12
返回列表 发新帖
楼主: 绿豆
特欧科技宁波电信399元节日特惠套餐8C/8G/40G+100G/100Mbps测评
发表于 2025-5-19 11:49:21 | 只看该作者
好家伙 特欧这波背刺老用户啊 刚买的2C2G瞬间不香了 8C8G才399还带100G数据盘 这价格隔壁老王看了都直呼内行 晚上蹲个测评图看看IO和晚高峰表现 要是稳的话直接冲爆 反正内网互通组个集群美滋滋 常州那款16C16G也香就是带宽砍半有点蛋疼 不过跑编译应该够用了
发表于 2025-5-19 11:51:29 | 只看该作者
糟糕的鲍勃 发表于 2025-5-18 18:48
国内机器肯定不需要 出事了我帮你坐牢就行
啥时候有优惠
 楼主| 发表于 2025-5-19 12:35:34 | 只看该作者
  1. Benchmark Run: Mon May 19 2025 11:14:27 - 11:42:31
  2. 8 CPUs in system; running 1 parallel copy of tests
  3. Dhrystone 2 using register variables       40369119.9 lps   (10.0 s, 7 samples)
  4. Double-Precision Whetstone                     6054.6 MWIPS (9.9 s, 7 samples)
  5. Execl Throughput                               2642.0 lps   (30.0 s, 2 samples)
  6. File Copy 1024 bufsize 2000 maxblocks       1041033.4 KBps  (30.0 s, 2 samples)
  7. File Copy 256 bufsize 500 maxblocks          280554.5 KBps  (30.0 s, 2 samples)
  8. File Copy 4096 bufsize 8000 maxblocks       2738141.4 KBps  (30.0 s, 2 samples)
  9. Pipe Throughput                             1602911.7 lps   (10.0 s, 7 samples)
  10. Pipe-based Context Switching                  66334.1 lps   (10.0 s, 7 samples)
  11. Process Creation                               5716.0 lps   (30.0 s, 2 samples)
  12. Shell Scripts (1 concurrent)                   8746.8 lpm   (60.0 s, 2 samples)
  13. Shell Scripts (8 concurrent)                   3947.9 lpm   (60.0 s, 2 samples)
  14. System Call Overhead                        1396458.7 lps   (10.0 s, 7 samples)
  15. System Benchmarks Index Values               BASELINE       RESULT    INDEX
  16. Dhrystone 2 using register variables         116700.0   40369119.9   3459.2
  17. Double-Precision Whetstone                       55.0       6054.6   1100.8
  18. Execl Throughput                                 43.0       2642.0    614.4
  19. File Copy 1024 bufsize 2000 maxblocks          3960.0    1041033.4   2628.9
  20. File Copy 256 bufsize 500 maxblocks            1655.0     280554.5   1695.2
  21. File Copy 4096 bufsize 8000 maxblocks          5800.0    2738141.4   4720.9
  22. Pipe Throughput                               12440.0    1602911.7   1288.5
  23. Pipe-based Context Switching                   4000.0      66334.1    165.8
  24. Process Creation                                126.0       5716.0    453.7
  25. Shell Scripts (1 concurrent)                     42.4       8746.8   2062.9
  26. Shell Scripts (8 concurrent)                      6.0       3947.9   6579.9
  27. System Call Overhead                          15000.0    1396458.7    931.0
  28.        ========
  29. System Benchmarks Index Score                                        1407.2
  30. ------------------------------------------------------------------------
  31. Benchmark Run: Mon May 19 2025 11:42:31 - 12:10:37
  32. 8 CPUs in system; running 8 parallel copies of tests
  33. Dhrystone 2 using register variables      321625610.5 lps   (10.0 s, 7 samples)
  34. Double-Precision Whetstone                    48357.0 MWIPS (9.9 s, 7 samples)
  35. Execl Throughput                              17297.0 lps   (29.7 s, 2 samples)
  36. File Copy 1024 bufsize 2000 maxblocks       1395637.5 KBps  (30.0 s, 2 samples)
  37. File Copy 256 bufsize 500 maxblocks          408910.1 KBps  (30.0 s, 2 samples)
  38. File Copy 4096 bufsize 8000 maxblocks       3826922.0 KBps  (30.0 s, 2 samples)
  39. Pipe Throughput                            12593502.5 lps   (10.0 s, 7 samples)
  40. Pipe-based Context Switching                1482450.0 lps   (10.0 s, 7 samples)
  41. Process Creation                              48569.4 lps   (30.0 s, 2 samples)
  42. Shell Scripts (1 concurrent)                  45215.9 lpm   (60.0 s, 2 samples)
  43. Shell Scripts (8 concurrent)                   6069.0 lpm   (60.0 s, 2 samples)
  44. System Call Overhead                        5577168.2 lps   (10.0 s, 7 samples)
  45. System Benchmarks Index Values               BASELINE       RESULT    INDEX
  46. Dhrystone 2 using register variables         116700.0  321625610.5  27560.0
  47. Double-Precision Whetstone                       55.0      48357.0   8792.2
  48. Execl Throughput                                 43.0      17297.0   4022.6
  49. File Copy 1024 bufsize 2000 maxblocks          3960.0    1395637.5   3524.3
  50. File Copy 256 bufsize 500 maxblocks            1655.0     408910.1   2470.8
  51. File Copy 4096 bufsize 8000 maxblocks          5800.0    3826922.0   6598.1
  52. Pipe Throughput                               12440.0   12593502.5  10123.4
  53. Pipe-based Context Switching                   4000.0    1482450.0   3706.1
  54. Process Creation                                126.0      48569.4   3854.7
  55. Shell Scripts (1 concurrent)                     42.4      45215.9  10664.1
  56. Shell Scripts (8 concurrent)                      6.0       6069.0  10115.0
  57. System Call Overhead                          15000.0    5577168.2   3718.1
  58.        ========
  59. System Benchmarks Index Score                                        6203.5
  60. ======= Script description and score comparison completed! =======
 楼主| 发表于 2025-5-19 12:36:35 | 只看该作者
现在已经可以购买了
发表于 2025-5-19 18:18:44 | 只看该作者
已上车,装个win机做云桌面很爽
GMT+8, 2026-4-19 13:18 , Processed in 0.058129 second(s), 9 queries , Gzip On, MemCache On.
