123
返回列表 发新帖
楼主: bluesky
[经验] 注意:84 的高级VPS是骗人滴! ( PREMIUM VPS )
 楼主| 发表于 2010-9-27 18:42:21 | 只看该作者
楼上滴~
ticket 早发过了~
84 打死也不承认没有爆发内存~
不管是 free -m 还是 top 或是探针查看...通通是512mb~
没见过VPS配置给 1G Burstable Ram
但是 Burstable Ram 却是使用不到...还让你查不到滴~
不信邪的人 ... 可以买各高级vps试试~
这是84滴回答~
You can see exactly how much memory you have available by looking at /proc/user_beancounters
Your burst memory is called 'privvmpages' and is measured in 4k blocks, 'barrier' is the max you can use right now.
The oomguarpages is your guaranteed memory, in 4k blocks. The barrier is the max you can allocate when the system is all out of extra burst memory (should never happen, we under utilize our hardware to keep it speedy).
The system will only report guaranteed memory for safety, its not recommended you use burst for services. The free command will show you how much 'safe' guaranteed memory you have left.
GMT+8, 2026-4-30 10:11 , Processed in 0.059257 second(s), 8 queries , Gzip On, MemCache On.
