查看: 1203|回复: 21
[特价VPS] 出ColoCrossing洛杉矶独服
发表于 2026-4-8 16:02:33 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
机器配置为:E3-1271 v3/32G/1T SSD/40T流量/洛杉矶
年付145刀,上周活动购买,还有一年到期。改邮箱出,1150元。需要的私信或签名TG联系
帖子没有标记已出,就是还有货
  3. #                     v2025-04-20                    #
  6. Thu Apr  2 02:13:59 PM CST 2026
  7. Basic System Information:
  9. Uptime     : 0 days, 0 hours, 2 minutes
  10. Processor  : Intel(R) Xeon(R) CPU E3-1271 v3 [url=home.php?mod=space&uid=175]@[/url] 3.60GHz
  11. CPU cores  : 8 @ 2795.822 MHz
  12. AES-NI     : ✔ Enabled
  13. VM-x/AMD-V : ✔ Enabled
  14. RAM        : 31.3 GiB
  15. Swap       : 8.0 GiB
  16. Disk       : 879.1 GiB
  17. Distro     : Ubuntu 24.04.4 LTS
  18. Kernel     : 6.8.0-107-generic
  19. VM Type    : NONE
  20. IPv4/IPv6  : ✔ Online / ❌ Offline
  21. IPv4 Network Information:
  23. ISP        : HostPapa
  24. ASN        : AS36352 HostPapa
  25. Host       : HostPapa
  26. Location   : Los Angeles, California (CA)
  27. Country    : United States
  28. fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/sda3):
  32. Read       | 168.61 MB/s  (42.1k) | 223.51 MB/s   (3.4k)
  33. Write      | 169.06 MB/s  (42.2k) | 224.69 MB/s   (3.5k)
  34. Total      | 337.67 MB/s  (84.4k) | 448.20 MB/s   (7.0k)
  38. Read       | 212.40 MB/s    (414) | 230.16 MB/s    (224)
  39. Write      | 223.68 MB/s    (436) | 245.49 MB/s    (239)
  40. Total      | 436.08 MB/s    (850) | 475.65 MB/s    (463)
  45. Clouvider       | London, UK (10G)          | 827 Mbits/sec   | 243 Mbits/sec   | 154 ms
  46. Eranium         | Amsterdam, NL (100G)      | 823 Mbits/sec   | 624 Mbits/sec   | 153 ms
  47. Uztelecom       | Tashkent, UZ (10G)        | 579 Mbits/sec   | 262 Mbits/sec   | 239 ms
  48. Leaseweb        | Singapore, SG (10G)       | 724 Mbits/sec   | 690 Mbits/sec   | 202 ms
  49. Clouvider       | Los Angeles, CA, US (10G) | 938 Mbits/sec   | 941 Mbits/sec   | 0.394 ms
  50. Leaseweb        | NYC, NY, US (10G)         | 900 Mbits/sec   | 673 Mbits/sec   | 77.3 ms
  51. Edgoo           | Sao Paulo, BR (1G)        | 801 Mbits/sec   | 303 Mbits/sec   | 166 ms
  52. Geekbench 5 Benchmark Test:
  53. ---------------------------------
  54. Test            | Value
  55.                 |
  56. Single Core     | 1059
  57. Multi Core      | 3967
  58. Full Test       | https://browser.geekbench.com/v5/cpu/24219360
  59. Geekbench 6 Benchmark Test:
  60. ---------------------------------
  61. Test            | Value
  62.                 |
  63. Single Core     | 1335
  64. Multi Core      | 4388
  65. Full Test       | https://browser.geekbench.com/v6/cpu/17419535
  66. YABS completed in 13 min 8 sec
 楼主| 发表于 2026-4-8 16:09:09 | 只看该作者
  1. ════════════════════════════════════════════════════════════════════════════════
  2.                        System Hardware Information Report
  3. ════════════════════════════════════════════════════════════════════════════════
  4. ┌─ System Information
  5. ├────────────────────
  6. │ Hostname            : host
  7. │ Operating System    : Ubuntu 24.04.4 LTS
  8. │ Kernel Version      : 6.8.0-107-generic
  9. │ System Uptime       : up 18 minutes
  10. └──────────────────────────────────────────────────
  11. ┌─ CPU Information
  12. ├─────────────────
  13. │ Model               : Intel(R) Xeon(R) CPU E3-1271 v3 [url=home.php?mod=space&uid=175]@[/url] 3.60GHz
  14. │ Cores               : 4
  15. │ Threads             : 8
  16. │ Frequency           : 3599.591 MHz
  17. │ Cache               : 8192 KB
  18. │ Usage               : 0%
  19. │ CPU Temperature     : +24.0°C
  20. └──────────────────────────────────────────────────
  21. ┌─ Memory (RAM) Information
  22. ├──────────────────────────
  23. │ Total               : 31.30 GB
  24. │ Used                : 665Mi
