123
返回列表 发新帖
楼主: Leaves
[疑问] VPSYOU的openvz vps谁用过
发表于 2010-10-2 01:21:48 | 只看该作者
回复 18# 的帖子
你的sosad.in主机是多少钱的啊
22#
 楼主| 发表于 2010-10-2 01:35:11 | 只看该作者
Linux 的X360   15刀,月付可以优惠10%...
我是年付的,那时可以优惠25%加双倍内存...
所以945元...
现在优惠幅度比以前小了,似乎也不会再降的样子,之前询问以后是否还有更高的优惠说是成本原因不会再高了...
其实...我之前是X540然后转X360的=3=
转了后发现硬盘和burst内存没变=W=
只是内存和流量改为了X360的...
到现在也没改XDD
23#
发表于 2010-10-2 01:47:47 | 只看该作者
回复 22# 的帖子
这个速度不那款openvz的快很多
24#
 楼主| 发表于 2010-10-2 02:09:44 | 只看该作者
居然测试那么久- -
都2点了...我五点半就要起床OTL
VPSYOU 的OPENVZ 128M内存
以下为测试结果...
睡了..
   Version 5.1.2                      Based on the Byte Magazine Unix Benchmark
   Multi-CPU version                  Version 5 revisions by Ian Smith,
                                      Sunnyvale, CA, USA
   December 22, 2007                  johantheghost at yahoo period com
1 x Dhrystone 2 using register variables  1 2 3 4 5 6 7 8 9 10
1 x Double-Precision Whetstone  1 2 3 4 5 6 7 8 9 10
1 x Execl Throughput  1 2 3
1 x File Copy 1024 bufsize 2000 maxblocks  1 2 3
1 x File Copy 256 bufsize 500 maxblocks  1 2 3
1 x File Copy 4096 bufsize 8000 maxblocks  1 2 3
1 x Pipe Throughput  1 2 3 4 5 6 7 8 9 10
1 x Pipe-based Context Switching  1 2 3 4 5 6 7 8 9 10
1 x Process Creation  1 2 3
1 x System Call Overhead  1 2 3 4 5 6 7 8 9 10
1 x Shell Scripts (1 concurrent)  1 2 3
1 x Shell Scripts (8 concurrent)  1 2 3
2 x Dhrystone 2 using register variables  1 2 3 4 5 6 7 8 9 10
2 x Double-Precision Whetstone  1 2 3 4 5 6 7 8 9 10
2 x Execl Throughput  1 2 3
2 x File Copy 1024 bufsize 2000 maxblocks  1 2 3
2 x File Copy 256 bufsize 500 maxblocks  1 2 3
2 x File Copy 4096 bufsize 8000 maxblocks  1 2 3
2 x Pipe Throughput  1 2 3 4 5 6 7 8 9 10
2 x Pipe-based Context Switching  1 2 3 4 5 6 7 8 9 10
2 x Process Creation  1 2 3
2 x System Call Overhead  1 2 3 4 5 6 7 8 9 10
2 x Shell Scripts (1 concurrent)  1 2 3
2 x Shell Scripts (8 concurrent)  1 2 3
   BYTE UNIX Benchmarks (Version 5.1.2)
   System: vpsyou.jia.im: GNU/Linux
   OS: GNU/Linux -- 2.6.18-194.8.1.el5.028stab070.4 -- #1 SMP Tue Aug 17 19:11:52 MSD 2010
   Machine: i686 (i386)
   Language: en_US.utf8 (charmap="UTF-8", collate="UTF-8")
   CPU 0: Intel(R) Xeon(R) CPU L3426 @ 1.87GHz (3733.4 bogomips)
          Hyper-Threading, x86-64, MMX, Physical Address Ext, SYSENTER/SYSEXIT, SYSCALL/SYSRET, Intel virtualization
   CPU 1: Intel(R) Xeon(R) CPU L3426 @ 1.87GHz (3733.4 bogomips)
   20:59:02 up  1:37,  1 user,  load average: 0.13, 0.03, 0.01; runlevel 3
Benchmark Run: Fri Oct 01 2010 20:59:02 - 21:30:29
2 CPUs in system; running 1 parallel copy of tests
Dhrystone 2 using register variables        4652209.9 lps   (10.0 s, 7 samples)
Double-Precision Whetstone                     1844.6 MWIPS (8.8 s, 7 samples)
Execl Throughput                               1673.0 lps   (29.4 s, 2 samples)
File Copy 1024 bufsize 2000 maxblocks        187606.0 KBps  (30.0 s, 2 samples)
File Copy 256 bufsize 500 maxblocks           52955.4 KBps  (30.0 s, 2 samples)
File Copy 4096 bufsize 8000 maxblocks        499007.4 KBps  (30.0 s, 2 samples)
Pipe Throughput                              346196.0 lps   (10.0 s, 7 samples)
Pipe-based Context Switching                  19082.9 lps   (10.0 s, 7 samples)
Process Creation                               5465.8 lps   (30.0 s, 2 samples)
Shell Scripts (1 concurrent)                   1695.2 lpm   (60.0 s, 2 samples)
Shell Scripts (8 concurrent)                    227.5 lpm   (60.1 s, 2 samples)
