12
返回列表 发新帖
楼主: xrp
colocrossing服务器三星840硬盘读写测试cc/ccs
发表于 2024-12-7 10:29:12 | 只看该作者
xrp 发表于 2024-12-7 09:09
老版赚大了,三星860固态盘超级好用
其实没觉得有过人之处,因为通电4.5w小时,写入44TB了
  1. smartctl 7.4 2023-08-01 r5530 [x86_64-linux-6.8.0-49-generic] (local build)
  2. Copyright (C) 2002-23, Bruce Allen, Christian Franke, www.smartmontools.org
  3. === START OF INFORMATION SECTION ===
  4. Model Family:     Samsung based SSDs
  5. Device Model:     Samsung SSD 860 EVO 1TB
  6. Serial Number:    S3Z6NW0K710730V
  7. LU WWN Device Id: 5 002538 e70072b94
  8. Firmware Version: RVT01B6Q
  9. User Capacity:    1,000,204,886,016 bytes [1.00 TB]
  10. Sector Size:      512 bytes logical/physical
  11. Rotation Rate:    Solid State Device
  12. Form Factor:      2.5 inches
  13. TRIM Command:     Available, deterministic, zeroed
  14. Device is:        In smartctl database 7.3/5528
  15. ATA Version is:   ACS-4 T13/BSR INCITS 529 revision 5
  16. SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
  17. Local Time is:    Sat Dec  7 02:21:07 2024 UTC
  18. SMART support is: Available - device has SMART capability.
  19. SMART support is: Enabled
  1.   9 Power_On_Hours          0x0032   090   090   000    Old_age   Always       -       45508
  2. ...
  3. 241 Total_LBAs_Written      0x0032   099   099   000    Old_age   Always       -       94174982713
 楼主| 发表于 2024-12-7 21:51:01 | 只看该作者
牛逼 这机器 840 与 850 写入都是**万小时了啊 写入 几百T
GMT+8, 2026-4-21 13:16 , Processed in 0.061436 second(s), 9 queries , Gzip On, MemCache On.
