         include wordpress.conf;
  25.         #error_page   404   /404.html;
  26.          location /wp-admin/ {
  27.                 auth_basic "login:";
  28.                 auth_basic_user_file /data/www/xxxxxx.com.passwd;
  29.          }
  30.         location ~ [^/]\.php(/|$)
  31.         {
  32.             # comment try_files $uri =404; to enable pathinfo
  33.             try_files $uri =404;
  34.             fastcgi_pass  unix:/tmp/php-cgi.sock;
  35.             fastcgi_index index.php;
  36.             include fastcgi.conf;
  37.             #include pathinfo.conf;
  38.         }
  39.         location ~ .*\.(gif|jpg|jpeg|png|bmp|swf)$
  40.         {
  41.             expires      30d;
  42.         }
  43.         location ~ .*\.(js|css)?$
  44.         {
  45.             expires      12h;
  46.         }
  47.         access_log  /data/logs/xxxxxxx.com.access.log access;
  48.     }
我的站配置。lnmp1.2 /usr/local/nginx/conf/vhost/xxxxx.com.conf
自己对应修改看看
发表于 2016-6-18 22:42:05 | 只看该作者
自己对应修改看看
404的问题估计是
这段问题,yum apt安装的lnmp不能这样写的。你得先测试能解析php,再添加那个密码验证字段看看
 楼主| 发表于 2016-6-18 22:44:58 | 只看该作者
funders 发表于 2016-6-18 22:42
404的问题估计是
这段我没有复制你的,我按照php-fpm的默认设置来的
 楼主| 发表于 2016-6-18 22:45:58 | 只看该作者
难道跟我的开启的WP伪静态有关系??
 楼主| 发表于 2016-6-19 20:24:32 | 只看该作者
继续求一下
发表于 2016-6-19 22:14:49 | 只看该作者
现在CDN不是有指定目录白名单IP么?做个跳板不是很好么
GMT+8, 2026-5-8 01:34 , Processed in 0.058761 second(s), 9 queries , Gzip On, MemCache On.