  25. │ Available           : 30.65 GB
  26. │ Memory Modules:
  27. ├────────────────────────────────────────────────────────────────────────────────────────────────────┤
  28. │ Size     │ Type   │ Frequency    │ Manufacturer │ Serial Number   │ Model                │
  29. ├────────────────────────────────────────────────────────────────────────────────────────────────────┤
  30. │ 8 GB     │ DDR3   │ 1600 MT/s    │ Hynix/Hyunda │ 310F36B5        │ HMT41GE7BFR8A-PB     │
  31. │ 8 GB     │ DDR3   │ 1600 MT/s    │ Hynix/Hyunda │ 310F3527        │ HMT41GE7BFR8A-PB     │
  32. │ 8 GB     │ DDR3   │ 1600 MT/s    │ Hynix/Hyunda │ 310F24AF        │ HMT41GE7BFR8A-PB     │
  33. │ 8 GB     │ DDR3   │ 1600 MT/s    │ Hynix/Hyunda │ 310F3687        │ HMT41GE7BFR8A-PB     │
  34. └────────────────────────────────────────────────────────────────────────────────────────────────────┘
  35. └──────────────────────────────────────────────────
  36. ┌─ Disk Drive Information
  37. ├────────────────────────
  38. │ /dev/sda3       878G   11G  822G   2% /
  39. │ /dev/sda2       2.0G  104M  1.7G   6% /boot
  40. │ ═══════════════════════════════════════════════════
  41. │ Other Disks (NVMe / SATA / SAS)
  42. │ ═══════════════════════════════════════════════════
  43. │ ═══ /dev/sda ═══
  44. │   Basic Info: 894.3G INTEL SSDSC2KG96 ATA
  45. │   SMART Status: PASSED
  46. │   Power On Hours: 31019 hours
  47. │   Total Reads: 5.22 GB
  48. │   Total Writes: 484.93 MB
  49. │   Temperature: 24°C
  50. │   Reallocated Sectors: 0
  51. │   Pending Sectors: 0
  52. │   Reported Uncorrectable: 0
  53. └──────────────────────────────────────────────────
  54. ┌─ RAID Controller Information
  55. ├─────────────────────────────
  56. │ Status              : Not detected
  57. └──────────────────────────────────────────────────
  58. ┌─ Network Interface Information
  59. ├───────────────────────────────
  60. │ ═══ eno1 ═══
  61. │   Model: Intel Corporation I350 Gigabit Network Connection (rev 01)
  62. │   Status: UP
  63. │   IPv4: 69.12.XX.XX/30
  64. │   IPv6: fe80::XX:XX::/64
  65. │   MAC Address: 0c:c4:7a:XX:XX:XX
  66. │   Speed: 1000 Mbps
  67. │   Duplex: full
  68. │   Link Detected: Yes
  69. │   RX: 5.15 GB
  70. │   TX: 6.95 GB
  71. │ ═══ eno2 ═══
  72. │   Model: Intel Corporation I350 Gigabit Network Connection (rev 01)
  73. │   Status: DOWN
  74. │   MAC Address: 0c:c4:7a:XX:XX:XX
  75. │   Link Detected: No
  76. │   RX: 0 GB
  77. │   TX: 0 GB
  78. └──────────────────────────────────────────────────
  79. ┌─ Graphics Card Information
  80. ├───────────────────────────
  81. │ Graphics Cards (PCI):
  82. │   03:00.0 VGA compatible controller: ASPEED Technology, Inc. ASPEED Graphics Family (rev 30)
  83. │ Display Hardware Summary:
  84. │   ==========================================================
  85. │   /0/100/1c/0/0        /dev/fb0   display        ASPEED Graphics Family
  86. └──────────────────────────────────────────────────
  87. ┌─ Motherboard Information
  88. ├─────────────────────────
  89. │ Vendor              : Supermicro
  90. │ Model               : X10SLE-DF
  91. │ Version             : 1.01
  92. │ BIOS Vendor         : American Megatrends Inc.
  93. │ BIOS Version        : 3.0
  94. └──────────────────────────────────────────────────
  95. Report generation completed!
  96. Generated on: Thu Apr  2 02:30:28 PM CST 2026
 楼主| 发表于 2026-4-8 23:42:40 | 只看该作者
收的老板请联系
发表于 7 天前 | 只看该作者
便宜货的垃圾路线现在炸穿,果然还是贵的套餐线路好
 楼主| 发表于 7 天前 | 只看该作者
啥意思
发表于 7 天前 | 只看该作者
ccs 10刀每年的洛杉矶现在线路拉胯,延迟上1000了,你这个贵的看着线路还行
encounter 发表于 2026-4-9 10:58
ccs 10刀每年的洛杉矶现在线路拉胯,延迟上1000了,你这个贵的看着线路还行 ...
你那个是VPS,这个是独服。VPS现在是竞技场
发表于 7 天前 | 只看该作者
好鸡,楼下收
发表于 7 天前 | 只看该作者
多少个IP的?
GMT+8, 2026-4-16 15:51 , Processed in 0.067396 second(s), 9 queries , Gzip On, MemCache On.