System Call Overhead                         272297.0 lps   (10.0 s, 7 samples)
Dhrystone 2 using register variables         116700.0    4652209.9    398.6
Double-Precision Whetstone                       55.0       1844.6    335.4
Execl Throughput                                 43.0       1673.0    389.1
File Copy 1024 bufsize 2000 maxblocks          3960.0     187606.0    473.8
File Copy 256 bufsize 500 maxblocks            1655.0      52955.4    320.0
File Copy 4096 bufsize 8000 maxblocks          5800.0     499007.4    860.4
Pipe Throughput                               12440.0     346196.0    278.3
Pipe-based Context Switching                   4000.0      19082.9     47.7
Process Creation                                126.0       5465.8    433.8
Shell Scripts (1 concurrent)                     42.4       1695.2    399.8
Shell Scripts (8 concurrent)                      6.0        227.5    379.2
System Call Overhead                          15000.0     272297.0    181.5
System Benchmarks Index Score                                         318.1
Benchmark Run: Fri Oct 01 2010 21:30:29 - 22:05:08
2 CPUs in system; running 2 parallel copies of tests
Dhrystone 2 using register variables        4392613.6 lps   (10.0 s, 7 samples)
Double-Precision Whetstone                     3702.1 MWIPS (9.3 s, 7 samples)
Execl Throughput                               1634.2 lps   (29.5 s, 2 samples)
File Copy 1024 bufsize 2000 maxblocks        193571.1 KBps  (30.0 s, 2 samples)
File Copy 256 bufsize 500 maxblocks           55104.3 KBps  (30.0 s, 2 samples)
File Copy 4096 bufsize 8000 maxblocks        490773.3 KBps  (30.0 s, 2 samples)
Pipe Throughput                              377690.8 lps   (10.0 s, 7 samples)
Pipe-based Context Switching                 121024.7 lps   (10.0 s, 7 samples)
Process Creation                               5284.4 lps   (30.0 s, 2 samples)
Shell Scripts (1 concurrent)                   1642.6 lpm   (60.0 s, 2 samples)
Shell Scripts (8 concurrent)                    230.7 lpm   (60.2 s, 2 samples)
System Call Overhead                         283358.9 lps   (10.0 s, 7 samples)
Dhrystone 2 using register variables         116700.0    4392613.6    376.4
Double-Precision Whetstone                       55.0       3702.1    673.1
Execl Throughput                                 43.0       1634.2    380.1
File Copy 1024 bufsize 2000 maxblocks          3960.0     193571.1    488.8
File Copy 256 bufsize 500 maxblocks            1655.0      55104.3    333.0
File Copy 4096 bufsize 8000 maxblocks          5800.0     490773.3    846.2
Pipe Throughput                               12440.0     377690.8    303.6
Pipe-based Context Switching                   4000.0     121024.7    302.6
Process Creation                                126.0       5284.4    419.4
Shell Scripts (1 concurrent)                     42.4       1642.6    387.4
Shell Scripts (8 concurrent)                      6.0        230.7    384.4
System Call Overhead                          15000.0     283358.9    188.9
System Benchmarks Index Score                                         394.9
25#
 楼主| 发表于 2010-10-2 02:10:08 | 只看该作者
原帖由 l12ab 于 2010-10-2 01:47 发表
这个速度不那款openvz的快很多
不过价格也要贵很多=w=
26#
发表于 2010-10-2 10:46:16 | 只看该作者
xen 是那个机房的啊
27#
发表于 2010-10-2 10:52:42 | 只看该作者
我在用呢
28#
 楼主| 发表于 2010-10-2 11:54:22 | 只看该作者
我XEN的是PR的…
不过最近抽风很多但不怎么影响访问…
T2如果有50M就好了…可惜才10
GMT+8, 2026-4-30 03:29 , Processed in 0.068826 second(s), 9 queries , Gzip On, MemCache On.
