12
返回列表 发新帖
楼主: hcw1588
编译出错,求解!!各种求!!
 楼主| 发表于 2013-7-31 18:07:54 | 只看该作者
SKIDROW 发表于 2013-7-31 17:57
libcap libssl expat,装这三个看看。
又出现
libIpcIo.a(IpcIoFile.o):/root/squid-3.3.8/src/../src/ipc/AtomicWord.h:45: more undefined references to `__sync_fetch_and_add_4' follow
libIpcIo.a(IpcIoFile.o): In function `Ipc::Atomic::WordT<int>:perator+=(int)':
/root/squid-3.3.8/src/../src/ipc/AtomicWord.h:29: undefined reference to `__sync_add_and_fetch_4'
libIpcIo.a(IpcIoFile.o): In function `Ipc::Atomic::WordT<int>::get() const':
/root/squid-3.3.8/src/../src/ipc/AtomicWord.h:45: undefined reference to `__sync_fetch_and_add_4'
libIpcIo.a(IpcIoFile.o): In function `Ipc::Atomic::WordT<int>::swap_if(int, int)':
/root/squid-3.3.8/src/../src/ipc/AtomicWord.h:36: undefined reference to `__sync_bool_compare_and_swap_4'
libIpcIo.a(IpcIoFile.o): In function `Ipc::Atomic::WordT<int>:perator-=(int)':
/root/squid-3.3.8/src/../src/ipc/AtomicWord.h:30: undefined reference to `__sync_sub_and_fetch_4'
ipc/.libs/libipc.a(Queue.o): In function `Ipc::Atomic::WordT<int>::swap_if(int, int)':
/root/squid-3.3.8/src/ipc/../../src/ipc/AtomicWord.h:36: undefined reference to `__sync_bool_compare_and_swap_4'
/root/squid-3.3.8/src/ipc/Queue.cc:250: undefined reference to `__sync_bool_compare_and_swap_4'
ipc/.libs/libipc.a(ReadWriteLock.o): In function `Ipc::Atomic::WordT<int>:perator--(int)':
/root/squid-3.3.8/src/ipc/../../src/ipc/AtomicWord.h:34: undefined reference to `__sync_fetch_and_sub_4'
ipc/.libs/libipc.a(ReadWriteLock.o): In function `Ipc::Atomic::WordT<int>:perator+=(int)':
/root/squid-3.3.8/src/ipc/../../src/ipc/AtomicWord.h:29: undefined reference to `__sync_add_and_fetch_4'
ipc/.libs/libipc.a(ReadWriteLock.o): In function `Ipc::Atomic::WordT<int>::get() const':
/root/squid-3.3.8/src/ipc/../../src/ipc/AtomicWord.h:45: undefined reference to `__sync_fetch_and_add_4'
ipc/.libs/libipc.a(ReadWriteLock.o): In function `Ipc::Atomic::WordT<int>:perator-=(int)':
/root/squid-3.3.8/src/ipc/../../src/ipc/AtomicWord.h:30: undefined reference to `__sync_sub_and_fetch_4'
ipc/.libs/libipc.a(ReadWriteLock.o): In function `Ipc::Atomic::WordT<int>:perator++(int)':
/root/squid-3.3.8/src/ipc/../../src/ipc/AtomicWord.h:33: undefined reference to `__sync_fetch_and_add_4'
