CeraNetworks网络延迟测速工具IP归属甄别
12
返回列表 发新帖
楼主: tom
测试达拉斯机房 路线
发表于 2010-10-2 10:47:54 | 只看该作者
C:\>ping 96.44.142.5
正在 Ping 96.44.142.5 具有 32 字节的数据:
来自 96.44.142.5 的回复: 字节=32 时间=318ms TTL=49
来自 96.44.142.5 的回复: 字节=32 时间=319ms TTL=49
来自 96.44.142.5 的回复: 字节=32 时间=312ms TTL=49
96.44.142.5 的 Ping 统计信息:
往返行程的估计时间(以毫秒为单位):
    最短 = 312ms,最长 = 319ms,平均 = 317ms
C:\>tracert 96.44.142.5
通过最多 30 个跃点跟踪到 96.44.142.5 的路由
  1    27 ms    28 ms    27 ms  [隐藏一下]
  2    28 ms    27 ms    27 ms  [隐藏一下]
  3    28 ms    29 ms    40 ms  [隐藏一下]
  4    29 ms    30 ms    29 ms  119.145.47.82
  5    97 ms    95 ms    94 ms  202.97.34.205
  6    88 ms    88 ms    91 ms  202.97.60.62
  7   255 ms   254 ms   254 ms  202.97.51.90
  8   264 ms   263 ms   261 ms  202.97.50.34
  9   420 ms   245 ms   244 ms  te6-3-10G.ar5.LAX1.gblx.net [64.208.27.169]
10   294 ms   295 ms   298 ms  customer.TenGigabitEthernet2-3.ar2.DAL2.gblx.net [64.215.28.206]
11   301 ms   302 ms   302 ms  204.26.60.118
12   296 ms   293 ms   296 ms  204.26.63.150
13   307 ms   309 ms   308 ms  96.44.142.5
跟踪完成。
以上为深圳电信ADSL测试结果,AM 10:45
发表于 2010-10-2 11:11:05 | 只看该作者
Pinging 96.44.142.5 with 32 bytes of data:
Reply from 96.44.142.5: bytes=32 time=219ms TTL=48
Reply from 96.44.142.5: bytes=32 time=220ms TTL=48
Reply from 96.44.142.5: bytes=32 time=221ms TTL=48
Reply from 96.44.142.5: bytes=32 time=237ms TTL=48
Reply from 96.44.142.5: bytes=32 time=241ms TTL=48
浙江电信ADSL 2M
发表于 2010-10-2 12:01:25 | 只看该作者
Microsoft Windows XP [版本 5.1.2600]
(C) 版权所有 1985-2001 Microsoft Corp.
C:\Documents and Settings\Administrator>ping 96.44.142.5 -t
Reply from 96.44.142.5: bytes=32 time=322ms TTL=46
Reply from 96.44.142.5: bytes=32 time=321ms TTL=46
Reply from 96.44.142.5: bytes=32 time=320ms TTL=46
Ping statistics for 96.44.142.5:
    Packets: Sent = 15, Received = 15, Lost = 0 (0% loss),
    Minimum = 320ms, Maximum = 322ms, Average = 321ms
Control-C
发表于 2010-10-11 16:06:53 | 只看该作者
冒个泡~~
Reply from 96.44.142.5: bytes=32 time=190ms TTL=48
Reply from 96.44.142.5: bytes=32 time=192ms TTL=48
Reply from 96.44.142.5: bytes=32 time=191ms TTL=48
发表于 2010-10-11 16:10:33 | 只看该作者
1     3 ms     2 ms     2 ms
  2     2 ms     2 ms     2 ms
  3     2 ms     2 ms     2 ms
  4     3 ms     2 ms     2 ms  118.84.1.1
  5    12 ms    15 ms    12 ms  202.97.39.173
  6    14 ms    12 ms    11 ms  202.97.33.186
  7    13 ms    13 ms    13 ms  202.97.33.54
  8   161 ms   160 ms   161 ms  202.97.50.126
  9   154 ms   154 ms   154 ms  202.97.50.78
10   171 ms   171 ms   172 ms  218.30.54.114
11   220 ms   220 ms   221 ms  customer.TenGigabitEthernet2-3.ar2.DAL2.gblx.net
[64.215.28.206]
12   222 ms   221 ms   222 ms  204.26.60.114
13   195 ms   195 ms   196 ms  204.26.63.150
[ 本帖最后由 疯子拿把枪 于 2010-10-11 16:11 编辑 ]
发表于 2010-10-12 16:39:19 | 只看该作者
发表于 2010-10-12 16:42:11 | 只看该作者
发表于 2010-10-12 17:54:17 | 只看该作者
96.44.的好象我有很多IP了
96.44.142.5 这个是新的机房的IP?不是现在用的这些?
湖北电信2M 小水管
Reply from 96.44.142.5: bytes=32 time=262ms TTL=49
Reply from 96.44.142.5: bytes=32 time=261ms TTL=49
Reply from 96.44.142.5: bytes=32 time=271ms TTL=49
Reply from 96.44.142.5: bytes=32 time=264ms TTL=49
Reply from 96.44.142.5: bytes=32 time=263ms TTL=49
Reply from 96.44.142.5: bytes=32 time=268ms TTL=49
Reply from 96.44.142.5: bytes=32 time=272ms TTL=49
Reply from 96.44.142.5: bytes=32 time=270ms TTL=49
GMT+8, 2026-1-14 10:54 , Processed in 0.060289 second(s), 9 queries , Gzip On, MemCache On.
