12
返回列表 发新帖
楼主: jeeve
[Windows VPS] letsencrypt公测了,谁发个完整版的教程?
 楼主| 发表于 2015-12-6 10:07:26 | 只看该作者
395183830 发表于 2015-12-6 01:05
yum install gcc zlib zlib-devel openssl openssl-devel
wget http://www.python.org/ftp/python/2.7.3/Py ...
./letsencrypt-auto: line 166: virtualenv: command not found
怎么解决?
发表于 2015-12-6 12:22:39 | 只看该作者
怎么解决?
cd /root/Python-2.7.3
./configure
make && make install
重新编译
cd /root
wget https://raw.github.com/pypa/pip/master/contrib/get-pip.py
python get-pip.py
安装pip
pip install virtualenv
安装virtualenv
最后签证书
 楼主| 发表于 2015-12-6 15:19:55 | 只看该作者
./configure
Failed building wheel for cryptography
Command "/root/.local/share/letsencrypt/bin/python2.7 -c "import setuptools, tokenize;__file__='/tmp/pip-build-EehjSr/cryptography/setup.py';exec(compile(getattr(tokenize, 'open', open)(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" install --record /tmp/pip-GspyCj-record/install-record.txt --single-version-externally-managed --compile --install-headers /root/.local/share/letsencrypt/include/site/python2.7/cryptography" failed with error code 1 in /tmp/pip-build-EehjSr/cryptography
发表于 2015-12-6 17:28:06 | 只看该作者
jeeve 发表于 2015-12-5 22:24
Centos 6 按照教程不行啊
centos 6会提示python版本过低,建议升级到2.7+
10楼有升级教程
发表于 2015-12-6 20:40:54 | 只看该作者
Command "/root/.local/share/letsencrypt/bin/python2.7 -c "i ...
后面不会了。。问度娘怎么解决吧
GMT+8, 2026-4-15 21:31 , Processed in 0.063136 second(s), 7 queries , Gzip On, MemCache On.