ipc/.libs/libipc.a(StoreMap.o): In function `Ipc::Atomic::WordT<int>::get() const':
ipc/.libs/libipc.a(StoreMap.o): In function `Ipc::Atomic::WordT<int>:perator-=(int)':
ipc/.libs/libipc.a(StoreMap.o): In function `Ipc::Atomic::WordT<unsigned char>::get() const':
/root/squid-3.3.8/src/ipc/../../src/ipc/AtomicWord.h:45: undefined reference to `__sync_fetch_and_add_1'
ipc/.libs/libipc.a(StoreMap.o): In function `Ipc::Atomic::WordT<int>::operator+=(int)':
ipc/.libs/libipc.a(Pages.o): In function `Ipc::Atomic::WordT<int>::get() const':
ipc/.libs/libipc.a(PagePool.o): In function `Ipc::Atomic::WordT<int>::get() const':
ipc/.libs/libipc.a(PagePool.o): In function `Ipc::Atomic::WordT<int>::operator-=(int)':
ipc/.libs/libipc.a(PagePool.o): In function `Ipc::Atomic::WordT<int>::operator+=(int)':
ipc/.libs/libipc.a(PageStack.o): In function `Ipc::Atomic::WordT<int>::operator-=(int)':
ipc/.libs/libipc.a(PageStack.o): In function `Ipc::Atomic::WordT<int>::get() const':
ipc/.libs/libipc.a(PageStack.o): In function `Ipc::Atomic::WordT<unsigned int>::fetchAndAnd(unsigned int)':
/root/squid-3.3.8/src/ipc/../../src/ipc/AtomicWord.h:39: undefined reference to `__sync_fetch_and_and_4'
ipc/.libs/libipc.a(PageStack.o): In function `Ipc::Atomic::WordT<int>::swap_if(int, int)':
ipc/.libs/libipc.a(PageStack.o): In function `Ipc::Atomic::WordT<int>::operator+=(int)':
ipc/.libs/libipc.a(PageStack.o): In function `Ipc::Atomic::WordT<unsigned int>::swap_if(unsigned int, unsigned int)':
/root/squid-3.3.8/src/ipc/mem/PageStack.cc:86: undefined reference to `__sync_bool_compare_and_swap_4'
collect2: ld returned 1 exit status
libtool: link: rm -f ".libs/squidS.o"
make[3]: *** [squid] Error 1
make[3]: Leaving directory `/root/squid-3.3.8/src'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/root/squid-3.3.8/src'
make[1]: *** [all] Error 2
make[1]: Leaving directory `/root/squid-3.3.8/src'
make: *** [all-recursive] Error 1
发表于 2013-7-31 18:09:50 | 只看该作者
hcw1588 发表于 2013-7-31 18:07
又出现
libIpcIo.a(IpcIoFile.o):/root/squid-3.3.8/src/../src/ipc/AtomicWord.h:45: more undefined re ...
我估计是编译器太老了……CentOS5好像只是gcc4.1……
 楼主| 发表于 2013-7-31 18:14:39 | 只看该作者
你是一路成功的吧?
发表于 2013-7-31 18:18:30 | 只看该作者
hcw1588 发表于 2013-7-31 18:14
你是一路成功的吧?
