12
返回列表 发新帖
楼主: mengxuan123
请问budgetvm送的另外一个ip要怎么才能使用?
 楼主| 发表于 2016-5-30 17:56:20 | 只看该作者
Hello,
You have had this IP for 10 days now, and it's in the same range as xx.xx.xx.xx
I see this pinging fine from my side and off the network.Can you please provide an MTR report containing at least 300 pings from your location to IP xx.xx.xx.xxx?
For your reference, I've included a guide to generating an MTR report in various operating systems below.
When testing the connection from you to your server, use your server's IP address as the target IP address.
Windows:
1. Download WinMTR from http://winmtr.net/download-winmtr/
2. Extract the downloaded ZIP file.
3. Enter the created WinMTR directory.
4. Enter the WinMTR_x32 directory.
5. Doubleclick WinMTR
6. In the "Host" field, enter the target IP address.
7. Click Start.
8. Allow the program to process for at least five minutes (which should be 300 pings).
9. Click Stop.
10. Click "Copy Text to clipboard."
11. Paste (ctrl+v or right-click > paste) the generated MTR report into this ticket.
Mac:
1. Download mtr from http://rudix.org/packages/mtr.html .
2. Install MTR (Open the .PKG file and proceed through the prompts).
3. Open a Terminal (Applications > Utilities > Terminal)
4. Enter the following command then press enter: sudo /usr/local/sbin/mtr -r -c 300 target_IP_address
5. You will be prompted for your password. Type your password and press enter.
6. Once your password has been accepted, the MTR begins running. This will take around five minutes. Please note that there will not be any output generated until MTR has finished running.
7. Copy and paste the generated output into this ticket.
Linux:
1. Login as root.
2. If it's not already installed, install MTR. (MTR is included in most distribution's repositories. For Debian-based systems (including Ubuntu), run "apt-get install -y mtr". For Red Hat-based systems (including CentOS), run "yum install -y mtr".
4. Run the following command: mtr -r -c 300 target_IP_address
5. Copy and paste the generated output into this ticket.
Kind Regards,
Alexander A
BudgetVM Support
我请求换一个ip,但是收到这样的答复,请问这个要怎么破啊?
发表于 2016-5-30 17:58:23 来自手机 | 只看该作者
直接绑定使用
发表于 2016-5-30 20:34:47 | 只看该作者
装个WDCP吧  用着方便
发表于 2016-5-30 23:59:55 | 只看该作者
有两个IP吗
GMT+8, 2026-4-30 03:13 , Processed in 0.069199 second(s), 9 queries , Gzip On, MemCache On.