一次性成功了,不然你装个gcc4.4看看。
 楼主| 发表于 2013-7-31 18:23:00 | 只看该作者
还有squid3.3的init.d启动脚本写过吗,网上找到的都木用。。
 楼主| 发表于 2013-7-31 19:38:04 | 只看该作者
可以start不可以stop
#!/bin/bash
# squid     This shell script takes care of starting and stopping
#       Squid Internet Object Cache
# chkconfig: - 90 25
# description: Squid - Internet Object Cache. Internet object caching is
#   a way to store requested Internet objects (i.e., data available
#   via the HTTP, FTP, and gopher protocols) on a system closer to the
#   requesting site than to the source. Web browsers can then use the
#   local Squid cache as a proxy HTTP server, reducing access time as
#   well as bandwidth consumption.
# pidfile: /var/run/squid.pid
# config: /etc/squid/squid.conf
PATH=/usr/bin:/sbin:/bin:/usr/sbin
export PATH
# Source function library.
. /etc/rc.d/init.d/functions
# Source networking configuration.
. /etc/sysconfig/network
# don't raise an error if the config file is incomplete
# set defaults instead:
SQUID_OPTS=${SQUID_OPTS:-"-D"}
SQUID_PIDFILE_TIMEOUT=${SQUID_PIDFILE_TIMEOUT:-20}
SQUID_SHUTDOWN_TIMEOUT=${SQUID_SHUTDOWN_TIMEOUT:-100}
# determine the name of the squid binary
[ -f /usr/local/squid/sbin/squid ] && SQUID=/usr/local/squid/sbin/squid && SQUID_id=squid
prog="$SQUID"
# determine which one is the cache_swap directory
CACHE_SWAP=`sed -e 's/#.*//g' /usr/local/squid/etc/squid.conf |
    grep cache_dir |  awk '{ print $3 }'`
[ -z "$CACHE_SWAP" ] && CACHE_SWAP=/usr/local/squid/var/cache
RETVAL=0
start() {
        #check if the squid conf file is present
        if [ ! -f /usr/local/squid/etc/squid.conf ]; then
            echo "Configuration file /usr/local/squid/etc/squid.conf missing" 1>&2
            exit 6
        fi
        . /etc/sysconfig/squid
        # don't raise an error if the config file is incomplete.
        if [ -z "$SQUID" ]; then
                echo "Insufficient privilege" 1>&2
                exit 4
        fi
        for adir in $CACHE_SWAP; do
        if [ ! -d $adir/00 ]; then
         echo -n "init_cache_dir $adir... "
         $SQUID -z -F -D >> /usr/local/squid/var/logs/squid.out 2>&1
    fi
    done
    echo -n $"Starting $prog: "
    $SQUID $SQUID_OPTS >> /usr/local/squid/var/logs/squid.out 2>&1
    RETVAL=$?
    if [ $RETVAL -eq 0 ]; then
       timeout=0;
       while : ; do
          [ ! -f /usr/local/squid/var/run/squid.pid ] || break
      if [ $timeout -ge $SQUID_PIDFILE_TIMEOUT ]; then
         RETVAL=1
         break
      fi
      sleep 1 && echo -n "."
      timeout=$((timeout+1))
       done
    fi
    [ $RETVAL -eq 0 ] && touch /var/lock/subsys/$SQUID_uid
    [ $RETVAL -eq 0 ] && echo_success
    [ $RETVAL -ne 0 ] && echo_failure
    echo
    return $RETVAL
stop() {
    echo -n  $"Stopping $prog: "
    $SQUID -k check >> /usr/local/squid/var/logs/squid.out 2>&1
    RETVAL=$?
    if [ $RETVAL -eq 0 ] ; then
        $SQUID -k shutdown &
        rm -f /var/lock/subsys/$SQUID_id
    timeout=0
    while : ; do
        [ -f /usr/local/squid/var/run/squid.pid ] || break
        if [ $timeout -ge $SQUID_SHUTDOWN_TIMEOUT ]; then
            echo
            return 1
        fi
        sleep 2 && echo -n "."
        timeout=$((timeout+2))
        done
    echo_success
    echo
    else
        echo_failure
    if [ ! -e /var/lock/subsys/$SQUID_id ]; then
        RETVAL=0
    fi
    echo
    fi
    return $RETVAL
reload() {
    $SQUID $SQUID_OPTS -k reconfigure
restart() {
    stop
    start
condrestart() {
    [ -e /var/lock/subsys/squid_id ] && restart || :
rhstatus() {
    status $SQUID_id && $SQUID -k check
probe() {
    return 0
case "$1" in
start)
    start
stop)
    stop
reload)
    reload
restart)
    restart
condrestart)
    condrestart
status)
    rhstatus
probe)
    exit 0
    echo $"Usage: $0 {start|stop|status|reload|restart|condrestart}"
    exit 2
esac
exit $?
发表于 2013-7-31 19:45:53 | 只看该作者
hcw1588 发表于 2013-7-31 19:38
可以start不可以stop
#!/bin/bash
还是像PHP5.3那样发信号得了
 楼主| 发表于 2013-7-31 20:09:35 | 只看该作者
SKIDROW 发表于 2013-7-31 19:45
还是像PHP5.3那样发信号得了
额。。。好吧,刚刚修改了部分然后就成功了。。。
GMT+8, 2026-4-16 15:38 , Processed in 0.060263 second(s), 8 queries , Gzip On, MemCache On.
